This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Security 6.4.1! |
SAML 2.0 Login Overview
Let’s take a look at how SAML 2.0 Relying Party Authentication works within Spring Security. First, we see that, like OAuth 2.0 Login, Spring Security takes the user to a third-party for performing authentication. It does this through a series of redirects.
The figure above builds off our SecurityFilterChain
and AbstractAuthenticationProcessingFilter
diagrams:
First, a user makes an unauthenticated request to the resource
/private
for which it is not authorized.
Spring Security’s
FilterSecurityInterceptor
indicates that the unauthenticated request is Denied by throwing an AccessDeniedException
Since the user lacks authorization, the
ExceptionTranslationFilter
initiates Start Authentication.
The configured AuthenticationEntryPoint
is an instance of LoginUrlAuthenticationEntryPoint
which redirects to the <saml2:AuthnRequest>
generating endpoint, Saml2WebSsoAuthenticationRequestFilter
Or, if you’ve configured more than one asserting party, it will first redirect to a picker page.
Next, the
creates, signs, serializes, and encodes a <saml2:AuthnRequest>
using its configured Saml2AuthenticationRequestFactory
Then, the browser takes this
and presents it to the asserting party.
The asserting party attempts to authentication the user.
If successful, it will return a <saml2:Response>
back to the browser.
The browser then POSTs the
<saml2:Response>
to the assertion consumer service endpoint.
<saml2:Response>
The figure builds off our SecurityFilterChain
diagram.
When the browser submits a
<saml2:Response>
to the application, it delegates to Saml2WebSsoAuthenticationFilter
This filter calls its configured AuthenticationConverter
to create a Saml2AuthenticationToken
by extracting the response from the HttpServletRequest
This converter additionally resolves the RelyingPartyRegistration
and supplies it to Saml2AuthenticationToken
Next, the filter passes the token to its configured
AuthenticationManager
By default, it will use the OpenSAML authentication provider
If authentication fails, then Failure
The
SecurityContextHolder
is cleared out. -
The
is invoked to restart the authentication process.
If authentication is successful, then Success.
The
Authentication
is set on theSecurityContextHolder
The
invokesFilterChain#doFilter(request,response)
to continue with the rest of the application logic.
Minimal Dependencies
SAML 2.0 service provider support resides in spring-security-saml2-service-provider
It builds off of the OpenSAML library, and, for that reason, you must also include the Shibboleth Maven repository in your build configuration.
Check this link for more details about why a separate repository is needed.
Maven
Gradle
<repositories>
<repository>
<id>shibboleth-releases</id>
<url>https://build.shibboleth.net/nexus/content/repositories/releases/</url>
</repository>
</repositories>
<dependency>
<groupId>org.springframework.security</groupId>
<artifactId>spring-security-saml2-service-provider</artifactId>
</dependency>
repositories {
maven { url "https://build.shibboleth.net/nexus/content/repositories/releases/" }
dependencies {
implementation 'org.springframework.security:spring-security-saml2-service-provider'
Minimal Configuration
When using Spring Boot, configuring an application as a service provider consists of two basic steps. First, include the needed dependencies and second, indicate the necessary asserting party metadata.
Also, this presupposes that you’ve already registered the relying party with your asserting party. |
Specifying Identity Provider Metadata
In a Spring Boot application, to specify an identity provider’s metadata, simply do:
spring:
security:
saml2:
relyingparty:
registration:
adfs:
identityprovider:
entity-id: https://idp.example.com/issuer
verification.credentials:
- certificate-location: "classpath:idp.crt"
singlesignon.url: https://idp.example.com/issuer/sso
singlesignon.sign-request: false
where
is the value contained in theIssuer
attribute of the SAML responses that the identity provider will issue -
classpath:idp.crt
is the location on the classpath for the identity provider’s certificate for verifying SAML responses, and -
is the endpoint where the identity provider is expectingAuthnRequest
s.
And that’s it!
Identity Provider and Asserting Party are synonymous, as are Service Provider and Relying Party. These are frequently abbreviated as AP and RP, respectively. |
Runtime Expectations
As configured above, the application processes any POST /login/saml2/sso/{registrationId}
request containing a SAMLResponse
parameter:
POST /login/saml2/sso/adfs HTTP/1.1
SAMLResponse=PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZ...
There are two ways to see induce your asserting party to generate a SAMLResponse
First, you can navigate to your asserting party. It likely has some kind of link or button for each registered relying party that you can click to send the
SAMLResponse
Second, you can navigate to a protected page in your app, for example,
localhost:8080
. Your app then redirects to the configured asserting party which then sends theSAMLResponse
From here, consider jumping to:
How SAML 2.0 Login Integrates with OpenSAML
Spring Security’s SAML 2.0 support has a couple of design goals:
First, rely on a library for SAML 2.0 operations and domain objects. To achieve this, Spring Security uses OpenSAML.
Second, ensure this library is not required when using Spring Security’s SAML support. To achieve this, any interfaces or classes where Spring Security uses OpenSAML in the contract remain encapsulated. This makes it possible for you to switch out OpenSAML for some other library or even an unsupported version of OpenSAML.
As a natural outcome of the above two goals, Spring Security’s SAML API is quite small relative to other modules.
Instead, classes like OpenSaml4AuthenticationRequestFactory
and OpenSaml4AuthenticationProvider
expose Converter
s that customize various steps in the authentication process.
For example, once your application receives a SAMLResponse
and delegates to Saml2WebSsoAuthenticationFilter
, the filter will delegate to OpenSaml4AuthenticationProvider
For backward compatibility, Spring Security will use the latest OpenSAML 3 by default. Note, though that OpenSAML 3 has reached it’s end-of-life and updating to OpenSAML 4.x is recommended. For that reason, Spring Security supports both OpenSAML 3.x and 4.x. If you manage your OpenSAML dependency to 4.x, then Spring Security will select its OpenSAML 4.x implementations. |
Response
This figure builds off of the Saml2WebSsoAuthenticationFilter
diagram.
The
formulates the Saml2AuthenticationToken
and invokes the AuthenticationManager
The
invokes the OpenSAML authentication provider.
The authentication provider deserializes the response into an OpenSAML
Response
and checks its signature.
If the signature is invalid, authentication fails.
Then, the provider decrypts any
EncryptedAssertion
elements.
If any decryptions fail, authentication fails.
Next, the provider validates the response’s
Issuer
and Destination
values.
If they don’t match what’s in the RelyingPartyRegistration
After that, the provider verifies the signature of each
Assertion
If any signature is invalid, authentication fails.
Also, if neither the response nor the assertions have signatures, authentication fails.
Either the response or all the assertions must have signatures.
Then, the provider ,decrypts any
EncryptedID
or EncryptedAttribute
elements].
Next, the provider validates each assertion’s
ExpiresAt
and NotBefore
timestamps, the <Subject>
and any <AudienceRestriction>
conditions.
If any validations fail, authentication fails.
Following that, the provider takes the first assertion’s
AttributeStatement
and maps it to a Map<String, List<Object>>
It also grants the ROLE_USER
granted authority.
And finally, it takes the
NameID
from the first assertion, the Map
of attributes, and the GrantedAuthority
and constructs a Saml2AuthenticatedPrincipal
Then, it places that principal and the authorities into a Saml2Authentication
The resulting Authentication#getPrincipal
is a Spring Security Saml2AuthenticatedPrincipal
object, and Authentication#getName
maps to the first assertion’s NameID
element.
Saml2AuthenticatedPrincipal#getRelyingPartyRegistrationId
holds the identifier to the associated RelyingPartyRegistration
Customizing OpenSAML Configuration
Any class that uses both Spring Security and OpenSAML should statically initialize OpenSamlInitializationService
at the beginning of the class, like so:
Java
Kotlin
static {
OpenSamlInitializationService.initialize();
companion object {
init {
This replaces OpenSAML’s InitializationService#initialize
Occasionally, it can be valuable to customize how OpenSAML builds, marshalls, and unmarshalls SAML objects.
In these circumstances, you may instead want to call OpenSamlInitializationService#requireInitialize(Consumer)
that gives you access to OpenSAML’s XMLObjectProviderFactory
For example, when sending an unsigned AuthNRequest, you may want to force reauthentication.
In that case, you can register your own AuthnRequestMarshaller
, like so:
Java
Kotlin
static {
OpenSamlInitializationService.requireInitialize(factory -> {
AuthnRequestMarshaller marshaller = new AuthnRequestMarshaller() {
public Element marshall(XMLObject object, Element element) throws MarshallingException {
configureAuthnRequest((AuthnRequest) object);
return super.marshall(object, element);
public Element marshall(XMLObject object, Document document) throws MarshallingException {
return super.marshall(object, document);
private void configureAuthnRequest(AuthnRequest authnRequest) {
authnRequest.setForceAuthn(true);
factory.getMarshallerFactory().registerMarshaller(AuthnRequest.DEFAULT_ELEMENT_NAME, marshaller);
companion object {
init {
OpenSamlInitializationService.requireInitialize {
val marshaller = object : AuthnRequestMarshaller() {
override fun marshall(xmlObject: XMLObject, element: Element): Element {
configureAuthnRequest(xmlObject as AuthnRequest)
return super.marshall(xmlObject, element)
override fun marshall(xmlObject: XMLObject, document: Document): Element {
return super.marshall(xmlObject, document)
private fun configureAuthnRequest(authnRequest: AuthnRequest) {
authnRequest.isForceAuthn = true
it.marshallerFactory.registerMarshaller(AuthnRequest.DEFAULT_ELEMENT_NAME, marshaller)
The requireInitialize
method may only be called once per application instance.
Overriding or Replacing Boot Auto Configuration
There are two @Bean
s that Spring Boot generates for a relying party.
The first is a SecurityFilterChain
that configures the app as a relying party.
When including spring-security-saml2-service-provider
, the SecurityFilterChain
looks like:
Java
Kotlin
http
.anyRequest().authenticated()
.saml2Login(withDefaults());
return http.build();
http {
authorizeRequests {
saml2Login { }
return http.build()
If the application doesn’t expose a SecurityFilterChain
bean, then Spring Boot will expose the above default one.
You can replace this by exposing the bean within the application:
Java
Kotlin
@EnableWebSecurity
public class MyCustomSecurityConfiguration {
http
.requestMatchers("/messages/**").hasAuthority("ROLE_USER")
@EnableWebSecurity
http {
authorizeRequests {
authorize("/messages/**", hasAuthority("ROLE_USER"))
saml2Login {
return http.build()
The above requires the role of USER
for any URL that starts with /messages/
The second @Bean
Spring Boot creates is a RelyingPartyRegistrationRepository
, which represents the asserting party and relying party metadata.
This includes things like the location of the SSO endpoint the relying party should use when requesting authentication from the asserting party.
You can override the default by publishing your own RelyingPartyRegistrationRepository
bean.
For example, you can look up the asserting party’s configuration by hitting its metadata endpoint like so:
Java
Kotlin
@Value("${metadata.location}")
String assertingPartyMetadataLocation;
public RelyingPartyRegistrationRepository relyingPartyRegistrations() {
RelyingPartyRegistration registration = RelyingPartyRegistrations
.fromMetadataLocation(assertingPartyMetadataLocation)
.registrationId("example")
return new InMemoryRelyingPartyRegistrationRepository(registration);
@Value("\${metadata.location}")
var assertingPartyMetadataLocation: String? = null
open fun relyingPartyRegistrations(): RelyingPartyRegistrationRepository? {
val registration = RelyingPartyRegistrations
.build()
return InMemoryRelyingPartyRegistrationRepository(registration)
The registrationId is an arbitrary value that you choose for differentiating between registrations.
Or you can provide each detail manually, as you can see below:
Java
Kotlin
@Value("${verification.key}")
File verificationKey;
public RelyingPartyRegistrationRepository relyingPartyRegistrations() throws Exception {
X509Certificate certificate = X509Support.decodeCertificate(this.verificationKey);
Saml2X509Credential credential = Saml2X509Credential.verification(certificate);
.withRegistrationId("example")
.assertingPartyDetails(party -> party
.entityId("https://idp.example.com/issuer")
.singleSignOnServiceLocation("https://idp.example.com/SSO.saml2")
.wantAuthnRequestsSigned(false)
.verificationX509Credentials(c -> c.add(credential))
@Value("\${verification.key}")
var verificationKey: File? = null
open fun relyingPartyRegistrations(): RelyingPartyRegistrationRepository {
val certificate: X509Certificate? = X509Support.decodeCertificate(verificationKey!!)
val credential: Saml2X509Credential = Saml2X509Credential.verification(certificate)
.assertingPartyDetails { party: AssertingPartyDetails.Builder ->
party
.verificationX509Credentials { c: MutableCollection<Saml2X509Credential?> ->
c.add(
credential
.build()
Note that X509Support is an OpenSAML class, used here in the snippet for brevity
Alternatively, you can directly wire up the repository using the DSL, which will also override the auto-configured SecurityFilterChain
Java
Kotlin
@EnableWebSecurity
http
.saml2Login(saml2 -> saml2
.relyingPartyRegistrationRepository(relyingPartyRegistrations())
@EnableWebSecurity
http {
authorizeRequests {
saml2Login {
relyingPartyRegistrationRepository = relyingPartyRegistrations()
return http.build()
A relying party can be multi-tenant by registering more than one relying party in the RelyingPartyRegistrationRepository .
A RelyingPartyRegistration
instance represents a link between an relying party and assering party’s metadata.
In a RelyingPartyRegistration
, you can provide relying party metadata like its Issuer
value, where it expects SAML Responses to be sent to, and any credentials that it owns for the purposes of signing or decrypting payloads.
Also, you can provide asserting party metadata like its Issuer
value, where it expects AuthnRequests to be sent to, and any public credentials that it owns for the purposes of the relying party verifying or encrypting payloads.
The following RelyingPartyRegistration
is the minimum required for most setups:
Java
Kotlin
RelyingPartyRegistration relyingPartyRegistration = RelyingPartyRegistrations
.fromMetadataLocation("https://ap.example.org/metadata")
.registrationId("my-id")
val relyingPartyRegistration = RelyingPartyRegistrations
.build()
Note that you can also create a RelyingPartyRegistration
from an arbitrary InputStream
source.
One such example is when the metadata is stored in a database:
String xml = fromDatabase();
try (InputStream source = new ByteArrayInputStream(xml.getBytes())) {
.fromMetadata(source)
Though a more sophisticated setup is also possible, like so:
Java
Kotlin
RelyingPartyRegistration relyingPartyRegistration = RelyingPartyRegistration.withRegistrationId("my-id")
.entityId("{baseUrl}/{registrationId}")
.decryptionX509Credentials(c -> c.add(relyingPartyDecryptingCredential()))
.assertionConsumerServiceLocation("/my-login-endpoint/{registrationId}")
.entityId("https://ap.example.org")
.verificationX509Credentials(c -> c.add(assertingPartyVerifyingCredential()))
.singleSignOnServiceLocation("https://ap.example.org/SSO.saml2")
.decryptionX509Credentials { c: MutableCollection<Saml2X509Credential?> ->
.assertingPartyDetails { party -> party
.verificationX509Credentials { c -> c.add(assertingPartyVerifyingCredential()) }
.build()
The top-level metadata methods are details about the relying party.
The methods inside assertingPartyDetails are details about the asserting party.
The location where a relying party is expecting SAML Responses is the Assertion Consumer Service Location. |
The default for the relying party’s entityId
is {baseUrl}/saml2/service-provider-metadata/{registrationId}
This is this value needed when configuring the asserting party to know about your relying party.
The default for the assertionConsumerServiceLocation
is /login/saml2/sso/{registrationId}
It’s mapped by default to Saml2WebSsoAuthenticationFilter
in the filter chain.
URI Patterns
You probably noticed in the above examples the {baseUrl}
and {registrationId}
placeholders.
These are useful for generating URIs. As such, the relying party’s entityId
and assertionConsumerServiceLocation
support the following placeholders:
baseUrl
- the scheme, host, and port of a deployed application -
registrationId
- the registration id for this relying party -
baseScheme
- the scheme of a deployed application -
baseHost
- the host of a deployed application -
basePort
- the port of a deployed application
For example, the assertionConsumerServiceLocation
defined above was:
which in a deployed application would translate to
/my-login-endpoint/adfs
The entityId
above was defined as:
https://rp.example.com/adfs
The prevailing URI patterns are as follows:
/saml2/authenticate/{registrationId}
- The endpoint that generates a<saml2:AuthnRequest>
based on the configurations for thatRelyingPartyRegistration
and sends it to the asserting party -
/saml2/login/sso/{registrationId}
- The endpoint that authenticates an asserting party’s<saml2:Response>
/saml2/logout/sso
- The endpoint that processes<saml2:LogoutRequest>
and<saml2:LogoutResponse>
payloads; theRelyingPartyRegistration
is looked up from previously authenticated state -
/saml2/saml2-service-provider/metadata/{registrationId}
- The relying party metadata for thatRelyingPartyRegistration
Since the registrationId
is the primary identifier for a RelyingPartyRegistration
, it is needed in the URL for unauthenticated scenarios.
If you wish to remove the registrationId
from the URL for any reason, you can specify a RelyingPartyRegistrationResolver
to tell Spring Security how to look up the registrationId
Credentials
You also likely noticed the credential that was used.
Oftentimes, a relying party will use the same key to sign payloads as well as decrypt them. Or it will use the same key to verify payloads as well as encrypt them.
Because of this, Spring Security ships with Saml2X509Credential
, a SAML-specific credential that simplifies configuring the same key for different use cases.
At a minimum, it’s necessary to have a certificate from the asserting party so that the asserting party’s signed responses can be verified.
To construct a Saml2X509Credential
that you’ll use to verify assertions from the asserting party, you can load the file and use
the CertificateFactory
like so:
Java
Kotlin
Resource resource = new ClassPathResource("ap.crt");
try (InputStream is = resource.getInputStream()) {
X509Certificate certificate = (X509Certificate)
CertificateFactory.getInstance("X.509").generateCertificate(is);
return Saml2X509Credential.verification(certificate);
val resource = ClassPathResource("ap.crt")
resource.inputStream.use {
CertificateFactory.getInstance("X.509").generateCertificate(it) as X509Certificate?
Let’s say that the asserting party is going to also encrypt the assertion. In that case, the relying party will need a private key to be able to decrypt the encrypted value.
In that case, you’ll need an RSAPrivateKey
as well as its corresponding X509Certificate
You can load the first using Spring Security’s RsaKeyConverters
utility class and the second as you did before:
Java
Kotlin
X509Certificate certificate = relyingPartyDecryptionCertificate();
Resource resource = new ClassPathResource("rp.crt");
RSAPrivateKey rsa = RsaKeyConverters.pkcs8().convert(is);
return Saml2X509Credential.decryption(rsa, certificate);
val certificate: X509Certificate = relyingPartyDecryptionCertificate()
val resource = ClassPathResource("rp.crt")
val rsa: RSAPrivateKey = RsaKeyConverters.pkcs8().convert(it)
When you specify the locations of these files as the appropriate Spring Boot properties, then Spring Boot will perform these conversions for you. |
Duplicated Relying Party Configurations
When an application uses multiple asserting parties, some configuration is duplicated between RelyingPartyRegistration
instances:
The relying party’s
entityId
Its
, and -
Its credentials, for example its signing or decryption credentials
What’s nice about this setup is credentials may be more easily rotated for some identity providers vs others.
The duplication can be alleviated in a few different ways.
First, in YAML this can be alleviated with references, like so:
spring:
security:
saml2:
relyingparty:
okta:
signing.credentials: &relying-party-credentials
- private-key-location: classpath:rp.key
certificate-location: classpath:rp.crt
identityprovider:
entity-id: ...
azure:
signing.credentials: *relying-party-credentials
identityprovider:
entity-id: ...
Second, in a database, it’s not necessary to replicate RelyingPartyRegistration
's model.
Third, in Java, you can create a custom configuration method, like so:
Java
Kotlin
private RelyingPartyRegistration.Builder
addRelyingPartyDetails(RelyingPartyRegistration.Builder builder) {
Saml2X509Credential signingCredential = ...
builder.signingX509Credentials(c -> c.addAll(signingCredential));
// ... other relying party configurations
RelyingPartyRegistration okta = addRelyingPartyDetails(
.fromMetadataLocation(oktaMetadataUrl)
.registrationId("okta")).build();
RelyingPartyRegistration azure = addRelyingPartyDetails(
.registrationId("azure")).build();
return new InMemoryRelyingPartyRegistrationRepository(okta, azure);
private fun addRelyingPartyDetails(builder: RelyingPartyRegistration.Builder): RelyingPartyRegistration.Builder {
val signingCredential: Saml2X509Credential = ...
builder.signingX509Credentials { c: MutableCollection<Saml2X509Credential?> ->
c.add(
signingCredential
val okta = addRelyingPartyDetails(
).build()
val azure = addRelyingPartyDetails(
).build()
return InMemoryRelyingPartyRegistrationRepository(okta, azure)
Resolving the RelyingPartyRegistration
from the Request
As seen so far, Spring Security resolves the RelyingPartyRegistration
by looking for the registration id in the URI path.
There are a number of reasons you may want to customize that. Among them:
You may already know which
you need -
You may be federating many asserting parties
To customize the way that a RelyingPartyRegistration
is resolved, you can configure a custom RelyingPartyRegistrationResolver
The default looks up the registration id from the URI’s last path element and looks it up in your RelyingPartyRegistrationRepository
Remember that if you have any placeholders in your RelyingPartyRegistration , your resolver implementation should resolve them.
Resolving to a Single Consistent RelyingPartyRegistration
You can provide a resolver that, for example, always returns the same RelyingPartyRegistration
Java
Kotlin
public class SingleRelyingPartyRegistrationResolver implements RelyingPartyRegistrationResolver {
private final RelyingPartyRegistrationResolver delegate;
public SingleRelyingPartyRegistrationResolver(RelyingPartyRegistrationRepository registrations) {
this.delegate = new DefaultRelyingPartyRegistrationResolver(registrations);
public RelyingPartyRegistration resolve(HttpServletRequest request, String registrationId) {
return this.delegate.resolve(request, "single");
class SingleRelyingPartyRegistrationResolver(delegate: RelyingPartyRegistrationResolver) : RelyingPartyRegistrationResolver {
override fun resolve(request: HttpServletRequest?, registrationId: String?): RelyingPartyRegistration? {
You might next take a look at how to use this resolver to customize <saml2:SPSSODescriptor> metadata production.
Resolving Based on the <saml2:Response#Issuer>
When you have one relying party that can accept assertions from multiple asserting parties, you will have as many RelyingPartyRegistration
s as asserting parties, with the relying party information duplicated across each instance.
This carries the implication that the assertion consumer service endpoint will be different for each asserting party, which may not be desirable.
You can instead resolve the registrationId
via the Issuer
A custom implementation of RelyingPartyRegistrationResolver
that does this may look like:
Java
Kotlin
public class SamlResponseIssuerRelyingPartyRegistrationResolver implements RelyingPartyRegistrationResolver {
private final InMemoryRelyingPartyRegistrationRepository registrations;
// ... constructor
if (registrationId != null) {
return this.registrations.findByRegistrationId(registrationId);
String entityId = resolveEntityIdFromSamlResponse(request);
for (RelyingPartyRegistration registration : this.registrations) {
if (registration.getAssertingPartyDetails().getEntityId().equals(entityId)) {
return registration;
return null;
private String resolveEntityIdFromSamlResponse(HttpServletRequest request) {
class SamlResponseIssuerRelyingPartyRegistrationResolver(val registrations: InMemoryRelyingPartyRegistrationRepository):
fun resolve(val request: HttpServletRequest, val registrationId: String): RelyingPartyRegistration {
for (val registration : this.registrations) {
return registration
return null
private resolveEntityIdFromSamlResponse(val request: HttpServletRequest): String {
You might next take a look at how to use this resolver to customize <saml2:Response> authentication.
Federating Login
One common arrangement with SAML 2.0 is an identity provider that has multiple asserting parties.
In this case, the identity provider’s metadata endpoint returns multiple <md:IDPSSODescriptor>
elements.
These multiple asserting parties can be accessed in a single call to RelyingPartyRegistrations
like so:
Java
Kotlin
Collection<RelyingPartyRegistration> registrations = RelyingPartyRegistrations
.collectionFromMetadataLocation("https://example.org/saml2/idp/metadata.xml")
.stream().map((builder) -> builder
.registrationId(UUID.randomUUID().toString())
.entityId("https://example.org/saml2/sp")
.build()
.collect(Collectors.toList()));
var registrations: Collection<RelyingPartyRegistration> = RelyingPartyRegistrations
.stream().map { builder : RelyingPartyRegistration.Builder -> builder
.build()
Note that because the registration id is set to a random value, this will change certain SAML 2.0 endpoints to be unpredictable. There are several ways to address this; let’s focus on a way that suits the specific use case of federation.
In many federation cases, all the asserting parties share service provider configuration.
Given that Spring Security will by default include the registrationId
in all many of its SAML 2.0 URIs, the next step is often to change these URIs to exclude the registrationId
There are two main URIs you will want to change along those lines:
Optionally, you may also want to change the Authentication Request location, but since this is a URI internal to the app and not published to asserting parties, the benefit is often minimal. |
You can see a completed example of this in our saml-extension-federation
sample.
Using Spring Security SAML Extension URIs
In the event that you are migrating from the Spring Security SAML Extension, there may be some benefit to configuring your application to use the SAML Extension URI defaults.
For more information on this, please see our custom-urls
sample and our saml-extension-federation
sample.
