This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Security 6.4.1! |
OAuth 2.0 Resource Server Multi-tenancy
Multi-tenancy
A resource server is considered multi-tenant when there are multiple strategies for verifying a bearer token, keyed by some tenant identifier.
For example, your resource server may accept bearer tokens from two different authorization servers. Or, your authorization server may represent a multiplicity of issuers.
In each case, there are two things that need to be done and trade-offs associated with how you choose to do them:
Resolve the tenant
Propagate the tenant
Resolving the Tenant By Claim
One way to differentiate tenants is by the issuer claim. Since the issuer claim accompanies signed JWTs, this can be done with the JwtIssuerReactiveAuthenticationManagerResolver
, like so:
Java
Kotlin
JwtIssuerReactiveAuthenticationManagerResolver authenticationManagerResolver = new JwtIssuerReactiveAuthenticationManagerResolver
("https://idp.example.org/issuerOne", "https://idp.example.org/issuerTwo");
http
.authorizeExchange(exchanges -> exchanges
.oauth2ResourceServer(oauth2 -> oauth2
.authenticationManagerResolver(authenticationManagerResolver)
val customAuthenticationManagerResolver = JwtIssuerReactiveAuthenticationManagerResolver("https://idp.example.org/issuerOne", "https://idp.example.org/issuerTwo")
return http {
authorizeExchange {
oauth2ResourceServer {
authenticationManagerResolver = customAuthenticationManagerResolver
This is nice because the issuer endpoints are loaded lazily.
In fact, the corresponding JwtReactiveAuthenticationManager
is instantiated only when the first request with the corresponding issuer is sent.
This allows for an application startup that is independent from those authorization servers being up and available.
Dynamic Tenants
Of course, you may not want to restart the application each time a new tenant is added.
In this case, you can configure the JwtIssuerReactiveAuthenticationManagerResolver
with a repository of ReactiveAuthenticationManager
instances, which you can edit at runtime, like so:
Java
Kotlin
private Mono<ReactiveAuthenticationManager> addManager(
Map<String, ReactiveAuthenticationManager> authenticationManagers, String issuer) {
return Mono.fromCallable(() -> ReactiveJwtDecoders.fromIssuerLocation(issuer))
.subscribeOn(Schedulers.boundedElastic())
.map(JwtReactiveAuthenticationManager::new)
.doOnNext(authenticationManager -> authenticationManagers.put(issuer, authenticationManager));
new JwtIssuerReactiveAuthenticationManagerResolver(authenticationManagers::get);
http
private fun addManager(
authenticationManagers: MutableMap<String, ReactiveAuthenticationManager>, issuer: String): Mono<JwtReactiveAuthenticationManager> {
return Mono.fromCallable { ReactiveJwtDecoders.fromIssuerLocation(issuer) }
.map { jwtDecoder: ReactiveJwtDecoder -> JwtReactiveAuthenticationManager(jwtDecoder) }
.doOnNext { authenticationManager: JwtReactiveAuthenticationManager -> authenticationManagers[issuer] = authenticationManager }
var customAuthenticationManagerResolver = JwtIssuerReactiveAuthenticationManagerResolver(authenticationManagers::get)
return http {
authorizeExchange {
In this case, you construct JwtIssuerReactiveAuthenticationManagerResolver
with a strategy for obtaining the ReactiveAuthenticationManager
given the issuer.
This approach allows us to add and remove elements from the repository (shown as a Map
in the snippet) at runtime.
It would be unsafe to simply take any issuer and construct an ReactiveAuthenticationManager from it.
The issuer should be one that the code can verify from a trusted source like an allowed list of issuers.
