OAuth Migrations
The following steps relate to changes around how to configure OAuth 2.0.spring-doc.cn
Change Default oauth2Login() Authorities
In Spring Security 5, the default GrantedAuthority given to a user that authenticates with an OAuth2 or OpenID Connect 1.0 provider (via oauth2Login()) is ROLE_USER.spring-doc.cn
See Mapping User Authorities for more information.spring-doc.cn
In Spring Security 6, the default authority given to a user authenticating with an OAuth2 provider is OAUTH2_USER. The default authority given to a user authenticating with an OpenID Connect 1.0 provider is OIDC_USER. These defaults allow clearer distinction of users that have authenticated with an OAuth2 or OpenID Connect 1.0 provider.spring-doc.cn
If you are using authorization rules or expressions such as hasRole("USER") or hasAuthority("ROLE_USER") to authorize users with this specific authority, the new defaults in Spring Security 6 will impact your application.spring-doc.cn
To opt into the new Spring Security 6 defaults, the following configuration can be used.spring-doc.cn
Configure oauth2Login() with 6.0 defaults
public SecurityFilterChain securityFilterChain(HttpSecurity http) throws Exception {
	http
		.oauth2Login((oauth2Login) -> oauth2Login
			.userInfoEndpoint((userInfo) -> userInfo
				.userAuthoritiesMapper(grantedAuthoritiesMapper())
	return http.build();
private GrantedAuthoritiesMapper grantedAuthoritiesMapper() {
	return (authorities) -> {
		Set<GrantedAuthority> mappedAuthorities = new HashSet<>();
		authorities.forEach((authority) -> {
			GrantedAuthority mappedAuthority;
			if (authority instanceof OidcUserAuthority) {
				OidcUserAuthority userAuthority = (OidcUserAuthority) authority;
				mappedAuthority = new OidcUserAuthority(
					"OIDC_USER", userAuthority.getIdToken(), userAuthority.getUserInfo());
			} else if (authority instanceof OAuth2UserAuthority) {
				OAuth2UserAuthority userAuthority = (OAuth2UserAuthority) authority;
				mappedAuthority = new OAuth2UserAuthority(
					"OAUTH2_USER", userAuthority.getAttributes());
			} else {
				mappedAuthority = authority;
			mappedAuthorities.add(mappedAuthority);
		return mappedAuthorities;
fun securityFilterChain(http: HttpSecurity): SecurityFilterChain {
	http {
		oauth2Login {
			userInfoEndpoint {
				userAuthoritiesMapper = grantedAuthoritiesMapper()
	return http.build()
private fun grantedAuthoritiesMapper(): GrantedAuthoritiesMapper {
	return GrantedAuthoritiesMapper { authorities ->
		authorities.map { authority ->
			when (authority) {
				is OidcUserAuthority ->
					OidcUserAuthority("OIDC_USER", authority.idToken, authority.userInfo)
				is OAuth2UserAuthority ->
					OAuth2UserAuthority("OAUTH2_USER", authority.attributes)
				else -> authority
<http>
	<oauth2-login user-authorities-mapper-ref="userAuthoritiesMapper" ... />
</http>
Opt-out Steps
If configuring the new authorities gives you trouble, you can opt out and explicitly use the 5.8 authority of ROLE_USER with the following configuration.spring-doc.cn
Configure oauth2Login() with 5.8 defaults
	http
					"ROLE_USER", userAuthority.getIdToken(), userAuthority.getUserInfo());
					"ROLE_USER", userAuthority.getAttributes());
			} else {
	http {
		oauth2Login {
			userInfoEndpoint {
	return http.build()
			when (authority) {
					OidcUserAuthority("ROLE_USER", authority.idToken, authority.userInfo)
					OAuth2UserAuthority("ROLE_USER", authority.attributes)
				else -> authority
<http>
</http>
Address OAuth2 Client Deprecations
In Spring Security 6, deprecated classes and methods were removed from OAuth2 Client. Each deprecation is listed below, along with a direct replacement.spring-doc.cn
ServletOAuth2AuthorizedClientExchangeFilterFunction
The method setAccessTokenExpiresSkew(…​) can be replaced with one of:spring-doc.cn
  • ClientCredentialsOAuth2AuthorizedClientProvider#setClockSkew(…​)spring-doc.cn
  • RefreshTokenOAuth2AuthorizedClientProvider#setClockSkew(…​)spring-doc.cn
  • JwtBearerOAuth2AuthorizedClientProvider#setClockSkew(…​)spring-doc.cn
The method setClientCredentialsTokenResponseClient(…​) can be replaced with the constructor ServletOAuth2AuthorizedClientExchangeFilterFunction(OAuth2AuthorizedClientManager).spring-doc.cn
See Client Credentials for more information.spring-doc.cn
OidcUserInfo
The method phoneNumberVerified(String) can be replaced with phoneNumberVerified(Boolean).spring-doc.cn
OAuth2AuthorizedClientArgumentResolver
The method setClientCredentialsTokenResponseClient(…​) can be replaced with the constructor OAuth2AuthorizedClientArgumentResolver(OAuth2AuthorizedClientManager).spring-doc.cn
ClaimAccessor
The method containsClaim(…​) can be replaced with hasClaim(…​).spring-doc.cn
OidcClientInitiatedLogoutSuccessHandler
The method setPostLogoutRedirectUri(URI) can be replaced with setPostLogoutRedirectUri(String).spring-doc.cn
HttpSessionOAuth2AuthorizationRequestRepository
The method setAllowMultipleAuthorizationRequests(…​) has no direct replacement.spring-doc.cn
The method removeAuthorizationRequest(HttpServletRequest) can be replaced with removeAuthorizationRequest(HttpServletRequest, HttpServletResponse).spring-doc.cn
ClientRegistration
The method getRedirectUriTemplate() can be replaced with getRedirectUri().spring-doc.cn
ClientRegistration.Builder
The method redirectUriTemplate(…​) can be replaced with redirectUri(…​).spring-doc.cn
AbstractOAuth2AuthorizationGrantRequest
The constructor AbstractOAuth2AuthorizationGrantRequest(AuthorizationGrantType) can be replaced with AbstractOAuth2AuthorizationGrantRequest(AuthorizationGrantType, ClientRegistration).spring-doc.cn
ClientAuthenticationMethod
The static field BASIC can be replaced with CLIENT_SECRET_BASIC.spring-doc.cn
The static field POST can be replaced with CLIENT_SECRET_POST.spring-doc.cn
OAuth2AccessTokenResponseHttpMessageConverter
The field tokenResponseConverter has no direct replacement.spring-doc.cn
The method setTokenResponseConverter(…​) can be replaced with setAccessTokenResponseConverter(…​).spring-doc.cn
The field tokenResponseParametersConverter has no direct replacement.spring-doc.cn
The method setTokenResponseParametersConverter(…​) can be replaced with setAccessTokenResponseParametersConverter(…​).spring-doc.cn
NimbusAuthorizationCodeTokenResponseClient
The class NimbusAuthorizationCodeTokenResponseClient can be replaced with DefaultAuthorizationCodeTokenResponseClient.spring-doc.cn
NimbusJwtDecoderJwkSupport
The class NimbusJwtDecoderJwkSupport can be replaced with NimbusJwtDecoder or JwtDecoders.spring-doc.cn
ImplicitGrantConfigurer
The class ImplicitGrantConfigurer has no direct replacement.spring-doc.cn
Use of the implicit grant type is not recommended and all related support is removed in Spring Security 6.spring-doc.cn
The static field IMPLICIT has no direct replacement.spring-doc.cn
OAuth2AuthorizationResponseType
The static field TOKEN has no direct replacement.spring-doc.cn
The static method implicit() has no direct replacement.spring-doc.cn
Address JwtAuthenticationConverter Deprecation
The method extractAuthorities will be removed. Instead of extending JwtAuthenticationConverter, please supply a custom granted authorities converter with JwtAuthenticationConverter#setJwtGrantedAuthoritiesConverter.spring-doc.cn
