This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Security 6.4.1!spring-doc.cn
Authorized Client Features
Resolving an Authorized Client
The @RegisteredOAuth2AuthorizedClient annotation provides the capability of resolving a method parameter to an argument value of type OAuth2AuthorizedClient. This is a convenient alternative compared to accessing the OAuth2AuthorizedClient using the OAuth2AuthorizedClientManager or OAuth2AuthorizedClientService.spring-doc.cn
@Controller
	@GetMapping("/")
	public String index(@RegisteredOAuth2AuthorizedClient("okta") OAuth2AuthorizedClient authorizedClient) {
		OAuth2AccessToken accessToken = authorizedClient.getAccessToken();
		return "index";
@Controller
    @GetMapping("/")
    fun index(@RegisteredOAuth2AuthorizedClient("okta") authorizedClient: OAuth2AuthorizedClient): String {
        val accessToken = authorizedClient.accessToken
        return "index"
The @RegisteredOAuth2AuthorizedClient annotation is handled by OAuth2AuthorizedClientArgumentResolver, which directly uses an OAuth2AuthorizedClientManager and therefore inherits it’s capabilities.spring-doc.cn
WebClient integration for Servlet Environments
The OAuth 2.0 Client support integrates with WebClient using an ExchangeFilterFunction.spring-doc.cn
The ServletOAuth2AuthorizedClientExchangeFilterFunction provides a simple mechanism for requesting protected resources by using an OAuth2AuthorizedClient and including the associated OAuth2AccessToken as a Bearer Token. It directly uses an OAuth2AuthorizedClientManager and therefore inherits the following capabilities:spring-doc.cn
  • An OAuth2AccessToken will be requested if the client has not yet been authorized.spring-doc.cn
    • authorization_code - triggers the Authorization Request redirect to initiate the flowspring-doc.cn
    • client_credentials - the access token is obtained directly from the Token Endpointspring-doc.cn
    • password - the access token is obtained directly from the Token Endpointspring-doc.cn
  • If the OAuth2AccessToken is expired, it will be refreshed (or renewed) if an OAuth2AuthorizedClientProvider is available to perform the authorizationspring-doc.cn
The following code shows an example of how to configure WebClient with OAuth 2.0 Client support:spring-doc.cn
WebClient webClient(OAuth2AuthorizedClientManager authorizedClientManager) {
	ServletOAuth2AuthorizedClientExchangeFilterFunction oauth2Client =
			new ServletOAuth2AuthorizedClientExchangeFilterFunction(authorizedClientManager);
	return WebClient.builder()
			.apply(oauth2Client.oauth2Configuration())
fun webClient(authorizedClientManager: OAuth2AuthorizedClientManager?): WebClient {
    val oauth2Client = ServletOAuth2AuthorizedClientExchangeFilterFunction(authorizedClientManager)
            .build()
Providing the Authorized Client
The ServletOAuth2AuthorizedClientExchangeFilterFunction determines the client to use (for a request) by resolving the OAuth2AuthorizedClient from the ClientRequest.attributes() (request attributes).spring-doc.cn
The following code shows how to set an OAuth2AuthorizedClient as a request attribute:spring-doc.cn
@GetMapping("/")
	String resourceUri = ...
	String body = webClient
			.get()
			.uri(resourceUri)
			.attributes(oauth2AuthorizedClient(authorizedClient))   (1)
			.retrieve()
			.bodyToMono(String.class)
			.block();
	return "index";
@GetMapping("/")
    val resourceUri: String = ...
    val body: String = webClient
            .get()
            .uri(resourceUri)
            .retrieve()
            .bodyToMono()
            .block()
    return "index"
1 oauth2AuthorizedClient() is a static method in ServletOAuth2AuthorizedClientExchangeFilterFunction.
The following code shows how to set the ClientRegistration.getRegistrationId() as a request attribute:spring-doc.cn
@GetMapping("/")
public String index() {
			.get()
			.uri(resourceUri)
			.attributes(clientRegistrationId("okta"))   (1)
			.retrieve()
			.block();
	return "index";
@GetMapping("/")
fun index(): String {
            .get()
            .uri(resourceUri)
            .retrieve()
            .bodyToMono()
            .block()
    return "index"
1 clientRegistrationId() is a static method in ServletOAuth2AuthorizedClientExchangeFilterFunction.
The following code shows how to set an Authentication as a request attribute:spring-doc.cn
@GetMapping("/")
	Authentication anonymousAuthentication = new AnonymousAuthenticationToken(
			"anonymous", "anonymousUser", AuthorityUtils.createAuthorityList("ROLE_ANONYMOUS"));
			.get()
			.uri(resourceUri)
			.attributes(authentication(anonymousAuthentication))   (1)
			.retrieve()
			.block();
	return "index";
@GetMapping("/")
    val anonymousAuthentication: Authentication = AnonymousAuthenticationToken(
            .get()
            .uri(resourceUri)
            .retrieve()
            .bodyToMono()
            .block()
    return "index"
1 authentication() is a static method in ServletOAuth2AuthorizedClientExchangeFilterFunction.
It is recommended to be cautious with this feature since all HTTP requests will receive an access token bound to the provided principal.
Defaulting the Authorized Client
If neither OAuth2AuthorizedClient or ClientRegistration.getRegistrationId() is provided as a request attribute, the ServletOAuth2AuthorizedClientExchangeFilterFunction can determine the default client to use depending on it’s configuration.spring-doc.cn
If setDefaultOAuth2AuthorizedClient(true) is configured and the user has authenticated using HttpSecurity.oauth2Login(), the OAuth2AccessToken associated with the current OAuth2AuthenticationToken is used.spring-doc.cn
The following code shows the specific configuration:spring-doc.cn
	oauth2Client.setDefaultOAuth2AuthorizedClient(true);
            .build()
It is recommended to be cautious with this feature since all HTTP requests will receive the access token.
Alternatively, if setDefaultClientRegistrationId("okta") is configured with a valid ClientRegistration, the OAuth2AccessToken associated with the OAuth2AuthorizedClient is used.spring-doc.cn
	oauth2Client.setDefaultClientRegistrationId("okta");
            .build()
