Exploit Protection Migrations
The following steps relate to changes around how to configure CSRF.spring-doc.cn
Defer Loading CsrfToken
In Spring Security 5, the default behavior is that the CsrfToken will be loaded on every request. This means that in a typical setup, the HttpSession must be read for every request even if it is unnecessary.spring-doc.cn
Some examples of where it should be unnecessary to read the session include endpoints marked permitAll() such as static assets, static HTML pages, single-page applications hosted under the same domain/server, etc.spring-doc.cn
In Spring Security 6, the default is that the lookup of the CsrfToken will be deferred until it is needed.spring-doc.cn
The CsrfToken is needed whenever a request is made with an HTTP verb that would change the state of the application. This is covered in detail in Safe Methods Must be Read-only. Additionally, it is needed by any request that renders the token to the response, such as a web page with a <form> tag that includes a hidden <input> for the CSRF token.spring-doc.cn
To opt into the new Spring Security 6 default, the following configuration can be used.spring-doc.cn
public SecurityFilterChain springSecurity(HttpSecurity http) throws Exception {
	CsrfTokenRequestAttributeHandler requestHandler = new CsrfTokenRequestAttributeHandler();
	// set the name of the attribute the CsrfToken will be populated on
	requestHandler.setCsrfRequestAttributeName("_csrf");
	http
		.csrf((csrf) -> csrf
			.csrfTokenRequestHandler(requestHandler)
	return http.build();
open fun springSecurity(http: HttpSecurity): SecurityFilterChain {
	val requestHandler = CsrfTokenRequestAttributeHandler()
	http {
		csrf {
			csrfTokenRequestHandler = requestHandler
	return http.build()
<http>
	<csrf request-handler-ref="requestHandler"/>
</http>
<b:bean id="requestHandler"
	class="org.springframework.security.web.csrf.CsrfTokenRequestAttributeHandler"
	p:csrfRequestAttributeName="_csrf"/>
When the CsrfToken is deferred (the default in Spring Security 6), some applications may break due to the fact that they were designed with non-deferred CSRF tokens. See Opt-out Steps below for more information.spring-doc.cn
Opt-out Steps
If configuring the CsrfToken to be deferred gives you trouble, take a look at these scenarios for optimal opt out behavior:spring-doc.cn
I am using a Single-Page Application with CookieCsrfTokenRepository
If you are using a single-page app (SPA) to connect to a backend protected by Spring Security along with CookieCsrfTokenRepository.withHttpOnlyFalse(), you may find that the CSRF token is no longer returned to your application as a cookie on the first request to the server.spring-doc.cn
In this case, you have several options for restoring the behavior your client-side application expects. One option is to add a Filter that eagerly renders the CsrfToken to the response regardless of which request is made first, like so:spring-doc.cn
Add a Filter to return a cookie on the response
public SecurityFilterChain securityFilterChain(HttpSecurity http) throws Exception {
	CookieCsrfTokenRepository tokenRepository = CookieCsrfTokenRepository.withHttpOnlyFalse();
	http
			.csrfTokenRepository(tokenRepository)
		.addFilterAfter(new CsrfCookieFilter(), BasicAuthenticationFilter.class);
private static final class CsrfCookieFilter extends OncePerRequestFilter {
	protected void doFilterInternal(HttpServletRequest request, HttpServletResponse response, FilterChain filterChain)
			throws ServletException, IOException {
		CsrfToken csrfToken = (CsrfToken) request.getAttribute(CsrfToken.class.getName());
		// Render the token value to a cookie by causing the deferred token to be loaded
		csrfToken.getToken();
		filterChain.doFilter(request, response);
open fun securityFilterChain(http: HttpSecurity): SecurityFilterChain {
	val tokenRepository = CookieCsrfTokenRepository.withHttpOnlyFalse()
	http {
		csrf {
			csrfTokenRepository = tokenRepository
		addFilterAfter<BasicAuthenticationFilter>(CsrfCookieFilter())
	return http.build()
class CsrfCookieFilter : OncePerRequestFilter() {
	override fun doFilterInternal(request: HttpServletRequest, response: HttpServletResponse, filterChain: FilterChain) {
		val csrfToken = request.getAttribute(CsrfToken::class.java.name) as CsrfToken
		csrfToken.token
The option above does not require changes to the single-page application, but does cause the CsrfToken to be loaded on every request. If you do not wish to add a Filter to eagerly load tokens on every request, additional options are listed below.spring-doc.cn
I am using a Single-Page Application with HttpSessionCsrfTokenRepository
If you are using sessions, your application will benefit from deferred tokens. Instead of opting out, another option is to add a new @RestController with a /csrf endpoint, like so:spring-doc.cn
Add a /csrf endpoint
@RestController
public class CsrfController {
    @GetMapping("/csrf")
    public CsrfToken csrf(CsrfToken csrfToken) {
        return csrfToken;
@RestController
    fun csrf(csrfToken: CsrfToken): CsrfToken {
        return csrfToken
You may consider adding .requestMatchers("/csrf").permitAll() if the endpoint above is required prior to authenticating with the server.spring-doc.cn
The /csrf endpoint would need to be consumed by the client-side application in order to bootstrap the application for subsequent requests.spring-doc.cn
Instructions for calling the /csrf endpoint on application launch are specific to your client-side framework and therefore outside the scope of this document.spring-doc.cn
While this requires changes to your single-page application, the benefit is that the CSRF token is only loaded once and the token can continue to be deferred. This approach works particularly well with applications that use HttpSessionCsrfTokenRepository and do benefit from deferred tokens by allowing the HttpSession not to be read on every request.spring-doc.cn
If you simply wish to opt out of deferred tokens altogether, that option is listed next.spring-doc.cn
I need to opt out of deferred tokens for another reason
If deferred tokens break your application for another reason, then you can explicitly opt into the 5.8 defaults using the following configuration:spring-doc.cn
Explicit Configure CsrfToken with 5.8 Defaults
	requestHandler.setCsrfRequestAttributeName(null);
	http
	http {
		csrf {
	return http.build()
<http>
</http>
	class="org.springframework.security.web.csrf.CsrfTokenRequestAttributeHandler">
	<b:property name="csrfRequestAttributeName">
		<b:null/>
	</b:property>
</b:bean>
By setting the csrfRequestAttributeName to null, the CsrfToken must first be loaded to determine what attribute name to use. This causes the CsrfToken to be loaded on every request.spring-doc.cn
Protect against CSRF BREACH
If the steps for Defer Loading CsrfToken work for you, then you can also opt into Spring Security 6’s default support for BREACH protection of the CsrfToken using the following configuration:spring-doc.cn
CsrfToken BREACH Protection
DefaultSecurityFilterChain springSecurity(HttpSecurity http) throws Exception {
	XorCsrfTokenRequestAttributeHandler requestHandler = new XorCsrfTokenRequestAttributeHandler();
	http
	val requestHandler = XorCsrfTokenRequestAttributeHandler()
	http {
		csrf {
	return http.build()
<http>
</http>
	class="org.springframework.security.web.csrf.XorCsrfTokenRequestAttributeHandler"
Opt-out Steps
If configuring CSRF BREACH protection gives you trouble, take a look at these scenarios for optimal opt out behavior:spring-doc.cn
I am using AngularJS or another Javascript framework
If you are using AngularJS and the HttpClientXsrfModule (or a similar module in another framework) along with CookieCsrfTokenRepository.withHttpOnlyFalse(), you may find that automatic support no longer works.spring-doc.cn
In this case, you can configure Spring Security to validate the raw CsrfToken from the cookie while keeping CSRF BREACH protection of the response using a custom CsrfTokenRequestHandler with delegation, like so:spring-doc.cn
Configure CsrfToken BREACH Protection to validate raw tokens
	XorCsrfTokenRequestAttributeHandler delegate = new XorCsrfTokenRequestAttributeHandler();
	delegate.setCsrfRequestAttributeName("_csrf");
	// Use only the handle() method of XorCsrfTokenRequestAttributeHandler and the
	// default implementation of resolveCsrfTokenValue() from CsrfTokenRequestHandler
	CsrfTokenRequestHandler requestHandler = delegate::handle;
	http
	val delegate = XorCsrfTokenRequestAttributeHandler()
	val requestHandler = CsrfTokenRequestHandler(delegate::handle)
	http {
		csrf {
	return http.build()
<http>
	<csrf token-repository-ref="tokenRepository"
</http>
<b:bean id="tokenRepository"
	class="org.springframework.security.web.csrf.CookieCsrfTokenRepository"
	p:cookieHttpOnly="false"/>
This is the RECOMMENDED way to configure Spring Security to work with a client-side application that uses cookie values, because it continues to allow the response to return a randomized value for the CSRF token in case the application returns HTML or other responses that could be vulnerable to BREACH without your knowledge.spring-doc.cn
BREACH protection works to protect the token when it is included in a response body that can be GZIP compressed, which generally does not include headers and cookies.spring-doc.cn
Any token value returned by the server can be used successfully by the client-side application because the underlying (raw) CSRF token does not change. It is not required for an AngularJS (or similar) application to refresh the CSRF token before/after every request.spring-doc.cn
If you simply wish to opt out of CSRF BREACH protection altogether, that option is listed next.spring-doc.cn
I need to opt out of CSRF BREACH protection for another reason
If CSRF BREACH protection does not work for you for another reason, you can opt out using the configuration from the Defer Loading CsrfToken section.spring-doc.cn
CSRF BREACH with WebSocket support
If the steps for Protect against CSRF BREACH work for normal HTTP requests and you are using WebSocket Security support, then you can also opt into Spring Security 6’s default support for BREACH protection of the CsrfToken with Stomp headers.spring-doc.cn
WebSocket Security BREACH Protection
ChannelInterceptor csrfChannelInterceptor() {
	return new XorCsrfChannelInterceptor();
open fun csrfChannelInterceptor(): ChannelInterceptor {
	return XorCsrfChannelInterceptor()
<b:bean id="csrfChannelInterceptor"
	class="org.springframework.security.messaging.web.csrf.XorCsrfChannelInterceptor"/>
If configuring CSRF BREACH protection for WebSocket Security gives you trouble, you can configure the 5.8 default using the following configuration:spring-doc.cn
Configure WebSocket Security with 5.8 default
	return new CsrfChannelInterceptor();
	return CsrfChannelInterceptor()
	class="org.springframework.security.messaging.web.csrf.CsrfChannelInterceptor"/>
