对于最新的稳定版本,请使用 Spring for Apache Kafka 3.2.1
有几种技术可用于在运行时创建侦听器容器。 本节将探讨其中的一些技术。
MessageListener 实现
如果直接实现自己的侦听器,则只需使用容器工厂即可为该侦听器创建原始容器:
用户侦听器
  • Java
  • Kotlin
public class MyListener implements MessageListener<String, String> {
    public void onMessage(ConsumerRecord<String, String> data) {
private ConcurrentMessageListenerContainer<String, String> createContainer(
        ConcurrentKafkaListenerContainerFactory<String, String> factory, String topic, String group) {
    ConcurrentMessageListenerContainer<String, String> container = factory.createContainer(topic);
    container.getContainerProperties().setMessageListener(new MyListener());
    container.getContainerProperties().setGroupId(group);
    container.setBeanName(group);
    container.start();
    return container;
class MyListener : MessageListener<String?, String?> {
    override fun onMessage(data: ConsumerRecord<String?, String?>) {
private fun createContainer(
    factory: ConcurrentKafkaListenerContainerFactory<String, String>, topic: String, group: String
): ConcurrentMessageListenerContainer<String, String> {
    val container = factory.createContainer(topic)
    container.containerProperties.messageListener = MyListener()
    container.containerProperties.groupId = group
    container.beanName = group
    container.start()
    return container
原型豆
可以通过将 Bean 声明为 prototype 来动态创建带有注释的方法的容器:@KafkaListener
原型
  • Java
  • Kotlin
public class MyPojo {
    private final String id;
    private final String topic;
    public MyPojo(String id, String topic) {
        this.id = id;
        this.topic = topic;
    public String getId() {
        return this.id;
    public String getTopic() {
        return this.topic;
    @KafkaListener(id = "#{__listener.id}", topics = "#{__listener.topic}")
    public void listen(String in) {
        System.out.println(in);
@Scope(ConfigurableBeanFactory.SCOPE_PROTOTYPE)
MyPojo pojo(String id, String topic) {
    return new MyPojo(id, topic);
applicationContext.getBean(MyPojo.class, "one", "topic2");
applicationContext.getBean(MyPojo.class, "two", "topic3");
class MyPojo(id: String?, topic: String?) {
    @KafkaListener(id = "#{__listener.id}", topics = ["#{__listener.topics}"])
    fun listen(`in`: String?) {
        println(`in`)
fun pojo(id: String?, topic: String?): MyPojo {
    return MyPojo(id, topic)
applicationContext.getBean(MyPojo::class.java, "one", arrayOf("topic2"))
applicationContext.getBean(MyPojo::class.java, "two", arrayOf("topic3"))
侦听器必须具有唯一的 ID。 从版本 2.8.9 开始,有一个新方法允许您重复使用 id。 取消注册容器不会取消容器,您必须自己执行此操作。KafkaListenerEndpointRegistryunregisterListenerContainer(String id)stop()
