For the latest stable version, please use Spring for Apache Kafka 3.3.6!spring-doc.cn
Accessing Delivery Attempts
To access blocking and non-blocking delivery attempts, add these headers to your @KafkaListener method signature:spring-doc.cn
@Header(KafkaHeaders.DELIVERY_ATTEMPT) int blockingAttempts,
@Header(name = RetryTopicHeaders.DEFAULT_HEADER_ATTEMPTS, required = false) Integer nonBlockingAttempts
Blocking delivery attempts are only provided if you set ContainerProperties's deliveryAttemptHeader to true.spring-doc.cn
Note that the non blocking attempts will be null for the initial delivery.spring-doc.cn
Starting with version 3.0.10, a convenient KafkaMessageHeaderAccessor is provided to allow simpler access to these headers; the accessor can be provided as a parameter for the listener method:spring-doc.cn
@RetryableTopic(backoff = @Backoff(...))
@KafkaListener(id = "dh1", topics = "dh1")
void listen(Thing thing, KafkaMessageHeaderAccessor accessor) {
Use accessor.getBlockingRetryDeliveryAttempt() and accessor.getNonBlockingRetryDeliveryAttempt() to get the values. The accessor will throw an IllegalStateException if blocking retries are not enabled; for non-blocking retries, the accessor returns 1 for the initial delivery.spring-doc.cn
