For the latest stable version, please use Spring for Apache Kafka 3.3.6! |
Pausing and Resuming Partitions on Listener Containers
Since version 2.7 you can pause and resume the consumption of specific partitions assigned to that consumer by using the pausePartition(TopicPartition topicPartition)
and resumePartition(TopicPartition topicPartition)
methods in the listener containers.
The pausing and resuming take place respectively before and after the poll()
similar to the pause()
and resume()
methods.
The isPartitionPauseRequested()
method returns true if pause for that partition has been requested.
The isPartitionPaused()
method returns true if that partition has effectively been paused.
Also since version 2.7 ConsumerPartitionPausedEvent
and ConsumerPartitionResumedEvent
instances are published with the container as the source
property and the TopicPartition
instance.
