For the latest stable version, please use Spring for Apache Kafka 3.3.6!spring-doc.cn
Message Listeners
When you use a message listener container, you must provide a listener to receive data. There are currently eight supported interfaces for message listeners. The following listing shows these interfaces:spring-doc.cn
public interface MessageListener<K, V> { (1)
    void onMessage(ConsumerRecord<K, V> data);
public interface AcknowledgingMessageListener<K, V> { (2)
    void onMessage(ConsumerRecord<K, V> data, Acknowledgment acknowledgment);
public interface ConsumerAwareMessageListener<K, V> extends MessageListener<K, V> { (3)
    void onMessage(ConsumerRecord<K, V> data, Consumer<?, ?> consumer);
public interface AcknowledgingConsumerAwareMessageListener<K, V> extends MessageListener<K, V> { (4)
    void onMessage(ConsumerRecord<K, V> data, Acknowledgment acknowledgment, Consumer<?, ?> consumer);
public interface BatchMessageListener<K, V> { (5)
    void onMessage(List<ConsumerRecord<K, V>> data);
public interface BatchAcknowledgingMessageListener<K, V> { (6)
    void onMessage(List<ConsumerRecord<K, V>> data, Acknowledgment acknowledgment);
public interface BatchConsumerAwareMessageListener<K, V> extends BatchMessageListener<K, V> { (7)
    void onMessage(List<ConsumerRecord<K, V>> data, Consumer<?, ?> consumer);
public interface BatchAcknowledgingConsumerAwareMessageListener<K, V> extends BatchMessageListener<K, V> { (8)
    void onMessage(List<ConsumerRecord<K, V>> data, Acknowledgment acknowledgment, Consumer<?, ?> consumer);
1 Use this interface for processing individual ConsumerRecord instances received from the Kafka consumer poll() operation when using auto-commit or one of the container-managed commit methods.
2 Use this interface for processing individual ConsumerRecord instances received from the Kafka consumer poll() operation when using one of the manual commit methods.
3 Use this interface for processing individual ConsumerRecord instances received from the Kafka consumer poll() operation when using auto-commit or one of the container-managed commit methods. Access to the Consumer object is provided.
4 Use this interface for processing individual ConsumerRecord instances received from the Kafka consumer poll() operation when using one of the manual commit methods. Access to the Consumer object is provided.
5 Use this interface for processing all ConsumerRecord instances received from the Kafka consumer poll() operation when using auto-commit or one of the container-managed commit methods. AckMode.RECORD is not supported when you use this interface, since the listener is given the complete batch.
6 Use this interface for processing all ConsumerRecord instances received from the Kafka consumer poll() operation when using one of the manual commit methods.
7 Use this interface for processing all ConsumerRecord instances received from the Kafka consumer poll() operation when using auto-commit or one of the container-managed commit methods. AckMode.RECORD is not supported when you use this interface, since the listener is given the complete batch. Access to the Consumer object is provided.
8 Use this interface for processing all ConsumerRecord instances received from the Kafka consumer poll() operation when using one of the manual commit methods. Access to the Consumer object is provided.
The Consumer object is not thread-safe. You must only invoke its methods on the thread that calls the listener.
You should not execute any Consumer<?, ?> methods that affect the consumer’s positions or committed offsets in your listener; the container needs to manage such information.
