For the latest stable version, please use Spring for Apache Kafka 3.3.6! |
Connecting to Kafka
KafkaAdmin
- see Configuring Topics -
ProducerFactory
- see Sending Messages -
ConsumerFactory
- see Receiving Messages
Starting with version 2.5, each of these extends KafkaResourceFactory
This allows changing the bootstrap servers at runtime by adding a Supplier<String>
to their configuration: setBootstrapServersSupplier(() -> …)
This will be called for all new connections to get the list of servers.
Consumers and Producers are generally long-lived.
To close existing Producers, call reset()
on the DefaultKafkaProducerFactory
To close existing Consumers, call stop()
(and then start()
) on the KafkaListenerEndpointRegistry
and/or stop()
and start()
on any other listener container beans.
For convenience, the framework also provides an ABSwitchCluster
which supports two sets of bootstrap servers; one of which is active at any time.
Configure the ABSwitchCluster
and add it to the producer and consumer factories, and the KafkaAdmin
, by calling setBootstrapServersSupplier()
When you want to switch, call primary()
or secondary()
and call reset()
on the producer factory to establish new connection(s); for consumers, stop()
and start()
all listener containers.
When using @KafkaListener
s, stop()
and start()
bean.
See the Javadocs for more information.
Factory Listeners
Starting with version 2.5, the DefaultKafkaProducerFactory
and DefaultKafkaConsumerFactory
can be configured with a Listener
to receive notifications whenever a producer or consumer is created or closed.
interface Listener<K, V> {
default void producerAdded(String id, Producer<K, V> producer) {
default void producerRemoved(String id, Producer<K, V> producer) {
default void consumerAdded(String id, Consumer<K, V> consumer) {
default void consumerRemoved(String id, Consumer<K, V> consumer) {
In each case, the id
is created by appending the client-id
property (obtained from the metrics()
after creation) to the factory beanName
property, separated by .
These listeners can be used, for example, to create and bind a Micrometer KafkaClientMetrics
instance when a new client is created (and close it when the client is closed).
The framework provides listeners that do exactly that; see Micrometer Native Metrics.
