For the latest stable version, please use Spring for Apache Kafka 3.3.6! |
Accessing Topics' Information at Runtime
Since 2.9, you can access information regarding the topic chain at runtime by injecting the provided DestinationTopicContainer
bean.
This interface provides methods to look up the next topic in the chain or the DLT for a topic if configured, as well as useful properties such as the topic’s name, delay and type.
As a real-world use-case example, you can use such information so a console application can resend a record from the DLT to the first retry topic in the chain after the cause of the failed processing, e.g. bug / inconsistent state, has been resolved.
The DestinationTopic provided by the DestinationTopicContainer#getNextDestinationTopicFor() method corresponds to the next topic registered in the chain for the input topic.
The actual topic the message will be forwarded to may differ due to different factors such as exception classification, number of attempts or single-topic fixed-delay strategies.
Use the DestinationTopicResolver interface if you need to weigh in these factors.
