此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 Spring Framework 6.2.6! |
声明式事务实现示例
请考虑以下接口及其附带的实现。此示例使用Foo
和Bar
类作为占位符,以便您可以专注于事务
使用,而不关注特定的域模型。在本示例中,
事实上,DefaultFooService
类引发UnsupportedOperationException
实例是好的。该行为让您看到
事务创建,然后回滚以响应UnsupportedOperationException
实例。下面的清单显示了FooService
接口:
Java
Kotlin
// the service interface that we want to make transactional
package x.y.service;
public interface FooService {
Foo getFoo(String fooName);
Foo getFoo(String fooName, String barName);
void insertFoo(Foo foo);
void updateFoo(Foo foo);
package x.y.service
fun getFoo(fooName: String): Foo
fun getFoo(fooName: String, barName: String): Foo
fun insertFoo(foo: Foo)
fun updateFoo(foo: Foo)
以下示例显示了上述接口的实现:
Java
Kotlin
public class DefaultFooService implements FooService {
public Foo getFoo(String fooName) {
public Foo getFoo(String fooName, String barName) {
public void insertFoo(Foo foo) {
public void updateFoo(Foo foo) {
package x.y.service
class DefaultFooService : FooService {
override fun getFoo(fooName: String): Foo {
override fun getFoo(fooName: String, barName: String): Foo {
override fun insertFoo(foo: Foo) {
override fun updateFoo(foo: Foo) {
假设FooService
接口getFoo(String)
和getFoo(String, String)
必须在只读的事务上下文中运行
semantics 和其他方法insertFoo(Foo)
和updateFoo(Foo)
必须
在具有读写语义的事务上下文中运行。以下内容
接下来的几段将详细解释配置:
<!-- from the file 'context.xml' -->
xmlns:aop="http://www.springframework.org/schema/aop"
xmlns:tx="http://www.springframework.org/schema/tx"
xsi:schemaLocation="
https://www.springframework.org/schema/tx/spring-tx.xsd
https://www.springframework.org/schema/aop/spring-aop.xsd">
<!-- this is the service object that we want to make transactional -->
<bean id="fooService" class="x.y.service.DefaultFooService"/>
<!-- the transactional advice (what 'happens'; see the <aop:advisor/> bean below) -->
<tx:advice id="txAdvice" transaction-manager="txManager">
<!-- the transactional semantics... -->
<tx:attributes>
<!-- all methods starting with 'get' are read-only -->
<tx:method name="get*" read-only="true"/>
<!-- other methods use the default transaction settings (see below) -->
<tx:method name="*"/>
</tx:attributes>
</tx:advice>
<!-- ensure that the above transactional advice runs for any execution
of an operation defined by the FooService interface -->
<aop:config>
<aop:pointcut id="fooServiceOperation" expression="execution(* x.y.service.FooService.*(..))"/>
<aop:advisor advice-ref="txAdvice" pointcut-ref="fooServiceOperation"/>
</aop:config>
<!-- don't forget the DataSource -->
<bean id="dataSource" class="org.apache.commons.dbcp.BasicDataSource" destroy-method="close">
<property name="driverClassName" value="oracle.jdbc.driver.OracleDriver"/>
<property name="url" value="jdbc:oracle:thin:@rj-t42:1521:elvis"/>
<property name="username" value="scott"/>
<property name="password" value="tiger"/>
</bean>
<!-- similarly, don't forget the TransactionManager -->
<bean id="txManager" class="org.springframework.jdbc.datasource.DataSourceTransactionManager">
<property name="dataSource" ref="dataSource"/>
</bean>
<!-- other <bean/> definitions here -->
</beans>
检查前面的配置。它假定你想创建一个服务对象
这fooService
bean,transactional。要应用的事务语义是封装的
在<tx:advice/>
定义。这<tx:advice/>
定义读作 “所有方法
起始于get
在只读事务的上下文中运行,并且所有
其他方法是使用默认的事务语义运行”。这transaction-manager
属性的<tx:advice/>
标记设置为TransactionManager
bean 来驱动事务(在本例中为txManager
bean) 的 Bean 的
您可以省略transaction-manager 属性
(<tx:advice/> ) 如果TransactionManager 您想要
wire in 的名称为transactionManager .如果TransactionManager bean 那个
you want to wire in 具有任何其他名称,则必须使用transaction-manager 属性,如前面的示例所示。 |
这<aop:config/>
定义确保由txAdvice
Bean 在程序中的适当点运行。首先,定义一个
切入点,该切入点与FooService
接口
(fooServiceOperation
).然后,将切入点与txAdvice
通过使用
顾问。结果表明,在执行fooServiceOperation
由txAdvice
运行。
在<aop:pointcut/>
元素是一个 AspectJ 切入点
表达。有关 pointcut 的更多详细信息,请参阅 AOP 部分
表达式。
一个常见的要求是使整个服务层具有事务性。最好的方法 执行此作是为了更改切入点表达式以匹配 service 层。以下示例显示了如何执行此作:
<aop:config>
<aop:pointcut id="fooServiceMethods" expression="execution(* x.y.service.*.*(..))"/>
<aop:advisor advice-ref="txAdvice" pointcut-ref="fooServiceMethods"/>
</aop:config>
在前面的示例中,假定所有服务接口都已定义
在x.y.service 包。有关更多详细信息,请参阅 AOP 部分。 |
现在我们已经分析了配置,您可能会问自己, “所有这些配置实际上是做什么的?”
前面显示的配置用于围绕对象创建事务代理
,它是从fooService
bean 定义。代理配置了
事务性通知,以便在代理上调用适当的方法时,
事务被启动、暂停、标记为只读等,具体取决于
transaction 配置。请考虑以下程序
该测试驱动前面显示的配置:
Java
Kotlin
public final class Boot {
public static void main(final String[] args) throws Exception {
ApplicationContext ctx = new ClassPathXmlApplicationContext("context.xml");
FooService fooService = ctx.getBean(FooService.class);
fooService.insertFoo(new Foo());
import org.springframework.beans.factory.getBean
fun main() {
val ctx = ClassPathXmlApplicationContext("context.xml")
val fooService = ctx.getBean<FooService>("fooService")
fooService.insertFoo(Foo())
运行上述程序的输出应类似于以下内容(Log4J
output 和UnsupportedOperationException
由insertFoo(..)
方法DefaultFooService
class 已被截断以明确):
<!-- the Spring container is starting up... -->
[AspectJInvocationContextExposingAdvisorAutoProxyCreator] - Creating implicit proxy for bean 'fooService' with 0 common interceptors and 1 specific interceptors
<!-- the DefaultFooService is actually proxied -->
[JdkDynamicAopProxy] - Creating JDK dynamic proxy for [x.y.service.DefaultFooService]
<!-- ... the insertFoo(..) method is now being invoked on the proxy -->
[TransactionInterceptor] - Getting transaction for x.y.service.FooService.insertFoo
<!-- the transactional advice kicks in here... -->
[DataSourceTransactionManager] - Creating new transaction with name [x.y.service.FooService.insertFoo]
[DataSourceTransactionManager] - Acquired Connection [org.apache.commons.dbcp.PoolableConnection@a53de4] for JDBC transaction
<!-- the insertFoo(..) method from DefaultFooService throws an exception... -->
[RuleBasedTransactionAttribute] - Applying rules to determine whether transaction should rollback on java.lang.UnsupportedOperationException
[TransactionInterceptor] - Invoking rollback for transaction on x.y.service.FooService.insertFoo due to throwable [java.lang.UnsupportedOperationException]
<!-- and the transaction is rolled back (by default, RuntimeException instances cause rollback) -->
[DataSourceTransactionManager] - Rolling back JDBC transaction on Connection [org.apache.commons.dbcp.PoolableConnection@a53de4]
[DataSourceTransactionManager] - Releasing JDBC Connection after transaction
[DataSourceUtils] - Returning JDBC Connection to DataSource
Exception in thread "main" java.lang.UnsupportedOperationException at x.y.service.DefaultFooService.insertFoo(DefaultFooService.java:14)
<!-- AOP infrastructure stack trace elements removed for clarity -->
at $Proxy0.insertFoo(Unknown Source)
at Boot.main(Boot.java:11)
要使用响应式事务管理,代码必须使用响应式类型。
Spring Framework 使用ReactiveAdapterRegistry 确定方法
return 类型是 Reactive。 |
下面的清单显示了以前使用的FooService
但
这次代码使用了响应式类型:
Java
Kotlin
// the reactive service interface that we want to make transactional
Flux<Foo> getFoo(String fooName);
Publisher<Foo> getFoo(String fooName, String barName);
Mono<Void> insertFoo(Foo foo);
Mono<Void> updateFoo(Foo foo);
package x.y.service
fun getFoo(fooName: String): Flow<Foo>
fun getFoo(fooName: String, barName: String): Publisher<Foo>
fun insertFoo(foo: Foo) : Mono<Void>
fun updateFoo(foo: Foo) : Mono<Void>
以下示例显示了上述接口的实现:
Java
Kotlin
public Flux<Foo> getFoo(String fooName) {
public Publisher<Foo> getFoo(String fooName, String barName) {
public Mono<Void> insertFoo(Foo foo) {
public Mono<Void> updateFoo(Foo foo) {
package x.y.service
override fun getFoo(fooName: String): Flow<Foo> {
override fun getFoo(fooName: String, barName: String): Publisher<Foo> {
override fun insertFoo(foo: Foo): Mono<Void> {
override fun updateFoo(foo: Foo): Mono<Void> {
命令式事务管理和响应式事务管理共享相同的事务语义
boundary 和 transaction 属性定义。命令式
而 reactive transactions 是后者的 delayend 性质。TransactionInterceptor
使用事务运算符装饰返回的响应式类型以开始和清理
交易。因此,调用事务响应式方法会延迟实际的
transaction management 添加到一个订阅类型中,该订阅类型激活了 Reactive
类型。
响应式事务管理的另一个方面与数据转义有关,它是一个 编程模型的自然结果。
命令式事务的方法返回值是从事务性方法返回的 成功终止方法时,以便部分计算的结果不会转义 方法闭包。
响应式事务方法返回一个响应式包装器类型,它表示一个 计算序列以及开始和完成计算的 Promise。
一个Publisher
可以在事务正在进行但不一定完成时发出数据。
因此,依赖于成功完成整个事务的方法需要
以确保 completion 和 buffer 结果在调用代码中。
