For the latest stable version, please use Spring Data Elasticsearch 5.4.5!spring-doc.cn
Upgrading from 5.2.x to 5.3.x
This section describes breaking changes from version 5.2.x to 5.3.x and how removed features can be replaced by new introduced features.spring-doc.cn
Breaking Changes
During the parameter replacement in @Query annotated repository methods previous versions wrote the String "null" into the query that was sent to Elasticsearch when the actual parameter value was null. As Elasticsearch does not store null values, this behaviour could lead to problems, for example whent the fields to be searched contains the string "null". In Version 5.3 a null value in a parameter will cause a ConversionException to be thrown. If you are using "null" as the null_value defined in a field mapping, then pass that string into the query instead of a Java null.spring-doc.cn
Deprecations
Removals
The deprecated classes org.springframework.data.elasticsearch.ELCQueries and org.springframework.data.elasticsearch.client.elc.QueryBuilders have been removed, use org.springframework.data.elasticsearch.client.elc.Queries instead.spring-doc.cn
