For the latest stable version, please use Spring Data Elasticsearch 5.4.5!spring-doc.cn
CDI Integration
The Spring Data Elasticsearch repositories can also be set up using CDI functionality.spring-doc.cn
Example 1. Spring Data Elasticsearch repositories using CDI
class ElasticsearchTemplateProducer {
  @Produces
  @ApplicationScoped
  public ElasticsearchOperations createElasticsearchTemplate() {
    // ...                               (1)
class ProductService {
  private ProductRepository repository;  (2)
  public Page<Product> findAvailableBookByName(String name, Pageable pageable) {
    return repository.findByAvailableTrueAndNameStartingWith(name, pageable);
  @Inject
  public void setRepository(ProductRepository repository) {
    this.repository = repository;
1 Create a component by using the same calls as are used in the Elasticsearch Operations chapter.
2 Let the CDI framework inject the Repository into your class.
