For the latest stable version, please use Spring Data Elasticsearch 5.4.5!spring-doc.cn
Reactive Elasticsearch Repositories
Reactive Elasticsearch repository support builds on the core repository support explained in Repositories utilizing operations provided via Reactive Elasticsearch Operations executed by a Reactive REST Client.spring-doc.cn
Spring Data Elasticsearch reactive repository support uses Project Reactor as its reactive composition library of choice.spring-doc.cn
There are 3 main interfaces to be used:spring-doc.cn
Usage
To access domain objects stored in a Elasticsearch using a Repository, just create an interface for it. Before you can actually go on and do that you will need an entity.spring-doc.cn
Example 1. Sample Person entity
public class Person {
  @Id
  private String id;
  private String firstname;
  private String lastname;
  private Address address;
  // … getters and setters omitted
Please note that the id property needs to be of type String.
Example 2. Basic repository interface to persist Person entities
interface ReactivePersonRepository extends ReactiveSortingRepository<Person, String> {
  Flux<Person> findByFirstname(String firstname);                                   (1)
  Flux<Person> findByFirstname(Publisher<String> firstname);                        (2)
  Flux<Person> findByFirstnameOrderByLastname(String firstname);                    (3)
  Flux<Person> findByFirstname(String firstname, Sort sort);                        (4)
  Flux<Person> findByFirstname(String firstname, Pageable page);                    (5)
  Mono<Person> findByFirstnameAndLastname(String firstname, String lastname);       (6)
  Mono<Person> findFirstByLastname(String lastname);                                (7)
  @Query("{ \"bool\" : { \"must\" : { \"term\" : { \"lastname\" : \"?0\" } } } }")
  Flux<Person> findByLastname(String lastname);                                     (8)
  Mono<Long> countByFirstname(String firstname)                                     (9)
  Mono<Boolean> existsByFirstname(String firstname)                                 (10)
  Mono<Long> deleteByFirstname(String firstname)                                    (11)
1 The method shows a query for all people with the given lastname.
2 Finder method awaiting input from Publisher to bind parameter value for firstname.
3 Finder method ordering matching documents by lastname.
4 Finder method ordering matching documents by the expression defined via the Sort parameter.
5 Use Pageable to pass offset and sorting parameters to the database.
6 Finder method concating criteria using And / Or keywords.
7 Find the first matching entity.
8 The method shows a query for all people with the given lastname looked up by running the annotated @Query with given parameters.
9 Count all entities with matching firstname.
10 Check if at least one entity with matching firstname exists.
11 Delete all entities with matching firstname.
Configuration
For Java configuration, use the @EnableReactiveElasticsearchRepositories annotation. If no base package is configured, the infrastructure scans the package of the annotated configuration class.spring-doc.cn
The following listing shows how to use Java configuration for a repository:spring-doc.cn
Example 3. Java configuration for repositories
public class Config extends AbstractReactiveElasticsearchConfiguration {
  public ReactiveElasticsearchClient reactiveElasticsearchClient() {
    return ReactiveRestClients.create(ClientConfiguration.localhost());
Because the repository from the previous example extends ReactiveSortingRepository, all CRUD operations are available as well as methods for sorted access to the entities. Working with the repository instance is a matter of dependency injecting it into a client, as the following example shows:spring-doc.cn
Example 4. Sorted access to Person entities
public class PersonRepositoryTests {
  @Autowired ReactivePersonRepository repository;
  @Test
  public void sortsElementsCorrectly() {
    Flux<Person> persons = repository.findAll(Sort.by(new Order(ASC, "lastname")));
