For the latest stable version, please use Spring Data Elasticsearch 5.4.5! |
Elasticsearch Repositories
This chapter includes details of the Elasticsearch repository implementation.
Book
entity@Document(indexName="books")
class Book {
@Id
private String id;
@Field(type = FieldType.Text)
private String name;
private String summary;
@Field(type = FieldType.Integer)
private Integer price;
// getter/setter ...
Automatic creation of indices with the corresponding mapping
The @Document
annotation has an argument createIndex
If this argument is set to true - which is the default value - Spring Data Elasticsearch will during bootstrapping the repository support on application startup check if the index defined by the @Document
annotation exists.
If it does not exist, the index will be created and the mappings derived from the entity’s annotations (see Elasticsearch Object Mapping) will be written to the newly created index.
Details of the index that will be created can be set by using the @Setting
annotation, refer to Index settings for further information.
Annotations for repository methods
@Highlight
The @Highlight
annotation on a repository method defines for which fields of the returned entity highlighting should be included.To search for some text in a Book
's name or summary and have the found data highlighted, the following repository method can be used:
interface BookRepository extends Repository<Book, String> {
@Highlight(fields = {
@HighlightField(name = "name"),
@HighlightField(name = "summary")
SearchHits<Book> findByNameOrSummary(String text, String summary);
It is possible to define multiple fields to be highlighted like above, and both the @Highlight
and the @HighlightField
annotation can further be customized with a @HighlightParameters
annotation. Check the Javadocs for the possible configuration options.
In the search results the highlight data can be retrieved from the SearchHit
class.
@SourceFilters
Sometimes the user does not need to have all the properties of an entity returned from a search but only a subset. Elasticsearch provides source filtering to reduce the amount of data that is transferred across the network to the application.
When working with Query
implementations and the ElasticsearchOperations
this is easily possible by setting a
source filter on the query.
When using repository methods there is the @SourceFilters
annotation:
@SourceFilters(includes = "name")
SearchHits<Book> findByName(String text);
In this example, all the properties of the returned Book
objects would be null
except the name.
Annotation based configuration
The Spring Data Elasticsearch repositories support can be activated using an annotation through JavaConfig.
@EnableElasticsearchRepositories( (1)
basePackages = "org.springframework.data.elasticsearch.repositories"
static class Config {
public ElasticsearchOperations elasticsearchTemplate() { (2)
class ProductService {
private ProductRepository repository; (3)
public ProductService(ProductRepository repository) {
this.repository = repository;
public Page<Product> findAvailableBookByName(String name, Pageable pageable) {
return repository.findByAvailableTrueAndNameStartingWith(name, pageable);
1 | The EnableElasticsearchRepositories annotation activates the Repository support.
If no base package is configured, it will use the one of the configuration class it is put on. |
2 | Provide a Bean named elasticsearchTemplate of type ElasticsearchOperations by using one of the configurations shown in the Elasticsearch Operations chapter. |
3 | Let Spring inject the Repository bean into your class. |
Spring Namespace
The Spring Data Elasticsearch module contains a custom namespace allowing definition of repository beans as well as elements for instantiating a ElasticsearchServer
Using the repositories
element looks up Spring Data repositories as described in Creating Repository Instances.
xmlns:elasticsearch="http://www.springframework.org/schema/data/elasticsearch"
https://www.springframework.org/schema/beans/spring-beans-3.1.xsd
https://www.springframework.org/schema/data/elasticsearch/spring-elasticsearch-1.0.xsd">
<elasticsearch:repositories base-package="com.acme.repositories" />
</beans>
Using the Transport Client
or Rest Client
element registers an instance of Elasticsearch Server
in the context.
<elasticsearch:transport-client id="client" cluster-nodes="localhost:9300,someip:9300" />
</beans>
xsi:schemaLocation="http://www.springframework.org/schema/data/elasticsearch
https://www.springframework.org/schema/data/elasticsearch/spring-elasticsearch.xsd
https://www.springframework.org/schema/beans/spring-beans.xsd">
<elasticsearch:rest-client id="restClient" hosts="http://localhost:9200">
</beans>
