For the latest stable version, please use Spring Data Elasticsearch 5.4.5!spring-doc.cn
Upgrading Spring Data
Instructions for how to upgrade from earlier versions of Spring Data are provided on the project wiki. Follow the links in the release notes section to find the version that you want to upgrade to.spring-doc.cn
Upgrading instructions are always the first item in the release notes. If you are more than one release behind, please make sure that you also review the release notes of the versions that you jumped.spring-doc.cn
