For the latest stable version, please use Spring Data Elasticsearch 5.4.5!spring-doc.cn
Reactive Elasticsearch Operations
ReactiveElasticsearchOperations is the gateway to executing high level commands against an Elasticsearch cluster using the ReactiveElasticsearchClient.spring-doc.cn
The ReactiveElasticsearchTemplate is the default implementation of ReactiveElasticsearchOperations.spring-doc.cn
To get started the ReactiveElasticsearchOperations needs to know about the actual client to work with. Please see Reactive Rest Client for details on the client and how to configure it.spring-doc.cn
Reactive Operations Usage
ReactiveElasticsearchOperations lets you save, find and delete your domain objects and map those objects to documents stored in Elasticsearch.spring-doc.cn
Consider the following:spring-doc.cn
Example 1. Use the ReactiveElasticsearchOperations
@Document(indexName = "marvel")
public class Person {
  private @Id String id;
  private String name;
  private int age;
  // Getter/Setter omitted...
ReactiveElasticsearchOperations operations;
operations.save(new Person("Bruce Banner", 42))                    (1)
  .doOnNext(System.out::println)
  .flatMap(person -> operations.get(person.id, Person.class))      (2)
  .flatMap(person -> operations.delete(person))                    (3)
  .flatMap(id -> operations.count(Person.class))                   (4)
  .subscribe();                                                    (5)
The above outputs the following sequence on the console.spring-doc.cn
> Person(id=QjWCWWcBXiLAnp77ksfR, name=Bruce Banner, age=42)
> 0
1 Insert a new Person document into the marvel index . The id is generated on server side and set into the instance returned.
2 Lookup the Person with matching id in the marvel index.
3 Delete the Person with matching id, extracted from the given instance, in the marvel index.
4 Count the total number of documents in the marvel index.
5 Don’t forget to subscribe().
