For the latest stable version, please use Spring Cloud Kubernetes 3.2.0!spring-doc.cn
Spring Cloud Kubernetes Config Server
The Spring Cloud Kubernetes Config Server, is based on Spring Cloud Config Server and adds an environment repository for Kubernetes Config Maps and Secrets.spring-doc.cn
This is component is completely optional. However, it allows you to continue to leverage configuration you may have stored in existing environment repositories (Git, SVN, Vault, etc) with applications that you are running on Kubernetes.spring-doc.cn
A default image is located on Docker Hub which will allow you to easily get a Config Server deployed on Kubernetes without building the code and image yourself. However, if you need to customize the config server behavior or prefer to build the image yourself you can easily build your own image from the source code on GitHub and use that.spring-doc.cn
Configuration
Enabling The Kubernetes Environment Repository
To enable the Kubernetes environment repository the kubernetes profile must be included in the list of active profiles. You may activate other profiles as well to use other environment repository implementations.spring-doc.cn
Config Map and Secret PropertySources
By default, only Config Map data will be fetched. To enable Secrets as well you will need to set spring.cloud.kubernetes.secrets.enableApi=true. You can disable the Config Map PropertySource by setting spring.cloud.kubernetes.config.enableApi=false.spring-doc.cn
Fetching Config Map and Secret Data From Additional Namespaces
By default, the Kubernetes environment repository will only fetch Config Map and Secrets from the namespace in which it is deployed. If you want to include data from other namespaces you can set spring.cloud.kubernetes.configserver.config-map-namespaces and/or spring.cloud.kubernetes.configserver.secrets-namespaces to a comma separated list of namespace values.spring-doc.cn
If you set spring.cloud.kubernetes.configserver.config-map-namespaces and/or spring.cloud.kubernetes.configserver.secrets-namespaces you will need to include the namespace in which the Config Server is deployed in order to continue to fetch Config Map and Secret data from that namespace.
Kubernetes Access Controls
The Kubernetes Config Server uses the Kubernetes API server to fetch Config Map and Secret data. In order for it to do that it needs ability to get and list Config Map and Secrets (depending on what you enable/disable).spring-doc.cn
Deployment Yaml
Below is a sample deployment, service and permissions configuration you can use to deploy a basic Config Server to Kubernetes.spring-doc.cn
apiVersion: v1
kind: List
items:
  - apiVersion: v1
    kind: Service
    metadata:
      labels:
        app: spring-cloud-kubernetes-configserver
    spec:
      ports:
        - name: http
          port: 8888
          targetPort: 8888
      selector:
      type: ClusterIP
  - apiVersion: v1
    kind: ServiceAccount
    metadata:
      labels:
  - apiVersion: rbac.authorization.k8s.io/v1
    kind: RoleBinding
    metadata:
      labels:
    roleRef:
      kind: Role
      apiGroup: rbac.authorization.k8s.io
    subjects:
      - kind: ServiceAccount
    kind: Role
    metadata:
      namespace: default
    rules:
      - apiGroups: ["", "extensions", "apps"]
        resources: ["configmaps", "secrets"]
        verbs: ["get", "list"]
  - apiVersion: apps/v1
    kind: Deployment
    metadata:
    spec:
      selector:
        matchLabels:
      template:
        metadata:
          labels:
        spec:
          serviceAccount: spring-cloud-kubernetes-configserver
          containers:
          - name: spring-cloud-kubernetes-configserver
            image: springcloud/spring-cloud-kubernetes-configserver
            imagePullPolicy: IfNotPresent
            env:
                - name: SPRING_PROFILES_INCLUDE
                  value: "kubernetes"
            readinessProbe:
              httpGet:
                port: 8888
                path: /actuator/health/readiness
            livenessProbe:
              httpGet:
                port: 8888
                path: /actuator/health/liveness
            ports:
            - containerPort: 8888
