For the latest stable version, please use Spring Cloud Kubernetes 3.2.0!spring-doc.cn
Kubernetes PropertySource implementations
The most common approach to configuring your Spring Boot application is to create an application.properties or application.yaml or an application-profile.properties or application-profile.yaml file that contains key-value pairs that provide customization values to your application or Spring Boot starters. You can override these properties by specifying system properties or environment variables.spring-doc.cn
To enable this functionality you need to set the spring.config.import application configuration property to kubernetes: (escape with quotes when using yaml eg. "kubernetes:"). Currently you can not specify a ConfigMap or Secret to load using spring.config.import, by default Spring Cloud Kubernetes will load a ConfigMap and/or Secret based on the spring.application.name property. If spring.application.name is not set it will load a ConfigMap and/or Secret with the name application.spring-doc.cn
If you would like to load Kubernetes PropertySources during the bootstrap phase like it worked prior to the 3.0.x release you can either add spring-cloud-starter-bootstrap to your application’s classpath or set spring.cloud.bootstrap.enabled=true as an environment variable.spring-doc.cn
It is not supported to load properties during Bootstrap (using spring-cloud-starter-bootstrap or spring.cloud.bootstrap.enabled=true and load properties using spring.config.import. You must use one or the other method.
