For the latest stable version, please use Spring Cloud Kubernetes 3.2.0!spring-doc.cn
Info Contributor
Spring Cloud Kubernetes includes an InfoContributor which adds Pod information to Spring Boot’s /info Actuator endpoint.spring-doc.cn
You can disable this InfoContributor by setting management.info.kubernetes.enabled to false in application.[properties | yaml].spring-doc.cn
