For the latest stable version, please use Spring Cloud Kubernetes 3.2.0!spring-doc.cn
Starters
Starters are convenient dependency descriptors you can include in your application. Include a starter to get the dependencies and Spring Boot auto-configuration for a feature set. Starters that begin with spring-cloud-starter-kubernetes-fabric8 provide implementations using the Fabric8 Kubernetes Java Client. Starters that begin with spring-cloud-starter-kubernetes-client provide implementations using the Kubernetes Java Client.spring-doc.cn
You CANNOT combine starters from Fabric8 and Kubernetes Java Clients. You must pick one library to use and use the starters for that library only.
Starter Features
Fabric8 Dependency
<dependency>
    <artifactId>spring-cloud-starter-kubernetes-fabric8</artifactId>
</dependency>
Kubernetes Client Dependency
<dependency>
    <artifactId>spring-cloud-starter-kubernetes-client</artifactId>
</dependency>
Discovery Client implementation that resolves service names to Kubernetes Services.spring-doc.cn
Fabric8 Dependency
<dependency>
    <artifactId>spring-cloud-starter-kubernetes-fabric8-config</artifactId>
</dependency>
<dependency>
    <artifactId>spring-cloud-starter-kubernetes-client-config</artifactId>
</dependency>
Load application properties from Kubernetes ConfigMaps and Secrets. Reload application properties when a ConfigMap or Secret changes.spring-doc.cn
Fabric8 Dependency
<dependency>
    <artifactId>spring-cloud-starter-kubernetes-fabric8-all</artifactId>
</dependency>
<dependency>
    <artifactId>spring-cloud-starter-kubernetes-client-all</artifactId>
</dependency>
All Spring Cloud Kubernetes features.spring-doc.cn
