For the latest stable version, please use Spring Cloud Kubernetes 3.2.0!spring-doc.cn
Namespace resolution
Finding an application namespace happens on a best-effort basis. There are some steps that we iterate in order to find it. The easiest and most common one, is to specify it in the proper configuration, for example:spring-doc.cn
spring:
  application:
  cloud:
    kubernetes:
      secrets:
        namespace: default
        sources:
         # Spring Cloud Kubernetes looks up a Secret named 'a' in namespace 'default'
         - name: a
         # Spring Cloud Kubernetes looks up a Secret named 'secret' in namespace 'b'
         - namespace: b
         # Spring Cloud Kubernetes looks up a Secret named 'd' in namespace 'c'
         - namespace: c
Remember that the same can be done for config maps. If such a namespace is not specified, it will be read (in this order):spring-doc.cn
  1. from property spring.cloud.kubernetes.client.namespacespring-doc.cn
  2. from a String residing in a file denoted by spring.cloud.kubernetes.client.serviceAccountNamespacePath propertyspring-doc.cn
  3. from a String residing in /var/run/secrets/kubernetes.io/serviceaccount/namespace file (kubernetes default namespace path)spring-doc.cn
  4. from a designated client method call (for example fabric8’s : KubernetesClient::getNamespace), if the client provides such a method. This, in turn, could be configured via environment properties. For example fabric8 client can be configured via "KUBERNETES_NAMESPACE" property; consult the client documentation for exact details.spring-doc.cn
Failure to find a namespace from the above steps will result in an Exception being raised.spring-doc.cn
