For the latest stable version, please use Spring Cloud Kubernetes 3.2.0!spring-doc.cn
Order of ConfigMaps and Secrets
If, for whatever reason, you enabled both configmaps and secrets, and there is a common property between them, the value from the ConfigMap will have a higher precedence. That is: it will override whatever values are found in secrets.spring-doc.cn
