对于最新的稳定版本,请使用 spring-cloud-contract 4.2.1! |
合约 DSL
Spring Cloud Contract 支持以下语言编写的 DSL:
槽的
YAML
Java
Kotlin
Spring Cloud Contract 支持在单个文件中定义多个 Contract (在 Groovy 中返回一个列表而不是单个 Contract )。 |
以下示例显示了 Contract 定义:
org.springframework.cloud.contract.spec.Contract.make {
request {
method 'PUT'
url '/api/12'
headers {
header 'Content-Type': 'application/vnd.org.springframework.cloud.contract.verifier.twitter-places-analyzer.v1+json'
body '''\
"created_at": "Sat Jul 26 09:38:57 +0000 2014",
"id": 492967299297845248,
"id_str": "492967299297845248",
"text": "Gonna see you at Warsaw",
"place":
"attributes":{},
"bounding_box":
"coordinates":
[-77.119759,38.791645],
[-76.909393,38.791645],
[-76.909393,38.995548],
[-77.119759,38.995548]
"type":"Polygon"
"country":"United States",
"country_code":"US",
"full_name":"Washington, DC",
"id":"01fbe706f872cb32",
"name":"Washington",
"place_type":"city",
"url": "https://api.twitter.com/1/geo/id/01fbe706f872cb32.json"
response {
status OK()
description: Some description
priority: 8
ignored: true
request:
url: /foo
queryParameters:
a: b
b: c
method: PUT
headers:
foo: bar
fooReq: baz
body:
foo: bar
matchers:
body:
- path: $.foo
type: by_regex
value: bar
headers:
- key: foo
regex: bar
response:
status: 200
headers:
foo2: bar
foo3: foo33
fooRes: baz
body:
foo2: bar
foo3: baz
nullValue: null
matchers:
body:
- path: $.foo2
type: by_regex
value: bar
- path: $.foo3
type: by_command
value: executeMe($it)
- path: $.nullValue
type: by_null
value: null
headers:
- key: foo2
regex: bar
- key: foo3
command: andMeToo($it)
import java.util.Collection;
import java.util.Collections;
import java.util.function.Supplier;
import org.springframework.cloud.contract.spec.Contract;
import org.springframework.cloud.contract.verifier.util.ContractVerifierUtil;
class contract_rest implements Supplier<Collection<Contract>> {
public Collection<Contract> get() {
return Collections.singletonList(Contract.make(c -> {
c.description("Some description");
c.name("some name");
c.priority(8);
c.ignored();
c.request(r -> {
r.url("/foo", u -> {
u.queryParameters(q -> {
q.parameter("a", "b");
q.parameter("b", "c");
r.method(r.PUT());
r.headers(h -> {
h.header("foo", r.value(r.client(r.regex("bar")), r.server("bar")));
h.header("fooReq", "baz");
r.body(ContractVerifierUtil.map().entry("foo", "bar"));
r.bodyMatchers(m -> {
m.jsonPath("$.foo", m.byRegex("bar"));
c.response(r -> {
r.fixedDelayMilliseconds(1000);
r.status(r.OK());
r.headers(h -> {
h.header("foo2", r.value(r.server(r.regex("bar")), r.client("bar")));
h.header("foo3", r.value(r.server(r.execute("andMeToo($it)")), r.client("foo33")));
h.header("fooRes", "baz");
r.body(ContractVerifierUtil.map().entry("foo2", "bar").entry("foo3", "baz").entry("nullValue", null));
m.jsonPath("$.foo2", m.byRegex("bar"));
m.jsonPath("$.foo3", m.byCommand("executeMe($it)"));
m.jsonPath("$.nullValue", m.byNull());
import org.springframework.cloud.contract.spec.ContractDsl.Companion.contract
import org.springframework.cloud.contract.spec.withQueryParameters
contract {
name = "some name"
description = "Some description"
priority = 8
ignored = true
request {
url = url("/foo") withQueryParameters {
parameter("a", "b")
parameter("b", "c")
method = PUT
headers {
header("foo", value(client(regex("bar")), server("bar")))
body = body(mapOf("foo" to "bar"))
bodyMatchers {
jsonPath("$.foo", byRegex("bar"))
response {
delay = fixedMilliseconds(1000)
status = OK
headers {
header("foo2", value(server(regex("bar")), client("bar")))
header("foo3", value(server(execute("andMeToo(\$it)")), client("foo33")))
body = body(mapOf(
"foo" to "bar",
"foo3" to "baz",
"nullValue" to null
bodyMatchers {
jsonPath("$.foo2", byRegex("bar"))
jsonPath("$.foo3", byCommand("executeMe(\$it)"))
jsonPath("$.nullValue", byNull)
您可以使用以下独立的 Maven 命令将合同编译为存根映射: mvn org.springframework.cloud:spring-cloud-contract-maven-plugin:convert |
Groovy 中的 Contract DSL
如果您不熟悉 Groovy,请不要担心。您可以在 Groovy DSL 文件。
如果您决定用 Groovy 编写合约,如果您还没有使用 Groovy,请不要惊慌 以前。实际上并不需要了解该语言,因为 Contract DSL 只使用 它的一小部分(仅 Literals、Method Calls 和 Closure)。此外,DSL 是静态的 typed,使其无需任何 DSL 本身知识即可程序员可读。
请记住,在 Groovy 合约文件中,您必须提供完整的
限定名称设置为Contract class 和make static imports(例如org.springframework.cloud.spec.Contract.make { … } .您还可以将导入
这Contract 类 (import org.springframework.cloud.spec.Contract ),然后调用Contract.make { … } . |
Java 中的合约 DSL
要在 Java 中编写合约定义,您需要创建一个类,该类实现Supplier<Contract>
interface (对于单个合约)或Supplier<Collection<Contract>>
(对于多个合同)。
您还可以在src/test/java
(例如,src/test/java/contracts
),这样就不必修改项目的 Classpath 了。在这种情况下,您必须为 Spring Cloud Contract 插件提供 Contract 定义的新位置。
以下示例(在 Maven 和 Gradle 中)在src/test/java
<plugin>
<artifactId>spring-cloud-contract-maven-plugin</artifactId>
<version>${spring-cloud-contract.version}</version>
<extensions>true</extensions>
<configuration>
<contractsDirectory>src/test/java/contracts</contractsDirectory>
</configuration>
</plugin>
contracts {
contractsDslDir = new File(project.rootDir, "src/test/java/contracts")
Kotlin 中的合约 DSL
要开始使用 Kotlin 编写合约,您需要从一个(新创建的)Kotlin 脚本文件 (.kts
与 Java DSL 一样,您可以将 Contract 放在您选择的任何目录中。
默认情况下,Maven 插件将查看src/test/resources/contracts
目录和 Gradle 插件将
看看src/contractTest/resources/contracts
目录。
从 3.0.0 开始,Gradle 插件也将查看遗留的
目录src/test/resources/contracts 用于迁移目的。在此目录中找到 Contract 时,会显示一条警告
将在您的构建过程中记录。 |
您需要显式传递spring-cloud-contract-spec-kotlin
依赖项添加到您的项目插件设置中。
以下示例(在 Maven 和 Gradle 中)展示了如何做到这一点:
<plugin>
<configuration>
<!-- some config -->
</configuration>
<dependencies>
<dependency>
<artifactId>spring-cloud-contract-spec-kotlin</artifactId>
</dependency>
</dependencies>
</plugin>
<dependencies>
<!-- Remember to add this for the DSL support in the IDE and on the consumer side -->
<dependency>
<scope>test</scope>
</dependency>
</dependencies>
buildscript {
repositories {
dependencies {
classpath "org.springframework.cloud:spring-cloud-contract-gradle-plugin:$\{scContractVersion}"
dependencies {
// Remember to add this for the DSL support in the IDE and on the consumer side
testImplementation "org.springframework.cloud:spring-cloud-contract-spec-kotlin"
// Kotlin versions are very particular down to the patch version. The <kotlin_version> needs to be the same as you have imported for your project.
testImplementation "org.jetbrains.kotlin:kotlin-scripting-compiler-embeddable:<kotlin_version>"
请记住,在 Kotlin 脚本文件中,您必须为ContractDSL 类。
通常,您将按如下方式使用其 contract 函数:org.springframework.cloud.contract.spec.ContractDsl.contract { … } .
您还可以提供对contract 函数 (import org.springframework.cloud.contract.spec.ContractDsl.Companion.contract ),然后调用contract { … } . |
YAML 中的合约 DSL
要查看 YAML 协定的架构,请访问 YML 架构页面。
局限性
对验证 JSON 数组大小的支持是实验性的。如果需要帮助,
要启用它,请将以下 System 属性的值设置为true :spring.cloud.contract.verifier.assert.size .默认情况下,此功能设置为false .
您还可以设置assertJsonSize 属性。 |
由于 JSON 结构可以具有任何形式,因此可能无法对其进行解析
正确地使用 Groovy DSL 和value(consumer(…), producer(…)) 表示法GString .那
是您应该使用 Groovy Map 表示法的原因。 |
一个文件中的多个合同
您可以在一个文件中定义多个合同。这样的合约可能类似于 以下示例:
Contract.make {
name("should post a user")
request {
method 'POST'
url('/users/1')
response {
status OK()
Contract.make {
request {
method 'POST'
url('/users/2')
response {
status OK()
name: should post a user
request:
method: POST
url: /users/1
response:
status: 200
request:
method: POST
url: /users/2
response:
status: 200
request:
method: POST
url: /users/3
response:
status: 200
class contract implements Supplier<Collection<Contract>> {
return Arrays.asList(
c.name("should post a user");
}), Contract.make(c -> {
arrayOf(
contract {
contract {
contract {
在前面的示例中,一个合约具有name
字段,而另一个则没有。这
导致生成两个测试,如下所示:
import com.example.TestBase;
import com.jayway.jsonpath.DocumentContext;
import com.jayway.jsonpath.JsonPath;
import com.jayway.restassured.module.mockmvc.specification.MockMvcRequestSpecification;
import com.jayway.restassured.response.ResponseOptions;
import org.junit.Test;
import static com.jayway.restassured.module.mockmvc.RestAssuredMockMvc.*;
import static com.toomuchcoding.jsonassert.JsonAssertion.assertThatJson;
import static org.assertj.core.api.Assertions.assertThat;
public class V1Test extends TestBase {
@Test
public void validate_should_post_a_user() throws Exception {
// given:
MockMvcRequestSpecification request = given();
// when:
ResponseOptions response = given().spec(request)
.post("/users/1");
// then:
assertThat(response.statusCode()).isEqualTo(200);
@Test
public void validate_withList_1() throws Exception {
// given:
// when:
.post("/users/2");
// then:
请注意,对于具有name
字段中,生成的测试方法名为validate_should_post_a_user
.没有name
field 调用validate_withList_1
.它对应于文件的名称WithList.groovy
和
列表中合约的索引。
生成的存根如以下示例所示:
should post a user.json
1_WithList.json
第一个文件获取了name
参数。第二个
获取了合约文件的名称 (WithList.groovy
) 前缀为索引(在此
case,则合约的索引为1
在文件的合同列表中)。
为您的合约命名要好得多,因为这样做会使 您的测试更有意义。 |
有状态合约
有状态合同(也称为场景)是应该读取的合同定义 挨次。这在以下情况下可能很有用:
您希望以精确定义的顺序调用合约,因为您使用 Spring Cloud Contract 来测试您的有状态应用程序。
我们真的不鼓励你这样做,因为 Contract 测试应该是无状态的。 |
您希望同一终端节点为同一请求返回不同的结果。
要创建有状态合约(或场景),您需要 在创建合同时使用正确的命名约定。约定 要求包含订单号,后跟下划线。这无论如何都有效 了解您是使用 YAML 还是 Groovy。下面的清单显示了一个示例:
my_contracts_dir\
scenario1\
1_login.groovy
2_showCart.groovy
3_logout.groovy
这样的树会导致 Spring Cloud Contract Verifier 生成 WireMock 的场景,其中包含
名称scenario1
以及以下三个步骤:
login
,标记为Started
指向... -
showCart
,标记为Step1
指向... -
logout
,标记为Step2
(这将关闭方案)。
您可以在 https://wiremock.org/docs/stateful-behaviour/ 中找到有关 WireMock 方案的更多详细信息。
