对于最新的稳定版本,请使用 spring-cloud-contract 4.2.1spring-doc.cadn.net.cn
Maven 项目
添加 Maven 插件
要添加 Spring Cloud Contract BOM,请在pom.xml文件:spring-doc.cadn.net.cn
<dependency>
	<artifactId>spring-cloud-contract-dependencies</artifactId>
	<version>${spring-cloud-contract.version}</version>
	<type>pom</type>
	<scope>import</scope>
</dependency>
接下来,添加Spring Cloud Contract VerifierMaven 插件,如下所示:spring-doc.cadn.net.cn
<plugin>
	<artifactId>spring-cloud-contract-maven-plugin</artifactId>
	<extensions>true</extensions>
	<configuration>
		<packageWithBaseClasses>com.example.fraud</packageWithBaseClasses>
	</configuration>
</plugin>
您可以在 spring-cloud-contract-maven-plugin/index.html[Spring] Cloud Contract Maven Plugin 文档]。spring-doc.cadn.net.cn
有时,无论选择哪种 IDE,您都可以看到target/generated-test-source文件夹在 IDE 的类路径中不可见。为确保它始终存在,您可以将以下条目添加到pom.xmlspring-doc.cadn.net.cn
<plugin>
	<groupId>org.codehaus.mojo</groupId>
	<artifactId>build-helper-maven-plugin</artifactId>
	<executions>
		<execution>
			<id>add-source</id>
			<phase>generate-test-sources</phase>
			<goals>
				<goal>add-test-source</goal>
			</goals>
			<configuration>
				<sources>
					<source>${project.build.directory}/generated-test-sources/contracts/</source>
				</sources>
			</configuration>
		</execution>
	</executions>
</plugin>
Maven 和 Rest Assured 2.0
默认情况下,Rest Assured 3.x 将添加到 Classpath 中。但是,您可以使用 Rest 通过将 2.x 添加到 plugins 类路径来保证 2.x,如下所示:spring-doc.cadn.net.cn
<plugin>
    <configuration>
        <packageWithBaseClasses>com.example</packageWithBaseClasses>
    </configuration>
    <dependencies>
        <dependency>
            <artifactId>spring-cloud-contract-verifier</artifactId>
        </dependency>
        <dependency>
           <groupId>com.jayway.restassured</groupId>
           <artifactId>rest-assured</artifactId>
           <version>2.5.0</version>
           <scope>compile</scope>
        </dependency>
        <dependency>
           <artifactId>spring-mock-mvc</artifactId>
        </dependency>
    </dependencies>
</plugin>
<dependencies>
    <!-- all dependencies -->
    <!-- you can exclude rest-assured from spring-cloud-contract-verifier -->
    <dependency>
       <scope>test</scope>
    </dependency>
    <dependency>
       <scope>test</scope>
    </dependency>
</dependencies>
这样,插件会自动看到 Rest Assured 2.x 存在于 Classpath 中 并相应地修改导入。spring-doc.cadn.net.cn
使用 Maven 的快照版本和里程碑版本
要使用快照和里程碑版本,您必须将以下部分添加到pom.xml:spring-doc.cadn.net.cn
<repositories>
	<repository>
		<id>spring-snapshots</id>
		<name>Spring Snapshots</name>
		<url>https://repo.spring.io/snapshot</url>
		<snapshots>
			<enabled>true</enabled>
		</snapshots>
	</repository>
	<repository>
		<id>spring-milestones</id>
		<name>Spring Milestones</name>
		<url>https://repo.spring.io/milestone</url>
		<snapshots>
			<enabled>false</enabled>
		</snapshots>
	</repository>
</repositories>
<pluginRepositories>
	<pluginRepository>
		<snapshots>
		</snapshots>
	</pluginRepository>
	<pluginRepository>
		<snapshots>
		</snapshots>
	</pluginRepository>
</pluginRepositories>
添加存根
默认情况下, Spring Cloud Contract Verifier 在src/test/resources/contracts目录。包含存根定义的目录为 被视为类名,并且每个存根定义都被视为单个测试。我们假设 它至少包含一个要用作测试类名的目录。如果还有更多 而不是一个级别的嵌套目录,则除最后一个目录外的所有目录都用作包名称。 请考虑以下结构:spring-doc.cadn.net.cn
src/test/resources/contracts/myservice/shouldCreateUser.groovy
src/test/resources/contracts/myservice/shouldReturnUser.groovy
给定该结构, Spring Cloud Contract Verifier 创建一个名为defaultBasePackage.MyService有两种方法:spring-doc.cadn.net.cn
运行插件
generateTestsplugin 目标被分配为在名为generate-test-sources.如果您希望它成为构建过程的一部分,则无需这样做 什么。如果您只想生成测试,请调用generateTests目标。spring-doc.cadn.net.cn
如果要从 Maven 运行存根,请调用rungoal 中,存根作为spring.cloud.contract.verifier.stubssystem 属性,如下所示:spring-doc.cadn.net.cn
mvn org.springframework.cloud:spring-cloud-contract-maven-plugin:run \ -Dspring.cloud.contract.verifier.stubs=“com.acme:服务名称”spring-doc.cadn.net.cn
配置插件
要更改默认配置,您可以添加configuration部分添加到插件中 定义或execution定义,如下所示:spring-doc.cadn.net.cn
<plugin>
    <executions>
        <execution>
            <goals>
                <goal>convert</goal>
                <goal>generateStubs</goal>
                <goal>generateTests</goal>
            </goals>
        </execution>
    </executions>
    <configuration>
        <basePackageForTests>org.springframework.cloud.verifier.twitter.place</basePackageForTests>
        <baseClassForTests>org.springframework.cloud.verifier.twitter.place.BaseMockMvcSpec</baseClassForTests>
    </configuration>
</plugin>
配置选项
  • testMode:定义验收测试的模式。默认情况下,模式为MockMvc, 它基于 Spring 的 MockMvc。您也可以将其更改为WebTestClient,JaxRsClientExplicit(对于真正的 HTTP 调用)。spring-doc.cadn.net.cn
  • basePackageForTests:指定所有生成的测试的基础包。如果未设置,则 该值是从baseClassForTests和 从packageWithBaseClasses. 如果这两个值均未设置,则该值将设置为org.springframework.cloud.contract.verifier.tests.spring-doc.cadn.net.cn
  • ruleClassForTests:指定应添加到生成的测试的规则 类。spring-doc.cadn.net.cn
  • baseClassForTests:为所有生成的测试创建一个基类。默认情况下,如果你 使用 Spock 类,则 class 为spock.lang.Specification.spring-doc.cadn.net.cn
  • contractsDirectory:指定一个目录,其中包含使用 Groovyn DSL.默认目录为/src/test/resources/contracts.spring-doc.cadn.net.cn
  • generatedTestSourcesDir:指定生成测试的测试源目录 应该放置 Groovy DSL。默认情况下,其值为$buildDir/generated-test-sources/contracts.spring-doc.cadn.net.cn
  • generatedTestResourcesDir:指定生成的测试使用的资源的测试资源目录。spring-doc.cadn.net.cn
  • testFramework:指定要使用的目标测试框架。目前,Spock、JUnit 4 (TestFramework.JUNIT) 和 支持 JUnit 5,其中 JUnit 4 是默认框架。spring-doc.cadn.net.cn
  • packageWithBaseClasses:定义所有基类所在的包。这 设置优先于baseClassForTests.约定是这样的,如果你 在 (例如) 下签订合同src/test/resources/contract/foo/bar/baz/并设置 的packageWithBaseClassesproperty 设置为com.example.baseSpring Cloud Contract Verifier 假定存在BarBazBasecom.example.base包。换句话说,系统采用 package(如果存在)并形成一个类Base作为后缀。spring-doc.cadn.net.cn
  • baseClassMappings:指定提供contractPackageRegex(根据 Contract 所在的软件包进行检查 located) 和baseClassFQN( 映射到 的基类的完全限定名称 匹配的合约)。例如,如果您在src/test/resources/contract/foo/bar/baz/并映射.* → com.example.base.BaseClassproperty,则从这些协定生成的测试类 延伸com.example.base.BaseClass.此设置优先于packageWithBaseClassesbaseClassForTests.spring-doc.cadn.net.cn
  • contractsProperties:包含要传递给 Spring Cloud Contract 的属性的 map 组件。这些属性可能由(例如)内置或自定义 Stub Downloader 使用。spring-doc.cadn.net.cn
  • failOnNoContracts:启用后,如果未找到 Contract,将引发异常。默认为true.spring-doc.cadn.net.cn
  • failOnInProgress:如果设置为true,然后,如果找到任何正在进行的合同,它们就会中断构建。在生产者方面,您需要明确说明您有正在进行的合同这一事实,并考虑到您可能会在消费者方面导致误报测试结果。默认为true.spring-doc.cadn.net.cn
  • incrementalContractTests:启用后,仅当自上次构建以来合同发生更改时,才会创建测试。默认为true.spring-doc.cadn.net.cn
  • incrementalContractStubs:启用后,仅当自上次构建以来合同发生更改时,才会创建存根。默认为true.spring-doc.cadn.net.cn
  • incrementalContractStubsJar:启用后,仅当存根自上次构建以来发生更改时,才会创建存根 jar。默认为true. *httpPort:提供存根的 WireMock 服务器的 HTTP 端口。现在spring.cloud.contract.verifier.http.port属性仅在从目录中提供存根时有效。否则,在提供存根 ID 时,必须在 id 字符串中包含 port。 *skip:将此项设置为true绕过验证程序执行。 *skipTestOnly:将此项设置为true绕过验证程序测试生成。 *stubs:要下载并以冒号分隔的 Ivy 表示法运行的存根列表。 *minPort:指定存根应从的最小端口开始。 *maxPort:指定存根应开始的最大端口。 *waitForKeyPressed:指定插件是否应在启动存根后等待用户按下该键。 *stubsClassifier:指定存根工件使用的分类器。spring-doc.cadn.net.cn
如果要从 Maven 存储库下载合同定义,可以使用 以下选项:spring-doc.cadn.net.cn
  • contractDependency:包含所有打包合同的合同依赖项。spring-doc.cadn.net.cn
  • contractsPath:具有打包合同的 JAR 中具体合同的路径。 默认为groupid/artifactid哪里gropuid是斜杠分隔的。spring-doc.cadn.net.cn
  • contractsMode:选择查找和注册存根的模式。spring-doc.cadn.net.cn
  • deleteStubsAfterTest:如果设置为false,请勿删除任何已下载的内容 来自临时目录的 Contract。spring-doc.cadn.net.cn
  • contractsRepositoryUrl:包含具有协定的构件的存储库的 URL。如果未提供, 使用当前的 Maven 的。spring-doc.cadn.net.cn
  • contractsRepositoryUsername:用于通过 Contract 连接到 repo 的用户名。spring-doc.cadn.net.cn
  • contractsRepositoryPassword:用于通过 Contract 连接到 repo 的密码。spring-doc.cadn.net.cn
  • contractsRepositoryProxyHost:用于通过 Contract 连接到 repo 的代理主机。spring-doc.cadn.net.cn
  • contractsRepositoryProxyPort:用于通过合约连接到仓库的代理端口。spring-doc.cadn.net.cn
我们只缓存非快照的、显式提供的版本(例如+1.0.0.BUILD-SNAPSHOT不要被缓存)。默认情况下,此功能处于打开状态。spring-doc.cadn.net.cn
以下列表描述了您可以在插件中打开的实验性功能:spring-doc.cadn.net.cn
  • convertToYaml:将所有 DSL 转换为声明式 YAML 格式。当您在 Groovy DSL 中使用外部库时,这可能非常有用。通过启用此功能(通过将其设置为true),则无需在使用者端添加库依赖项。spring-doc.cadn.net.cn
  • assertJsonSize:您可以在生成的测试中检查 JSON 数组的大小。默认情况下,此功能处于禁用状态。spring-doc.cadn.net.cn
所有测试的单个基类
当在默认 (MockMvc),您需要创建一个 base 规范。在此类中,您需要指向一个 endpoint,该端点应进行验证。以下示例显示了如何执行此作:spring-doc.cadn.net.cn
import org.mycompany.ExampleSpringController
import com.jayway.restassured.module.mockmvc.RestAssuredMockMvc
import spock.lang.Specification
class MvcSpec extends Specification {
  def setup() {
   RestAssuredMockMvc.standaloneSetup(new ExampleSpringController())
如有必要,您还可以设置整个上下文,如下例所示:spring-doc.cadn.net.cn
import io.restassured.module.mockmvc.RestAssuredMockMvc;
import org.junit.Before;
import org.junit.runner.RunWith;
import org.springframework.beans.factory.annotation.Autowired;
import org.springframework.boot.test.context.SpringBootTest;
import org.springframework.test.context.junit4.SpringRunner;
import org.springframework.web.context.WebApplicationContext;
@RunWith(SpringRunner.class)
@SpringBootTest(webEnvironment = WebEnvironment.RANDOM_PORT, classes = SomeConfig.class, properties="some=property")
public abstract class BaseTestClass {
	@Autowired
	WebApplicationContext context;
	@Before
	public void setup() {
		RestAssuredMockMvc.webAppContextSetup(this.context);
如果您使用EXPLICITmode 中,你可以使用基类来初始化整个测试的应用程序。 类似于您在常规集成测试中可能执行的作。以下示例显示了 如何作:spring-doc.cadn.net.cn
import io.restassured.RestAssured;
import org.springframework.boot.web.server.LocalServerPort;
	@LocalServerPort
	int port;
	@Before
		RestAssured.baseURI = "http://localhost:" + this.port;
如果您使用JAXRSCLIENTmode 时,此基类还应包含一个protected WebTarget webTarget田。右 现在,测试 JAX-RS API 的唯一方法是启动 Web 服务器。spring-doc.cadn.net.cn
对 Contract 使用不同的基类
如果您的基类在 Contract 之间不同,则可以告诉 Spring Cloud Contract plugin 哪个类应该由自动生成的测试进行扩展。您有两个选项:spring-doc.cadn.net.cn
按约定
约定是这样的,如果您在 (例如)src/test/resources/contract/foo/bar/baz/并设置packageWithBaseClassesproperty 设置为com.example.base,然后是 Spring Cloud Contract 验证程序假定存在BarBazBasecom.example.base包。 换句话说,系统采用包的最后两部分(如果存在),并且 形成一个类,其中包含Base后缀。此规则优先于baseClassForTests. 以下示例显示了它在contracts关闭:spring-doc.cadn.net.cn
<plugin>
	<configuration>
		<packageWithBaseClasses>hello</packageWithBaseClasses>
	</configuration>
</plugin>
按映射
您可以手动将 Contract 包的正则表达式映射到完全限定的 匹配合约的基类名称。您必须提供一个名为baseClassMappings包括baseClassMapping对象,每个对象都采用contractPackageRegexbaseClassFQN映射。请考虑以下示例:spring-doc.cadn.net.cn
<plugin>
	<configuration>
		<baseClassForTests>com.example.FooBase</baseClassForTests>
		<baseClassMappings>
			<baseClassMapping>
				<contractPackageRegex>.*com.*</contractPackageRegex>
				<baseClassFQN>com.example.TestBase</baseClassFQN>
			</baseClassMapping>
		</baseClassMappings>
	</configuration>
</plugin>
假设您在以下两个位置签订了合同:spring-doc.cadn.net.cn
通过提供baseClassForTests,如果映射未成功,我们有一个回退。 (您还可以提供packageWithBaseClasses作为后备。这样,测试 生成自src/test/resources/contract/com/合约扩展了com.example.ComBase,而其余测试扩展com.example.FooBase.spring-doc.cadn.net.cn
调用生成的测试
Spring Cloud Contract Maven Plugin 在名为/generated-test-sources/contractVerifier并将此目录附加到testCompile目标。spring-doc.cadn.net.cn
对于 Groovy Spock 代码,您可以使用以下内容:spring-doc.cadn.net.cn
<plugin>
	<groupId>org.codehaus.gmavenplus</groupId>
	<artifactId>gmavenplus-plugin</artifactId>
	<version>1.5</version>
	<executions>
		<execution>
			<goals>
				<goal>testCompile</goal>
			</goals>
		</execution>
	</executions>
	<configuration>
		<testSources>
			<testSource>
				<directory>${project.basedir}/src/test/groovy</directory>
				<includes>
					<include>**/*.groovy</include>
				</includes>
			</testSource>
			<testSource>
				<directory>${project.build.directory}/generated-test-sources/contractVerifier</directory>
				<includes>
				</includes>
			</testSource>
		</testSources>
	</configuration>
</plugin>
为了确保 provider 端符合定义的 Contract,您需要调用mvn generateTest test.spring-doc.cadn.net.cn
将存根推送到 SCM
如果您使用 SCM (Source Control Management) 存储库来保存合同和 stubs 中,您可能希望自动执行将 stub 推送到 存储库。为此,您可以添加pushStubsToScm目标。以下示例显示了如何执行此作:spring-doc.cadn.net.cn
<plugin>
    <configuration>
        <!-- Base class mappings etc. -->
        <!-- We want to pick contracts from a Git repository -->
        <contractsRepositoryUrl>git://https://github.com/spring-cloud-samples/spring-cloud-contract-nodejs-contracts-git.git</contractsRepositoryUrl>
        <!-- We reuse the contract dependency section to set up the path
        to the folder that contains the contract definitions. In our case the
        path will be /groupId/artifactId/version/contracts -->
        <contractDependency>
            <groupId>${project.groupId}</groupId>
            <artifactId>${project.artifactId}</artifactId>
            <version>${project.version}</version>
        </contractDependency>
        <!-- The contracts mode can't be classpath -->
        <contractsMode>REMOTE</contractsMode>
    </configuration>
    <executions>
        <execution>
            <phase>package</phase>
            <goals>
                <!-- By default we will not push the stubs back to SCM,
                you have to explicitly add it as a goal -->
                <goal>pushStubsToScm</goal>
            </goals>
        </execution>
    </executions>
</plugin>
Using the SCM Stub Downloader 下,您可以找到所有可能的 您可以传递的配置选项 这<configuration><contractsProperties>map、系统属性、 或环境变量。例如,您可以指定要签出的具体分支,而不是默认分支spring-doc.cadn.net.cn
<plugin>
    <configuration>
            <git.branch>another_branch</git.branch>
        </contractsProperties>
    </configuration>
    <executions>
        <execution>
            <goals>
            </goals>
        </execution>
    </executions>
</plugin>
Maven 插件和 STS
下图显示了在使用 STS 时可能会看到的异常:spring-doc.cadn.net.cn
STS Exception
当您单击错误标记时,您应该会看到如下所示的内容:spring-doc.cadn.net.cn
 plugin:1.1.0.M1:convert:default-convert:process-test-resources) org.apache.maven.plugin.PluginExecutionException: Execution default-convert of goal org.springframework.cloud:spring-
 cloud-contract-maven-plugin:1.1.0.M1:convert failed. at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:145) at
 org.eclipse.m2e.core.internal.embedder.MavenImpl.execute(MavenImpl.java:331) at org.eclipse.m2e.core.internal.embedder.MavenImpl$11.call(MavenImpl.java:1362) at
 org.eclipse.core.internal.jobs.Worker.run(Worker.java:55) Caused by: java.lang.NullPointerException at
 org.eclipse.m2e.core.internal.builder.plexusbuildapi.EclipseIncrementalBuildContext.hasDelta(EclipseIncrementalBuildContext.java:53) at
 org.sonatype.plexus.build.incremental.ThreadBuildContext.hasDelta(ThreadBuildContext.java:59) at
要解决此问题,请在pom.xml:spring-doc.cadn.net.cn
<build>
    <pluginManagement>
        <plugins>
            <!--This plugin's configuration is used to store Eclipse m2e settings
                only. It has no influence on the Maven build itself. -->
            <plugin>
                <groupId>org.eclipse.m2e</groupId>
                <artifactId>lifecycle-mapping</artifactId>
                <version>1.0.0</version>
                <configuration>
                    <lifecycleMappingMetadata>
                        <pluginExecutions>
                             <pluginExecution>
                                <pluginExecutionFilter>
                                    <versionRange>[1.0,)</versionRange>
                                    <goals>
                                    </goals>
                                </pluginExecutionFilter>
                                <action>
                                    <execute />
                                </action>
                             </pluginExecution>
                        </pluginExecutions>
                    </lifecycleMappingMetadata>
                </configuration>
            </plugin>
        </plugins>
    </pluginManagement>
</build>
带有 Spock 测试的 Maven 插件
您可以选择 Spock Framework 来创建和运行自动生成的合约 使用 Maven 和 Gradle 进行验证测试。但是,虽然使用 Gradle 很简单, 在 Maven 中,您需要一些额外的设置才能使测试正确编译和执行。spring-doc.cadn.net.cn
首先,您必须使用插件,例如 GMavenPlus 插件, 将 Groovy 添加到您的项目中。在 GMavenPlus 插件中,您需要显式设置测试源,包括 path 来定义您的基本测试类,并且 path 是添加生成的 Contract 测试的。 以下示例说明如何执行此作。spring-doc.cadn.net.cn
如果您坚持 Spock 约定,即以Spec,您还需要调整您的 Maven Surefire 插件设置,如下所示。spring-doc.cadn.net.cn
