此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 Spring AMQP 3.2.0! |
多代理(或集群)支持
版本 2.3 在单个应用程序与多个代理或代理集群之间通信时增加了更多便利。 从使用者的角度来看,主要好处是基础设施可以自动将自动声明的队列与适当的代理相关联。
最好用一个例子来说明这一点:
@SpringBootApplication(exclude = RabbitAutoConfiguration.class)
public class Application {
SpringApplication.run(Application.class, args);
CachingConnectionFactory cf1() {
return new CachingConnectionFactory("localhost");
CachingConnectionFactory cf2() {
return new CachingConnectionFactory("otherHost");
CachingConnectionFactory cf3() {
return new CachingConnectionFactory("thirdHost");
SimpleRoutingConnectionFactory rcf(CachingConnectionFactory cf1,
CachingConnectionFactory cf2, CachingConnectionFactory cf3) {
SimpleRoutingConnectionFactory rcf = new SimpleRoutingConnectionFactory();
rcf.setDefaultTargetConnectionFactory(cf1);
rcf.setTargetConnectionFactories(Map.of("one", cf1, "two", cf2, "three", cf3));
return rcf;
@Bean("factory1-admin")
RabbitAdmin admin1(CachingConnectionFactory cf1) {
return new RabbitAdmin(cf1);
@Bean("factory2-admin")
RabbitAdmin admin2(CachingConnectionFactory cf2) {
return new RabbitAdmin(cf2);
@Bean("factory3-admin")
RabbitAdmin admin3(CachingConnectionFactory cf3) {
return new RabbitAdmin(cf3);
public RabbitListenerEndpointRegistry rabbitListenerEndpointRegistry() {
return new RabbitListenerEndpointRegistry();
public RabbitListenerAnnotationBeanPostProcessor postProcessor(RabbitListenerEndpointRegistry registry) {
MultiRabbitListenerAnnotationBeanPostProcessor postProcessor
= new MultiRabbitListenerAnnotationBeanPostProcessor();
postProcessor.setEndpointRegistry(registry);
postProcessor.setContainerFactoryBeanName("defaultContainerFactory");
return postProcessor;
public SimpleRabbitListenerContainerFactory factory1(CachingConnectionFactory cf1) {
SimpleRabbitListenerContainerFactory factory = new SimpleRabbitListenerContainerFactory();
factory.setConnectionFactory(cf1);
return factory;
public SimpleRabbitListenerContainerFactory factory2(CachingConnectionFactory cf2) {
factory.setConnectionFactory(cf2);
return factory;
public SimpleRabbitListenerContainerFactory factory3(CachingConnectionFactory cf3) {
factory.setConnectionFactory(cf3);
return factory;
RabbitTemplate template(SimpleRoutingConnectionFactory rcf) {
return new RabbitTemplate(rcf);
ConnectionFactoryContextWrapper wrapper(SimpleRoutingConnectionFactory rcf) {
return new ConnectionFactoryContextWrapper(rcf);
@Component
class Listeners {
@RabbitListener(queuesToDeclare = @Queue("q1"), containerFactory = "factory1")
public void listen1(String in) {
@RabbitListener(queuesToDeclare = @Queue("q2"), containerFactory = "factory2")
public void listen2(String in) {
@RabbitListener(queuesToDeclare = @Queue("q3"), containerFactory = "factory3")
public void listen3(String in) {
如你所见,我们已经声明了 3 组基础设施(连接工厂、管理员、容器工厂)。
如前所述,@RabbitListener
可以定义要使用的容器工厂;在这种情况下,他们还使用queuesToDeclare
这会导致在 broker 上声明队列(如果它不存在)。
通过将RabbitAdmin
具有约定的 bean<container-factory-name>-admin
,基础架构能够确定哪个管理员应该声明队列。
这也适用于bindings = @QueueBinding(…)
因此,也将声明交换和约束。
它不适用于queues
,因为这期望队列已经存在。
在生产商方面,一个方便的ConnectionFactoryContextWrapper
类,要使用RoutingConnectionFactory
(请参阅 Routing Connection Factory) 更简单。
如您在上面看到的,SimpleRoutingConnectionFactory
添加了带有路由键的 Beanone
,two
和three
还有一个RabbitTemplate
使用该工厂。
以下是使用该模板和包装器路由到其中一个代理集群的示例。
public ApplicationRunner runner(RabbitTemplate template, ConnectionFactoryContextWrapper wrapper) {
return args -> {
wrapper.run("one", () -> template.convertAndSend("q1", "toCluster1"));
wrapper.run("two", () -> template.convertAndSend("q2", "toCluster2"));
wrapper.run("three", () -> template.convertAndSend("q3", "toCluster3"));
