Cross Site Request Forgery (CSRF) for WebFlux Environments
This section discusses Spring Security’s Cross Site Request Forgery (CSRF) support for WebFlux environments.spring-doc.cn
Using Spring Security CSRF Protection
The steps to using Spring Security’s CSRF protection are outlined below:spring-doc.cn
Use Proper HTTP Verbs
The first step to protecting against CSRF attacks is to ensure your website uses proper HTTP verbs. This is covered in detail in Safe Methods Must be Read-only.spring-doc.cn
Configure CSRF Protection
The next step is to configure Spring Security’s CSRF protection within your application. By default, Spring Security’s CSRF protection is enabled, but you may need to customize the configuration. The next few subsections cover a few common customizations.spring-doc.cn
Custom CsrfTokenRepository
By default, Spring Security stores the expected CSRF token in the WebSession by using WebSessionServerCsrfTokenRepository. Sometimes, you may need to configure a custom ServerCsrfTokenRepository. For example, you may want to persist the CsrfToken in a cookie to support a JavaScript-based application.spring-doc.cn
By default, the CookieServerCsrfTokenRepository writes to a cookie named XSRF-TOKEN and read its from a header named X-XSRF-TOKEN or the HTTP _csrf parameter. These defaults come from AngularJSspring-doc.cn
You can configure CookieServerCsrfTokenRepository in Java Configuration:spring-doc.cn
Store CSRF Token in a Cookie
public SecurityWebFilterChain springSecurityFilterChain(ServerHttpSecurity http) {
	http
		.csrf(csrf -> csrf.csrfTokenRepository(CookieServerCsrfTokenRepository.withHttpOnlyFalse()))
	return http.build();
fun springSecurityFilterChain(http: ServerHttpSecurity): SecurityWebFilterChain {
    return http {
        csrf {
            csrfTokenRepository = CookieServerCsrfTokenRepository.withHttpOnlyFalse()
The preceding sample explicitly sets cookieHttpOnly=false. This is necessary to let JavaScript (in this case, AngularJS) to read it. If you do not need the ability to read the cookie with JavaScript directly, we recommend to omitting cookieHttpOnly=false (by using new CookieServerCsrfTokenRepository() instead) to improve security.spring-doc.cn
Disable CSRF Protection
By default, CSRF protection is enabled. However, you can disable CSRF protection if it makes sense for your application.spring-doc.cn
The Java configuration below will disable CSRF protection.spring-doc.cn
Disable CSRF Configuration
	http
		.csrf(csrf -> csrf.disable()))
    return http {
        csrf {
            disable()
Configure ServerCsrfTokenRequestHandler
Spring Security’s CsrfWebFilter exposes a Mono<CsrfToken> as a ServerWebExchange attribute named org.springframework.security.web.server.csrf.CsrfToken with the help of a ServerCsrfTokenRequestHandler. In 5.8, the default implementation was ServerCsrfTokenRequestAttributeHandler, which simply makes the Mono<CsrfToken> available as an exchange attribute.spring-doc.cn
As of 6.0, the default implementation is XorServerCsrfTokenRequestAttributeHandler, which provides protection for BREACH (see gh-4001).spring-doc.cn
If you wish to disable BREACH protection of the CsrfToken and revert to the 5.8 default, you can configure ServerCsrfTokenRequestAttributeHandler using the following Java configuration:spring-doc.cn
Disable BREACH protection
	http
		.csrf(csrf -> csrf
			.csrfTokenRequestHandler(new ServerCsrfTokenRequestAttributeHandler())
    return http {
        csrf {
            csrfTokenRequestHandler = ServerCsrfTokenRequestAttributeHandler()
Include the CSRF Token
For the synchronizer token pattern to protect against CSRF attacks, we must include the actual CSRF token in the HTTP request. It must be included in a part of the request (a form parameter, an HTTP header, or other option) that is not automatically included in the HTTP request by the browser.spring-doc.cn
We’ve seen that the Mono<CsrfToken> is exposed as a ServerWebExchange attribute. This means that any view technology can access the Mono<CsrfToken> to expose the expected token as either a form or a meta tag.spring-doc.cn
If your view technology does not provide a simple way to subscribe to the Mono<CsrfToken>, a common pattern is to use Spring’s @ControllerAdvice to expose the CsrfToken directly. The following example places the CsrfToken on the default attribute name (_csrf) used by Spring Security’s CsrfRequestDataValueProcessor to automatically include the CSRF token as a hidden input:spring-doc.cn
CsrfToken as @ModelAttribute
@ControllerAdvice
public class SecurityControllerAdvice {
	@ModelAttribute
	Mono<CsrfToken> csrfToken(ServerWebExchange exchange) {
		Mono<CsrfToken> csrfToken = exchange.getAttribute(CsrfToken.class.getName());
		return csrfToken.doOnSuccess(token -> exchange.getAttributes()
				.put(CsrfRequestDataValueProcessor.DEFAULT_CSRF_ATTR_NAME, token));
@ControllerAdvice
    @ModelAttribute
    fun csrfToken(exchange: ServerWebExchange): Mono<CsrfToken> {
        val csrfToken: Mono<CsrfToken>? = exchange.getAttribute(CsrfToken::class.java.name)
        return csrfToken!!.doOnSuccess { token ->
            exchange.attributes[CsrfRequestDataValueProcessor.DEFAULT_CSRF_ATTR_NAME] = token
Fortunately, Thymeleaf provides integration that works without any additional work.spring-doc.cn
Form URL Encoded
To post an HTML form, the CSRF token must be included in the form as a hidden input. The following example shows what the rendered HTML might look like:spring-doc.cn
CSRF Token HTML
<input type="hidden"
	name="_csrf"
	value="4bfd1575-3ad1-4d21-96c7-4ef2d9f86721"/>
Next, we discuss various ways of including the CSRF token in a form as a hidden input.spring-doc.cn
Automatic CSRF Token Inclusion
Spring Security’s CSRF support provides integration with Spring’s RequestDataValueProcessor through its CsrfRequestDataValueProcessor. For CsrfRequestDataValueProcessor to work, the Mono<CsrfToken> must be subscribed to and the CsrfToken must be exposed as an attribute that matches DEFAULT_CSRF_ATTR_NAME.spring-doc.cn
Fortunately, Thymeleaf takes care of all the boilerplate for you by integrating with RequestDataValueProcessor to ensure that forms that have an unsafe HTTP method (POST) automatically include the actual CSRF token.spring-doc.cn
CsrfToken Request Attribute
If the other options for including the actual CSRF token in the request do not work, you can take advantage of the fact that the Mono<CsrfToken> is exposed as a ServerWebExchange attribute named org.springframework.security.web.server.csrf.CsrfToken.spring-doc.cn
The following Thymeleaf sample assumes that you expose the CsrfToken on an attribute named _csrf:spring-doc.cn
CSRF Token in Form with Request Attribute
<form th:action="@{/logout}"
	method="post">
<input type="submit"
	value="Log out" />
	th:name="${_csrf.parameterName}"
	th:value="${_csrf.token}"/>
</form>
Ajax and JSON Requests
If you use JSON, you cannot submit the CSRF token within an HTTP parameter. Instead, you can submit the token within a HTTP header.spring-doc.cn
In the following sections, we discuss various ways of including the CSRF token as an HTTP request header in JavaScript-based applications.spring-doc.cn
Automatic Inclusion
You can configure Spring Security to store the expected CSRF token in a cookie. By storing the expected CSRF in a cookie, JavaScript frameworks, such as AngularJS, automatically include the actual CSRF token in the HTTP request headers.spring-doc.cn
Meta Tags
An alternative pattern to exposing the CSRF in a cookie is to include the CSRF token within your meta tags. The HTML might look something like this:spring-doc.cn
CSRF meta tag HTML
<html>
<head>
	<meta name="_csrf" content="4bfd1575-3ad1-4d21-96c7-4ef2d9f86721"/>
	<meta name="_csrf_header" content="X-CSRF-TOKEN"/>
</head>
Once the meta tags contain the CSRF token, the JavaScript code can read the meta tags and include the CSRF token as a header. If you use jQuery, you could read the meta tags with the following code:spring-doc.cn
AJAX send CSRF Token
$(function () {
	var token = $("meta[name='_csrf']").attr("content");
	var header = $("meta[name='_csrf_header']").attr("content");
	$(document).ajaxSend(function(e, xhr, options) {
		xhr.setRequestHeader(header, token);
The following sample assumes that you expose the CsrfToken on an attribute named _csrf. The following example does this with Thymeleaf:spring-doc.cn
CSRF meta tag JSP
<html>
<head>
	<meta name="_csrf" th:content="${_csrf.token}"/>
	<!-- default header name is X-CSRF-TOKEN -->
	<meta name="_csrf_header" th:content="${_csrf.headerName}"/>
</head>
CSRF Considerations
There are a few special considerations to consider when implementing protection against CSRF attacks. This section discusses those considerations as it pertains to WebFlux environments. See CSRF Considerations for a more general discussion.spring-doc.cn
Logging In
You should require CSRF for login requests to protect against forged login attempts. Spring Security’s WebFlux support automatically does this.spring-doc.cn
Logging Out
You should require CSRF for logout requests to protect against forging logout attempts. By default, Spring Security’s LogoutWebFilter only processes only HTTP post requests. This ensures that logout requires a CSRF token and that a malicious user cannot forcibly log out your users.spring-doc.cn
The easiest approach is to use a form to log out. If you really want a link, you can use JavaScript to have the link perform a POST (maybe on a hidden form). For browsers with JavaScript that is disabled, you can optionally have the link take the user to a logout confirmation page that performs the POST.spring-doc.cn
If you really want to use HTTP GET with logout, you can do so, but remember that doing so is generally not recommended. For example, the following Java Configuration logs out when the /logout URL is requested with any HTTP method:spring-doc.cn
Log out with HTTP GET
	http
		.logout(logout -> logout.requiresLogout(new PathPatternParserServerWebExchangeMatcher("/logout")))
    return http {
        logout {
            requiresLogout = PathPatternParserServerWebExchangeMatcher("/logout")
CSRF and Session Timeouts
By default, Spring Security stores the CSRF token in the WebSession. This arrangement can lead to a situation where the session expires, which means that there is not an expected CSRF token to validate against.spring-doc.cn
We have already discussed general solutions to session timeouts. This section discusses the specifics of CSRF timeouts as it pertains to the WebFlux support.spring-doc.cn
You can change storage of the expected CSRF token to be in a cookie. For details, see the Custom CsrfTokenRepository section.spring-doc.cn
Multipart (file upload)
We have already discussed how protecting multipart requests (file uploads) from CSRF attacks causes a chicken and the egg problem. This section discusses how to implement placing the CSRF token in the body and url within a WebFlux application.spring-doc.cn
For more information about using multipart forms with Spring, see the Multipart Data section of the Spring reference.spring-doc.cn
Place CSRF Token in the Body
We have already discussed the trade-offs of placing the CSRF token in the body.spring-doc.cn
In a WebFlux application, you can do so with the following configuration:spring-doc.cn
Enable obtaining CSRF token from multipart/form-data
	http
		.csrf(csrf -> csrf.tokenFromMultipartDataEnabled(true))
    return http {
        csrf {
            tokenFromMultipartDataEnabled = true
Include CSRF Token in URL
We have already discussed the trade-offs of placing the CSRF token in the URL. Since the CsrfToken is exposed as an ServerHttpRequest request attribute, we can use that to create an action with the CSRF token in it. An example with Thymeleaf is shown below:spring-doc.cn
CSRF Token in Action
<form method="post"
	th:action="@{/upload(${_csrf.parameterName}=${_csrf.token})}"
	enctype="multipart/form-data">
HiddenHttpMethodFilter
We have already discussed overriding the HTTP method.spring-doc.cn
In a Spring WebFlux application, overriding the HTTP method is done by using HiddenHttpMethodFilter.spring-doc.cn
