Authentication Migrations
The following steps relate to how to finish migrating authentication support.spring-doc.cn
Propagate AuthenticationServiceExceptions
AuthenticationFilter propagates AuthenticationServiceExceptions to the AuthenticationEntryPoint. Because AuthenticationServiceExceptions represent a server-side error instead of a client-side error, in 6.0, this changes to propagate them to the container.spring-doc.cn
So, if you opted into this behavior by setting rethrowAuthenticationServiceException to true, you can now remove it like so:spring-doc.cn
AuthenticationFilter authenticationFilter = new AuthenticationFilter(...);
AuthenticationEntryPointFailureHandler handler = new AuthenticationEntryPointFailureHandler(...);
handler.setRethrowAuthenticationServiceException(true);
authenticationFilter.setAuthenticationFailureHandler(handler);
val authenticationFilter: AuthenticationFilter = AuthenticationFilter(...)
val handler: AuthenticationEntryPointFailureHandler = AuthenticationEntryPointFailureHandler(...)
<bean id="authenticationFilter" class="org.springframework.security.web.authentication.AuthenticationFilter">
    <property ref="authenticationFailureHandler"/>
</bean>
<bean id="authenticationFailureHandler" class="org.springframework.security.web.authentication.AuthenticationEntryPointFailureHandler">
    <property name="rethrowAuthenticationServiceException" value="true"/>
</bean>
changes to:spring-doc.cn
</bean>
</bean>
Use SHA-256 in Remember Me
In 6.0, the TokenBasedRememberMeServices uses SHA-256 to encode and match the token. To complete the migration, any default values can be removed.spring-doc.cn
For example, if you opted in to the 6.0 default for encodingAlgorithm and matchingAlgorithm like so:spring-doc.cn
@EnableWebSecurity
public class SecurityConfig {
    SecurityFilterChain securityFilterChain(HttpSecurity http, RememberMeServices rememberMeServices) throws Exception {
        http
                .rememberMe((remember) -> remember
                    .rememberMeServices(rememberMeServices)
        return http.build();
    RememberMeServices rememberMeServices(UserDetailsService userDetailsService) {
        RememberMeTokenAlgorithm encodingAlgorithm = RememberMeTokenAlgorithm.SHA256;
        TokenBasedRememberMeServices rememberMe = new TokenBasedRememberMeServices(myKey, userDetailsService, encodingAlgorithm);
        rememberMe.setMatchingAlgorithm(RememberMeTokenAlgorithm.SHA256);
        return rememberMe;
<http>
  <remember-me services-ref="rememberMeServices"/>
</http>
<bean id="rememberMeServices" class=
"org.springframework.security.web.authentication.rememberme.TokenBasedRememberMeServices">
    <property name="userDetailsService" ref="myUserDetailsService"/>
    <property name="key" value="springRocks"/>
    <property name="matchingAlgorithm" value="SHA256"/>
    <property name="encodingAlgorithm" value="SHA256"/>
</bean>
then the defaults can be removed:spring-doc.cn
@EnableWebSecurity
        http
        return new TokenBasedRememberMeServices(myKey, userDetailsService);
<http>
</http>
</bean>
Default authorities for oauth2Login()
In Spring Security 5, the default GrantedAuthority given to a user that authenticates with an OAuth2 or OpenID Connect 1.0 provider (via oauth2Login()) is ROLE_USER.spring-doc.cn
In Spring Security 6, the default authority given to a user authenticating with an OAuth2 provider is OAUTH2_USER. The default authority given to a user authenticating with an OpenID Connect 1.0 provider is OIDC_USER. If you configured the GrantedAuthoritiesMapper only for the purpose of updating to 6.0, you can remove it completely.spring-doc.cn
