Authorize HttpServletRequests
Spring Security allows you to model your authorization at the request level. For example, with Spring Security you can say that all pages under /admin require one authority while all other pages simply require authentication.spring-doc.cn
By default, Spring Security requires that every request be authenticated. That said, any time you use an HttpSecurity instance, it’s necessary to declare your authorization rules.spring-doc.cn
Whenever you have an HttpSecurity instance, you should at least do:spring-doc.cn
Use authorizeHttpRequests
http
    .authorizeHttpRequests((authorize) -> authorize
        .anyRequest().authenticated()
http {
    authorizeHttpRequests {
<http>
    <intercept-url pattern="/**" access="authenticated"/>
</http>
This tells Spring Security that any endpoint in your application requires that the security context at a minimum be authenticated in order to allow it.spring-doc.cn
In many cases, your authorization rules will be more sophisticated than that, so please consider the following use cases:spring-doc.cn
Understanding How Request Authorization Components Work
This section builds on Servlet Architecture and Implementation by digging deeper into how authorization works at the request level in Servlet-based applications.
authorizationfilter
Figure 1. Authorize HttpServletRequest
AuthorizationFilter Is Last By Default
The AuthorizationFilter is last in the Spring Security filter chain by default. This means that Spring Security’s authentication filters, exploit protections, and other filter integrations do not require authorization. If you add filters of your own before the AuthorizationFilter, they will also not require authorization; otherwise, they will.spring-doc.cn
A place where this typically becomes important is when you are adding Spring MVC endpoints. Because they are executed by the DispatcherServlet and this comes after the AuthorizationFilter, you’re endpoints need to be included in authorizeHttpRequests to be permitted.spring-doc.cn
All Dispatches Are Authorized
The AuthorizationFilter runs not just on every request, but on every dispatch. This means that the REQUEST dispatch needs authorization, but also FORWARDs, ERRORs, and INCLUDEs.spring-doc.cn
For example, Spring MVC can FORWARD the request to a view resolver that renders a Thymeleaf template, like so:spring-doc.cn
Sample Forwarding Spring MVC Controller
@Controller
public class MyController {
    @GetMapping("/endpoint")
    public String endpoint() {
        return "endpoint";
@Controller
    fun endpoint(): String {
        return "endpoint"
In this case, authorization happens twice; once for authorizing /endpoint and once for forwarding to Thymeleaf to render the "endpoint" template.spring-doc.cn
For that reason, you may want to permit all FORWARD dispatches.spring-doc.cn
Another example of this principle is how Spring Boot handles errors. If the container catches an exception, say like the following:spring-doc.cn
Sample Erroring Spring MVC Controller
@Controller
        throw new UnsupportedOperationException("unsupported");
@Controller
        throw UnsupportedOperationException("unsupported")
then Boot will dispatch it to the ERROR dispatch.spring-doc.cn
In that case, authorization also happens twice; once for authorizing /endpoint and once for dispatching the error.spring-doc.cn
For that reason, you may want to permit all ERROR dispatches.spring-doc.cn
Authentication Lookup is Deferred
This matters with authorizeHttpRequests when requests are always permitted or always denied. In those cases, the Authentication is not queried, making for a faster request.spring-doc.cn
Authorizing an Endpoint
You can configure Spring Security to have different rules by adding more rules in order of precedence.spring-doc.cn
If you want to require that /endpoint only be accessible by end users with the USER authority, then you can do:spring-doc.cn
Authorize an Endpoint
SecurityFilterChain web(HttpSecurity http) throws Exception {
	http
			.requestMatchers("/endpoint").hasAuthority("USER")
	return http.build();
	http {
            authorize("/endpoint", hasAuthority("USER"))
<http>
    <intercept-url pattern="/endpoint" access="hasAuthority('USER')"/>
</http>
As you can see, the declaration can be broken up in to pattern/rule pairs.spring-doc.cn
AuthorizationFilter processes these pairs in the order listed, applying only the first match to the request. This means that even though /** would also match for /endpoint the above rules are not a problem. The way to read the above rules is "if the request is /endpoint, then require the USER authority; else, only require authentication".spring-doc.cn
Spring Security supports several patterns and several rules; you can also programmatically create your own of each.spring-doc.cn
Once authorized, you can test it using Security’s test support in the following way:spring-doc.cn
Test Endpoint Authorization
@WithMockUser(authorities="USER")
@Test
void endpointWhenUserAuthorityThenAuthorized() {
    this.mvc.perform(get("/endpoint"))
        .andExpect(status().isOk());
@WithMockUser
@Test
void endpointWhenNotUserAuthorityThenForbidden() {
        .andExpect(status().isForbidden());
@Test
void anyWhenUnauthenticatedThenUnauthorized() {
    this.mvc.perform(get("/any"))
        .andExpect(status().isUnauthorized())
Matching Requests
Above you’ve already seen two ways to match requests.spring-doc.cn
The first you saw was the simplest, which is to match any request.spring-doc.cn
The second is to match by a URI pattern. Spring Security supports two languages for URI pattern-matching: Ant (as seen above) and Regular Expressions.spring-doc.cn
Matching Using Ant
Ant is the default language that Spring Security uses to match requests.spring-doc.cn
You can use it to match a single endpoint or a directory, and you can even capture placeholders for later use. You can also refine it to match a specific set of HTTP methods.spring-doc.cn
Let’s say that you instead of wanting to match the /endpoint endpoint, you want to match all endpoints under the /resource directory. In that case, you can do something like the following:spring-doc.cn
Match with Ant
http
        .requestMatchers("/resource/**").hasAuthority("USER")
http {
        authorize("/resource/**", hasAuthority("USER"))
<http>
    <intercept-url pattern="/resource/**" access="hasAuthority('USER')"/>
</http>
The way to read this is "if the request is /resource or some subdirectory, require the USER authority; otherwise, only require authentication"spring-doc.cn
You can also extract path values from the request, as seen below:spring-doc.cn
Authorize and Extract
http
        .requestMatchers("/resource/{name}").access(new WebExpressionAuthorizationManager("#name == authentication.name"))
http {
        authorize("/resource/{name}", WebExpressionAuthorizationManager("#name == authentication.name"))
<http>
    <intercept-url pattern="/resource/{name}" access="#name == authentication.name"/>
</http>
Test Directory Authorization
@Test
    this.mvc.perform(get("/endpoint/jon"))
@WithMockUser
@Test
@Test
Spring Security only matches paths. If you want to match query parameters, you will need a custom request matcher.
Matching Using Regular Expressions
Spring Security supports matching requests against a regular expression. This can come in handy if you want to apply more strict matching criteria than ** on a subdirectory.spring-doc.cn
For example, consider a path that contains the username and the rule that all usernames must be alphanumeric. You can use RegexRequestMatcher to respect this rule, like so:spring-doc.cn
Match with Regex
http
        .requestMatchers(RegexRequestMatcher.regexMatcher("/resource/[A-Za-z0-9]+")).hasAuthority("USER")
        .anyRequest().denyAll()
http {
        authorize(RegexRequestMatcher.regexMatcher("/resource/[A-Za-z0-9]+"), hasAuthority("USER"))
        authorize(anyRequest, denyAll)
<http>
    <intercept-url request-matcher="regex" pattern="/resource/[A-Za-z0-9]+" access="hasAuthority('USER')"/>
    <intercept-url pattern="/**" access="denyAll"/>
</http>
Matching By Http Method
You can also match rules by HTTP method. One place where this is handy is when authorizing by permissions granted, like being granted a read or write privilege.spring-doc.cn
To require all GETs to have the read permission and all POSTs to have the write permission, you can do something like this:spring-doc.cn
Match by HTTP Method
http
        .requestMatchers(HttpMethod.GET).hasAuthority("read")
        .requestMatchers(HttpMethod.POST).hasAuthority("write")
http {
        authorize(HttpMethod.GET, hasAuthority("read"))
        authorize(HttpMethod.POST, hasAuthority("write"))
<http>
    <intercept-url http-method="GET" pattern="/**" access="hasAuthority('read')"/>
    <intercept-url http-method="POST" pattern="/**" access="hasAuthority('write')"/>
</http>
These authorization rules should read as: "if the request is a GET, then require read permission; else, if the request is a POST, then require write permission; else, deny the request"spring-doc.cn
Denying the request by default is a healthy security practice since it turns the set of rules into an allow list.
Test Http Method Authorization
@WithMockUser(authorities="read")
@Test
void getWhenReadAuthorityThenAuthorized() {
@WithMockUser
@Test
void getWhenNoReadAuthorityThenForbidden() {
@WithMockUser(authorities="write")
@Test
void postWhenWriteAuthorityThenAuthorized() {
    this.mvc.perform(post("/any").with(csrf()))
@Test
void postWhenNoWriteAuthorityThenForbidden() {
    this.mvc.perform(get("/any").with(csrf()))
Matching By Dispatcher Type
This feature is not currently supported in XML
As stated earlier, Spring Security authorizes all dispatcher types by default. And even though the security context established on the REQUEST dispatch carries over to subsequent dispatches, subtle mismatches can sometimes cause an unexpected AccessDeniedException.spring-doc.cn
To address that, you can configure Spring Security Java configuration to allow dispatcher types like FORWARD and ERROR, like so:spring-doc.cn
Example 1. Match by Dispatcher Type
Java
http
        .dispatcherTypeMatchers(DispatcherType.FORWARD, DispatcherType.ERROR).permitAll()
        .requestMatchers("/endpoint").permitAll()
Kotlin
http {
        authorize(DispatcherTypeRequestMatcher(DispatcherType.FORWARD), permitAll)
        authorize(DispatcherTypeRequestMatcher(DispatcherType.ERROR), permitAll)
        authorize("/endpoint", permitAll)
Using an MvcRequestMatcher
Generally speaking, you can use requestMatchers(String) as demonstrated above.spring-doc.cn
However, if you map Spring MVC to a different servlet path, then you need to account for that in your security configuration.spring-doc.cn
For example, if Spring MVC is mapped to /spring-mvc instead of / (the default), then you may have an endpoint like /spring-mvc/my/controller that you want to authorize.spring-doc.cn
You need to use MvcRequestMatcher to split the servlet path and the controller path in your configuration like so:spring-doc.cn
Example 2. Match by MvcRequestMatcher
Java
MvcRequestMatcher.Builder mvc(HandlerMappingIntrospector introspector) {
	return new MvcRequestMatcher.Builder(introspector).servletPath("/spring-mvc");
SecurityFilterChain appEndpoints(HttpSecurity http, MvcRequestMatcher.Builder mvc) {
	http
            .requestMatchers(mvc.pattern("/my/controller/**")).hasAuthority("controller")
Kotlin
fun mvc(introspector: HandlerMappingIntrospector): MvcRequestMatcher.Builder =
fun appEndpoints(http: HttpSecurity, mvc: MvcRequestMatcher.Builder): SecurityFilterChain =
    http {
            authorize(mvc.pattern("/my/controller/**"), hasAuthority("controller"))
Xml
<http>
    <intercept-url servlet-path="/spring-mvc" pattern="/my/controller/**" access="hasAuthority('controller')"/>
</http>
This need can arise in at least two different ways:spring-doc.cn
  • If you use the spring.mvc.servlet.path Boot property to change the default path (/) to something elsespring-doc.cn
  • If you register more than one Spring MVC DispatcherServlet (thus requiring that one of them not be the default path)spring-doc.cn
Using a Custom Matcher
In Java configuration, you can create your own RequestMatcher and supply it to the DSL like so:spring-doc.cn
Example 3. Authorize by Dispatcher Type
Java
RequestMatcher printview = (request) -> request.getParameter("print") != null;
http
        .requestMatchers(printview).hasAuthority("print")
Kotlin
val printview: RequestMatcher = { (request) -> request.getParameter("print") != null }
http {
        authorize(printview, hasAuthority("print"))
Because RequestMatcher is a functional interface, you can supply it as a lambda in the DSL. However, if you want to extract values from the request, you will need to have a concrete class since that requires overriding a default method.
Test Custom Authorization
@WithMockUser(authorities="print")
@Test
void printWhenPrintAuthorityThenAuthorized() {
    this.mvc.perform(get("/any?print"))
@WithMockUser
@Test
void printWhenNoPrintAuthorityThenForbidden() {
Authorizing Requests
Once a request is matched, you can authorize it in several ways already seen like permitAll, denyAll, and hasAuthority.spring-doc.cn
As a quick summary, here are the authorization rules built into the DSL:spring-doc.cn
  • permitAll - The request requires no authorization and is a public endpoint; note that in this case, the Authentication is never retrieved from the sessionspring-doc.cn
  • denyAll - The request is not allowed under any circumstances; note that in this case, the Authentication is never retrieved from the sessionspring-doc.cn
  • hasAuthority - The request requires that the Authentication have a GrantedAuthority that matches the given valuespring-doc.cn
  • hasRole - A shortcut for hasAuthority that prefixes ROLE_ or whatever is configured as the default prefixspring-doc.cn
  • hasAnyAuthority - The request requires that the Authentication have a GrantedAuthority that matches any of the given valuesspring-doc.cn
  • hasAnyRole - A shortcut for hasAnyAuthority that prefixes ROLE_ or whatever is configured as the default prefixspring-doc.cn
  • access - The request uses this custom AuthorizationManager to determine accessspring-doc.cn
Having now learned the patterns, rules, and how they can be paired together, you should be able to understand what is going on in this more complex example:spring-doc.cn
Authorize Requests
import static jakarta.servlet.DispatcherType.*;
import static org.springframework.security.authorization.AuthorizationManagers.allOf;
import static org.springframework.security.authorization.AuthorityAuthorizationManager.hasAuthority;
import static org.springframework.security.authorization.AuthorityAuthorizationManager.hasRole;
	http
		.authorizeHttpRequests(authorize -> authorize                                  (1)
            .dispatcherTypeMatchers(FORWARD, ERROR).permitAll() (2)
			.requestMatchers("/static/**", "/signup", "/about").permitAll()         (3)
			.requestMatchers("/admin/**").hasRole("ADMIN")                             (4)
			.requestMatchers("/db/**").access(allOf(hasAuthority('db'), hasRole('ADMIN')))   (5)
			.anyRequest().denyAll()                                                (6)
1 There are multiple authorization rules specified. Each rule is considered in the order they were declared.
2 Dispatches FORWARD and ERROR are permitted to allow Spring MVC to render views and Spring Boot to render errors
3 We specified multiple URL patterns that any user can access. Specifically, any user can access a request if the URL starts with "/resources/", equals "/signup", or equals "/about".
4 Any URL that starts with "/admin/" will be restricted to users who have the role "ROLE_ADMIN". You will notice that since we are invoking the hasRole method we do not need to specify the "ROLE_" prefix.
5 Any URL that starts with "/db/" requires the user to have both been granted the "db" permission as well as be a "ROLE_ADMIN". You will notice that since we are using the hasRole expression we do not need to specify the "ROLE_" prefix.
6 Any URL that has not already been matched on is denied access. This is a good strategy if you do not want to accidentally forget to update your authorization rules.
Expressing Authorization with SpEL
While using a concrete AuthorizationManager is recommended, there are some cases where an expression is necessary, like with <intercept-url> or with JSP Taglibs. For that reason, this section will focus on examples from those domains.spring-doc.cn
Given that, let’s cover Spring Security’s Web Security Authorization SpEL API a bit more in depth.spring-doc.cn
Spring Security encapsulates all of its authorization fields and methods in a set of root objects. The most generic root object is called SecurityExpressionRoot and it forms the basis for WebSecurityExpressionRoot. Spring Security supplies this root object to StandardEvaluationContext when preparing to evaluate an authorization expression.spring-doc.cn
Using Authorization Expression Fields and Methods
The first thing this provides is an enhanced set of authorization fields and methods to your SpEL expressions. What follows is a quick overview of the most common methods:spring-doc.cn
  • permitAll - The request requires no authorization to be invoked; note that in this case, the Authentication is never retrieved from the sessionspring-doc.cn
  • hasPermission - A hook into your PermissionEvaluator instance for doing object-level authorizationspring-doc.cn
And here is a brief look at the most common fields:spring-doc.cn
  • authentication - The Authentication instance associated with this method invocationspring-doc.cn
  • principal - The Authentication#getPrincipal associated with this method invocationspring-doc.cn
Authorize Requests Using SpEL
<http>
    <intercept-url pattern="/static/**" access="permitAll"/> (1)
    <intercept-url pattern="/admin/**" access="hasRole('ADMIN')"/> (2)
    <intercept-url pattern="/db/**" access="hasAuthority('db') and hasRole('ADMIN')"/> (3)
    <intercept-url pattern="/**" access="denyAll"/> (4)
</http>
1 We specified a URL patters that any user can access. Specifically, any user can access a request if the URL starts with "/static/".
2 Any URL that starts with "/admin/" will be restricted to users who have the role "ROLE_ADMIN". You will notice that since we are invoking the hasRole method we do not need to specify the "ROLE_" prefix.
3 Any URL that starts with "/db/" requires the user to have both been granted the "db" permission as well as be a "ROLE_ADMIN". You will notice that since we are using the hasRole expression we do not need to specify the "ROLE_" prefix.
4 Any URL that has not already been matched on is denied access. This is a good strategy if you do not want to accidentally forget to update your authorization rules.
Using Path Parameters
Additionally, Spring Security provides a mechanism for discovering path parameters so they can also be accessed in the SpEL expression as well.spring-doc.cn
For example, you can access a path parameter in your SpEL expression in the following way:spring-doc.cn
Authorize Request using SpEL path variable
<http>
</http>
This expression refers to the path variable after /resource/ and requires that it is equal to Authentication#getName.spring-doc.cn
Use an Authorization Database, Policy Agent, or Other Service
If you want to configure Spring Security to use a separate service for authorization, you can create your own AuthorizationManager and match it to anyRequest.spring-doc.cn
First, your AuthorizationManager may look something like this:spring-doc.cn
Open Policy Agent Authorization Manager
@Component
public final class OpenPolicyAgentAuthorizationManager implements AuthorizationManager<RequestAuthorizationContext> {
    public AuthorizationDecision check(Supplier<Authentication> authentication, RequestAuthorizationContext context) {
        // make request to Open Policy Agent
Then, you can wire it into Spring Security in the following way:spring-doc.cn
Any Request Goes to Remote Service
SecurityFilterChain web(HttpSecurity http, AuthorizationManager<RequestAuthorizationContext> authz) throws Exception {
	http
            .anyRequest().access(authz)
Favor permitAll over ignoring
When you have static resources it can be tempting to configure the filter chain to ignore these values. A more secure approach is to permit them using permitAll like so:spring-doc.cn
Example 4. Permit Static Resources
Java
http
        .requestMatchers("/css/**").permitAll()
Kotlin
http {
        authorize("/css/**", permitAll)
It’s more secure because even with static resources it’s important to write secure headers, which Spring Security cannot do if the request is ignored.spring-doc.cn
In this past, this came with a performance tradeoff since the session was consulted by Spring Security on every request. As of Spring Security 6, however, the session is no longer pinged unless required by the authorization rule. Because the performance impact is now addressed, Spring Security recommends using at least permitAll for all requests.spring-doc.cn
Migrating from authorizeRequests
AuthorizationFilter supersedes FilterSecurityInterceptor. To remain backward compatible, FilterSecurityInterceptor remains the default. This section discusses how AuthorizationFilter works and how to override the default configuration.
The AuthorizationFilter provides authorization for HttpServletRequests. It is inserted into the FilterChainProxy as one of the Security Filters.spring-doc.cn
You can override the default when you declare a SecurityFilterChain. Instead of using authorizeRequests, use authorizeHttpRequests, like so:spring-doc.cn
SecurityFilterChain web(HttpSecurity http) throws AuthenticationException {
    http
            .anyRequest().authenticated();
This improves on authorizeRequests in a number of ways:spring-doc.cn
  1. Uses the simplified AuthorizationManager API instead of metadata sources, config attributes, decision managers, and voters. This simplifies reuse and customization.spring-doc.cn
  2. Delays Authentication lookup. Instead of the authentication needing to be looked up for every request, it will only look it up in requests where an authorization decision requires authentication.spring-doc.cn
  3. Bean-based configuration support.spring-doc.cn
When authorizeHttpRequests is used instead of authorizeRequests, then AuthorizationFilter is used instead of FilterSecurityInterceptor.spring-doc.cn
Migrating Expressions
Where possible, it is recommended that you use type-safe authorization managers instead of SpEL. For Java configuration, WebExpressionAuthorizationManager is available to help migrate legacy SpEL.spring-doc.cn
To use WebExpressionAuthorizationManager, you can construct one with the expression you are trying to migrate, like so:spring-doc.cn
.requestMatchers("/test/**").access(new WebExpressionAuthorizationManager("hasRole('ADMIN') && hasRole('USER')"))
.requestMatchers("/test/**").access(WebExpressionAuthorizationManager("hasRole('ADMIN') && hasRole('USER')"))
If you are referring to a bean in your expression like so: @webSecurity.check(authentication, request), it’s recommended that you instead call the bean directly, which will look something like the following:spring-doc.cn
.requestMatchers("/test/**").access((authentication, context) ->
    new AuthorizationDecision(webSecurity.check(authentication.get(), context.getRequest())))
.requestMatchers("/test/**").access((authentication, context): AuthorizationManager<RequestAuthorizationContext> ->
For complex instructions that include bean references as well as other expressions, it is recommended that you change those to implement AuthorizationManager and refer to them by calling .access(AuthorizationManager).spring-doc.cn
If you are not able to do that, you can configure a DefaultHttpSecurityExpressionHandler with a bean resolver and supply that to WebExpressionAuthorizationManager#setExpressionhandler.spring-doc.cn
Security Matchers
The RequestMatcher interface is used to determine if a request matches a given rule. We use securityMatchers to determine if a given HttpSecurity should be applied to a given request. The same way, we can use requestMatchers to determine the authorization rules that we should apply to a given request. Look at the following example:spring-doc.cn
@EnableWebSecurity
public class SecurityConfig {
	public SecurityFilterChain securityFilterChain(HttpSecurity http) throws Exception {
		http
			.securityMatcher("/api/**")                            (1)
				.requestMatchers("/user/**").hasRole("USER")       (2)
				.requestMatchers("/admin/**").hasRole("ADMIN")     (3)
				.anyRequest().authenticated()                      (4)
			.formLogin(withDefaults());
@EnableWebSecurity
open class SecurityConfig {
    open fun web(http: HttpSecurity): SecurityFilterChain {
        http {
                authorize("/user/**", hasRole("USER"))                           (2)
                authorize("/admin/**", hasRole("ADMIN"))                         (3)
                authorize(anyRequest, authenticated)                             (4)
        return http.build()
1 Configure HttpSecurity to only be applied to URLs that start with /api/
2 Allow access to URLs that start with /user/ to users with the USER role
3 Allow access to URLs that start with /admin/ to users with the ADMIN role
4 Any other request that doesn’t match the rules above, will require authentication
The securityMatcher(s) and requestMatcher(s) methods will decide which RequestMatcher implementation fits best for your application: If Spring MVC is in the classpath, then MvcRequestMatcher will be used, otherwise, AntPathRequestMatcher will be used. You can read more about the Spring MVC integration here.spring-doc.cn
If you want to use a specific RequestMatcher, just pass an implementation to the securityMatcher and/or requestMatcher methods:spring-doc.cn
import static org.springframework.security.web.util.matcher.AntPathRequestMatcher.antMatcher; (1)
import static org.springframework.security.web.util.matcher.RegexRequestMatcher.regexMatcher;
@EnableWebSecurity
		http
			.securityMatcher(antMatcher("/api/**"))                              (2)
				.requestMatchers(antMatcher("/user/**")).hasRole("USER")         (3)
				.requestMatchers(regexMatcher("/admin/.*")).hasRole("ADMIN")     (4)
				.requestMatchers(new MyCustomRequestMatcher()).hasRole("SUPERVISOR")     (5)
public class MyCustomRequestMatcher implements RequestMatcher {
    public boolean matches(HttpServletRequest request) {
import org.springframework.security.web.util.matcher.AntPathRequestMatcher.antMatcher (1)
import org.springframework.security.web.util.matcher.RegexRequestMatcher.regexMatcher
@EnableWebSecurity
        http {
                authorize(antMatcher("/user/**"), hasRole("USER"))               (3)
                authorize(regexMatcher("/admin/**"), hasRole("ADMIN"))           (4)
                authorize(MyCustomRequestMatcher(), hasRole("SUPERVISOR"))       (5)
        return http.build()
1 Import the static factory methods from AntPathRequestMatcher and RegexRequestMatcher to create RequestMatcher instances.
2 Configure HttpSecurity to only be applied to URLs that start with /api/, using AntPathRequestMatcher
3 Allow access to URLs that start with /user/ to users with the USER role, using AntPathRequestMatcher
4 Allow access to URLs that start with /admin/ to users with the ADMIN role, using RegexRequestMatcher
5 Allow access to URLs that match the MyCustomRequestMatcher to users with the SUPERVISOR role, using a custom RequestMatcher
Further Reading
Now that you have secured your application’s requests, consider securing its methods. You can also read further on testing your application or on integrating Spring Security with other aspects of you application like the data layer or tracing and metrics.spring-doc.cn
