EnableReactiveMethodSecurity
Spring Security supports method security by using Reactor’s Context, which is set up by ReactiveSecurityContextHolder. The following example shows how to retrieve the currently logged in user’s message:spring-doc.cn
For this example to work, the return type of the method must be a org.reactivestreams.Publisher (that is, a Mono or a Flux). This is necessary to integrate with Reactor’s Context.spring-doc.cn
EnableReactiveMethodSecurity with AuthorizationManager
In Spring Security 5.8, we can enable annotation-based security using the @EnableReactiveMethodSecurity(useAuthorizationManager=true) annotation on any @Configuration instance.spring-doc.cn
This improves upon @EnableReactiveMethodSecurity in a number of ways. @EnableReactiveMethodSecurity(useAuthorizationManager=true):spring-doc.cn
  1. Uses the simplified AuthorizationManager API instead of metadata sources, config attributes, decision managers, and voters. This simplifies reuse and customization.spring-doc.cn
  2. Supports reactive return types. Note that we are waiting on additional coroutine support from the Spring Framework before adding coroutine support.spring-doc.cn
  3. Is built using native Spring AOP, removing abstractions and allowing you to use Spring AOP building blocks to customizespring-doc.cn
  4. Checks for conflicting annotations to ensure an unambiguous security configurationspring-doc.cn
  5. Complies with JSR-250spring-doc.cn
For earlier versions, please read about similar support with @EnableReactiveMethodSecurity.spring-doc.cn
For example, the following would enable Spring Security’s @PreAuthorize annotation:spring-doc.cn
Method Security Configuration
public class MethodSecurityConfig {
Adding an annotation to a method (on a class or interface) would then limit the access to that method accordingly. Spring Security’s native annotation support defines a set of attributes for the method. These will be passed to the various method interceptors, like AuthorizationManagerBeforeReactiveMethodInterceptor, for it to make the actual decision:spring-doc.cn
Method Security Annotation Usage
public interface BankService {
	@PreAuthorize("hasRole('USER')")
	Mono<Account> readAccount(Long id);
	Flux<Account> findAccounts();
	@PreAuthorize("@func.apply(#account)")
	Mono<Account> post(Account account, Double amount);
In this case hasRole refers to the method found in SecurityExpressionRoot that gets invoked by the SpEL evaluation engine.spring-doc.cn
@bean refers to a custom component you have defined, where apply can return Boolean or Mono<Boolean> to indicate the authorization decision. A bean like that might look something like this:spring-doc.cn
Method Security Reactive Boolean Expression
public Function<Account, Mono<Boolean>> func() {
    return (account) -> Mono.defer(() -> Mono.just(account.getId().equals(12)));
Customizing Authorization
Spring Security’s @PreAuthorize, @PostAuthorize, @PreFilter, and @PostFilter ship with rich expression-based support.spring-doc.cn
Also, for role-based authorization, Spring Security adds a default ROLE_ prefix, which is uses when evaluating expressions like hasRole. You can configure the authorization rules to use a different prefix by exposing a GrantedAuthorityDefaults bean, like so:spring-doc.cn
Custom MethodSecurityExpressionHandler
@Role(BeanDefinition.ROLE_INFRASTRUCTURE)
static GrantedAuthorityDefaults grantedAuthorityDefaults() {
	return new GrantedAuthorityDefaults("MYPREFIX_");
We expose GrantedAuthorityDefaults using a static method to ensure that Spring publishes it before it initializes Spring Security’s method security @Configuration classes. Since the GrantedAuthorityDefaults bean is part of internal workings of Spring Security, we should also expose it as an infrastructural bean effectively avoiding some warnings related to bean post-processing (see gh-14751).spring-doc.cn
Custom Authorization Managers
Method authorization is a combination of before- and after-method authorization.spring-doc.cn
Before-method authorization is performed before the method is invoked. If that authorization denies access, the method is not invoked, and an AccessDeniedException is thrown. After-method authorization is performed after the method is invoked, but before the method returns to the caller. If that authorization denies access, the value is not returned, and an AccessDeniedException is thrownspring-doc.cn
To recreate what adding @EnableReactiveMethodSecurity(useAuthorizationManager=true) does by default, you would publish the following configuration:spring-doc.cn
Full Pre-post Method Security Configuration
	BeanDefinitionRegistryPostProcessor aopConfig() {
		return AopConfigUtils::registerAutoProxyCreatorIfNecessary;
	PreFilterAuthorizationReactiveMethodInterceptor preFilterInterceptor() {
		return new PreFilterAuthorizationReactiveMethodInterceptor();
	AuthorizationManagerBeforeReactiveMethodInterceptor preAuthorizeInterceptor() {
		return AuthorizationManagerBeforeReactiveMethodInterceptor.preAuthorize();
	AuthorizationManagerAfterReactiveMethodInterceptor postAuthorizeInterceptor() {
		return AuthorizationManagerAfterReactiveMethodInterceptor.postAuthorize();
	PostFilterAuthorizationReactiveMethodInterceptor postFilterInterceptor() {
		return new PostFilterAuthorizationReactiveMethodInterceptor();
Notice that Spring Security’s method security is built using Spring AOP. So, interceptors are invoked based on the order specified. This can be customized by calling setOrder on the interceptor instances like so:spring-doc.cn
Publish Custom Advisor
Advisor postFilterAuthorizationMethodInterceptor() {
	PostFilterAuthorizationMethodInterceptor interceptor = new PostFilterAuthorizationReactiveMethodInterceptor();
	interceptor.setOrder(AuthorizationInterceptorOrders.POST_AUTHORIZE.getOrder() - 1);
	return interceptor;
You may want to only support @PreAuthorize in your application, in which case you can do the following:spring-doc.cn
Only @PreAuthorize Configuration
	Advisor preAuthorize() {
		return AuthorizationManagerBeforeMethodInterceptor.preAuthorize();
Or, you may have a custom before-method ReactiveAuthorizationManager that you want to add to the list.spring-doc.cn
In this case, you will need to tell Spring Security both the ReactiveAuthorizationManager and to which methods and classes your authorization manager applies.spring-doc.cn
Thus, you can configure Spring Security to invoke your ReactiveAuthorizationManager in between @PreAuthorize and @PostAuthorize like so:spring-doc.cn
Custom Before Advisor
	public Advisor customAuthorize() {
		JdkRegexpMethodPointcut pattern = new JdkRegexpMethodPointcut();
		pattern.setPattern("org.mycompany.myapp.service.*");
		ReactiveAuthorizationManager<MethodInvocation> rule = AuthorityAuthorizationManager.isAuthenticated();
		AuthorizationManagerBeforeReactiveMethodInterceptor interceptor = new AuthorizationManagerBeforeReactiveMethodInterceptor(pattern, rule);
		interceptor.setOrder(AuthorizationInterceptorsOrder.PRE_AUTHORIZE_ADVISOR_ORDER.getOrder() + 1);
		return interceptor;
You can place your interceptor in between Spring Security method interceptors using the order constants specified in AuthorizationInterceptorsOrder.spring-doc.cn
The same can be done for after-method authorization. After-method authorization is generally concerned with analysing the return value to verify access.spring-doc.cn
For example, you might have a method that confirms that the account requested actually belongs to the logged-in user like so:spring-doc.cn
@PostAuthorize example
	@PostAuthorize("returnObject.owner == authentication.name")
You can supply your own AuthorizationMethodInterceptor to customize how access to the return value is evaluated.spring-doc.cn
For example, if you have your own custom annotation, you can configure it like so:spring-doc.cn
Custom After Advisor
	public Advisor customAuthorize(ReactiveAuthorizationManager<MethodInvocationResult> rules) {
		AnnotationMethodMatcher pattern = new AnnotationMethodMatcher(MySecurityAnnotation.class);
		AuthorizationManagerAfterReactiveMethodInterceptor interceptor = new AuthorizationManagerAfterReactiveMethodInterceptor(pattern, rules);
		interceptor.setOrder(AuthorizationInterceptorsOrder.POST_AUTHORIZE_ADVISOR_ORDER.getOrder() + 1);
		return interceptor;
and it will be invoked after the @PostAuthorize interceptor.spring-doc.cn
@EnableReactiveMethodSecurity also supports Kotlin coroutines, though only to a limited degree. When intercepting coroutines, only the first interceptor participates. If any other interceptors are present and come after Spring Security’s method security interceptor, they will be skipped.spring-doc.cn
Authentication authentication = new TestingAuthenticationToken("user", "password", "ROLE_USER");
Mono<String> messageByUsername = ReactiveSecurityContextHolder.getContext()
	.map(SecurityContext::getAuthentication)
	.map(Authentication::getName)
	.flatMap(this::findMessageByUsername)
	// In a WebFlux application the `subscriberContext` is automatically setup using `ReactorContextWebFilter`
	.contextWrite(ReactiveSecurityContextHolder.withAuthentication(authentication));
StepVerifier.create(messageByUsername)
	.expectNext("Hi user")
	.verifyComplete();
val authentication: Authentication = TestingAuthenticationToken("user", "password", "ROLE_USER")
val messageByUsername: Mono<String> = ReactiveSecurityContextHolder.getContext()
	.flatMap(this::findMessageByUsername) // In a WebFlux application the `subscriberContext` is automatically setup using `ReactorContextWebFilter`
	.verifyComplete()
Where this::findMessageByUsername is defined as:spring-doc.cn
Mono<String> findMessageByUsername(String username) {
	return Mono.just("Hi " + username);
fun findMessageByUsername(username: String): Mono<String> {
	return Mono.just("Hi $username")
The following minimal method security configures method security in reactive applications:spring-doc.cn
public class SecurityConfig {
	public MapReactiveUserDetailsService userDetailsService() {
		User.UserBuilder userBuilder = User.withDefaultPasswordEncoder();
		UserDetails rob = userBuilder.username("rob")
			.password("rob")
			.roles("USER")
		UserDetails admin = userBuilder.username("admin")
			.password("admin")
			.roles("USER","ADMIN")
		return new MapReactiveUserDetailsService(rob, admin);
	fun userDetailsService(): MapReactiveUserDetailsService {
		val userBuilder: User.UserBuilder = User.withDefaultPasswordEncoder()
		val rob = userBuilder.username("rob")
			.password("rob")
			.roles("USER")
			.build()
		val admin = userBuilder.username("admin")
			.password("admin")
			.roles("USER", "ADMIN")
			.build()
		return MapReactiveUserDetailsService(rob, admin)
Consider the following class:spring-doc.cn
@Component
public class HelloWorldMessageService {
	@PreAuthorize("hasRole('ADMIN')")
	public Mono<String> findMessage() {
		return Mono.just("Hello World!");
@Component
	fun findMessage(): Mono<String> {
Alternatively, the following class uses Kotlin coroutines:spring-doc.cn
@Component
    suspend fun findMessage(): String {
        delay(10)
        return "Hello World!"
Combined with our configuration above, @PreAuthorize("hasRole('ADMIN')") ensures that findByMessage is invoked only by a user with the ADMIN role. Note that any of the expressions in standard method security work for @EnableReactiveMethodSecurity. However, at this time, we support only a return type of Boolean or boolean of the expression. This means that the expression must not block.spring-doc.cn
When integrating with WebFlux Security, the Reactor Context is automatically established by Spring Security according to the authenticated user:spring-doc.cn
@EnableWebFluxSecurity
	SecurityWebFilterChain springWebFilterChain(ServerHttpSecurity http) throws Exception {
		return http
			// Demonstrate that method security works
			// Best practice to use both for defense in depth
			.authorizeExchange(exchanges -> exchanges
				.anyExchange().permitAll()
			.httpBasic(withDefaults())
			.password("rob")
			.roles("USER")
			.password("admin")
	open fun springWebFilterChain(http: ServerHttpSecurity): SecurityWebFilterChain {
		return http {
			authorizeExchange {
				authorize(anyExchange, permitAll)
			httpBasic { }
			.password("rob")
			.roles("USER")
			.build()
			.password("admin")
			.build()
You can find a complete sample in hellowebflux-method.spring-doc.cn
