此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 Spring for Apache Kafka 3.3.6spring-doc.cadn.net.cn
将 Spring Bean 连接到生产者/消费者拦截器
Apache Kafka 提供了一种向生产者和使用者添加拦截器的机制。 这些对象由 Kafka 而不是 Spring 管理,因此普通的 Spring 依赖注入不适用于依赖的 Spring Bean 中的连接。 但是,您可以使用拦截器手动连接这些依赖项config()方法。 下面的 Spring Boot 应用程序展示了如何通过覆盖 Spring Boot 的默认工厂以将一些依赖的 bean 添加到配置属性中来做到这一点。spring-doc.cadn.net.cn
@SpringBootApplication
public class Application {
        SpringApplication.run(Application.class, args);
    public ConsumerFactory<?, ?> kafkaConsumerFactory(SomeBean someBean) {
        Map<String, Object> consumerProperties = new HashMap<>();
        // consumerProperties.put(..., ...)
        consumerProperties.put(ConsumerConfig.INTERCEPTOR_CLASSES_CONFIG, MyConsumerInterceptor.class.getName());
        consumerProperties.put("some.bean", someBean);
        return new DefaultKafkaConsumerFactory<>(consumerProperties);
    public ProducerFactory<?, ?> kafkaProducerFactory(SomeBean someBean) {
        Map<String, Object> producerProperties = new HashMap<>();
        // producerProperties.put(..., ...)
        producerProperties.put(ProducerConfig.INTERCEPTOR_CLASSES_CONFIG, MyProducerInterceptor.class.getName());
        producerProperties.put("some.bean", someBean);
        return new DefaultKafkaProducerFactory<>(producerProperties);
    public SomeBean someBean() {
        return new SomeBean();
    @KafkaListener(id = "kgk897", topics = "kgh897")
    public void listen(String in) {
        System.out.println("Received " + in);
    public ApplicationRunner runner(KafkaTemplate<String, String> template) {
        return args -> template.send("kgh897", "test");
    public NewTopic kRequests() {
        return TopicBuilder.name("kgh897")
            .partitions(1)
            .replicas(1)
public class SomeBean {
    public void someMethod(String what) {
        System.out.println(what + " in my foo bean");
public class MyProducerInterceptor implements ProducerInterceptor<String, String> {
    private SomeBean bean;
    public void configure(Map<String, ?> configs) {
        this.bean = (SomeBean) configs.get("some.bean");
    public ProducerRecord<String, String> onSend(ProducerRecord<String, String> record) {
        this.bean.someMethod("producer interceptor");
        return record;
    public void onAcknowledgement(RecordMetadata metadata, Exception exception) {
    public void close() {
public class MyConsumerInterceptor implements ConsumerInterceptor<String, String> {
    public ConsumerRecords<String, String> onConsume(ConsumerRecords<String, String> records) {
        this.bean.someMethod("consumer interceptor");
        return records;
    public void onCommit(Map<TopicPartition, OffsetAndMetadata> offsets) {
producer interceptor in my foo bean
consumer interceptor in my foo bean
Received test
