For the latest stable version, please use Spring for Apache Kafka 3.3.6! |
Topic/Partition Initial Offset
There are several ways to set the initial offset for a partition.
When manually assigning partitions, you can set the initial offset (if desired) in the configured TopicPartitionOffset
arguments (see Message Listener Containers).
You can also seek to a specific offset at any time.
When you use group management where the broker assigns partitions:
For a new
group.id
, the initial offset is determined by theauto.offset.reset
consumer property (earliest
orlatest
For an existing group ID, the initial offset is the current offset for that group ID. You can, however, seek to a specific offset during initialization (or at any time thereafter).
