For the latest stable version, please use Spring for Apache Kafka 3.3.6! |
@KafkaListener
@Payload
Validation
Starting with version 2.2, it is now easier to add a Validator
to validate @KafkaListener
@Payload
arguments.
Previously, you had to configure a custom DefaultMessageHandlerMethodFactory
and add it to the registrar.
Now, you can add the validator to the registrar itself.
The following code shows how to do so:
@EnableKafka
public class Config implements KafkaListenerConfigurer {
public void configureKafkaListeners(KafkaListenerEndpointRegistrar registrar) {
registrar.setValidator(new MyValidator());
When you use Spring Boot with the validation starter, a LocalValidatorFactoryBean is auto-configured, as the following example shows:
@EnableKafka
@Autowired
private LocalValidatorFactoryBean validator;
registrar.setValidator(this.validator);
The following examples show how to validate:
public static class ValidatedClass {
@Max(10)
private int bar;
public int getBar() {
return this.bar;
public void setBar(int bar) {
this.bar = bar;
@KafkaListener(id="validated", topics = "annotated35", errorHandler = "validationErrorHandler",
containerFactory = "kafkaJsonListenerContainerFactory")
public void validatedListener(@Payload @Valid ValidatedClass val) {
public KafkaListenerErrorHandler validationErrorHandler() {
return (m, e) -> {
Starting with version 2.5.11, validation now works on payloads for @KafkaHandler
methods in a class-level listener.
See @KafkaListener
on a Class.
Starting with version 3.1, you can perform validation in an ErrorHandlingDeserializer
instead.
See Using ErrorHandlingDeserializer
for more information.
