For the latest stable version, please use Spring for Apache Kafka 3.3.6! |
JAAS and Kerberos
Starting with version 2.0, a KafkaJaasLoginModuleInitializer
class has been added to assist with Kerberos configuration.
You can add this bean, with the desired configuration, to your application context.
The following example configures such a bean:
public KafkaJaasLoginModuleInitializer jaasConfig() throws IOException {
KafkaJaasLoginModuleInitializer jaasConfig = new KafkaJaasLoginModuleInitializer();
jaasConfig.setControlFlag("REQUIRED");
Map<String, String> options = new HashMap<>();
options.put("useKeyTab", "true");
options.put("storeKey", "true");
options.put("keyTab", "/etc/security/keytabs/kafka_client.keytab");
options.put("principal", "[email protected]");
jaasConfig.setOptions(options);
return jaasConfig;
