For the latest stable version, please use Spring for Apache Kafka 3.3.6! |
Configuring Topics
If you define a KafkaAdmin
bean in your application context, it can automatically add topics to the broker.
To do so, you can add a NewTopic
for each topic to the application context.
Version 2.3 introduced a new class TopicBuilder
to make creation of such beans more convenient.
The following example shows how to do so:
Java
Kotlin
public KafkaAdmin admin() {
Map<String, Object> configs = new HashMap<>();
configs.put(AdminClientConfig.BOOTSTRAP_SERVERS_CONFIG, "localhost:9092");
return new KafkaAdmin(configs);
public NewTopic topic1() {
return TopicBuilder.name("thing1")
.partitions(10)
.replicas(3)
.compact()
public NewTopic topic2() {
return TopicBuilder.name("thing2")
.partitions(10)
.replicas(3)
.config(TopicConfig.COMPRESSION_TYPE_CONFIG, "zstd")
public NewTopic topic3() {
return TopicBuilder.name("thing3")
.assignReplicas(0, List.of(0, 1))
.assignReplicas(1, List.of(1, 2))
.assignReplicas(2, List.of(2, 0))
fun admin() = KafkaAdmin(mapOf(AdminClientConfig.BOOTSTRAP_SERVERS_CONFIG to "localhost:9092"))
fun topic1() =
.partitions(10)
.replicas(3)
.compact()
.build()
fun topic2() =
.partitions(10)
.replicas(3)
.build()
fun topic3() =
.assignReplicas(0, Arrays.asList(0, 1))
.assignReplicas(1, Arrays.asList(1, 2))
.assignReplicas(2, Arrays.asList(2, 0))
.build()
Starting with version 2.6, you can omit partitions()
and/or replicas()
and the broker defaults will be applied to those properties.
The broker version must be at least 2.4.0 to support this feature - see KIP-464.
Java
Kotlin
public NewTopic topic4() {
return TopicBuilder.name("defaultBoth")
public NewTopic topic5() {
return TopicBuilder.name("defaultPart")
.replicas(1)
public NewTopic topic6() {
return TopicBuilder.name("defaultRepl")
.partitions(3)
fun topic4() = TopicBuilder.name("defaultBoth").build()
fun topic5() = TopicBuilder.name("defaultPart").replicas(1).build()
fun topic6() = TopicBuilder.name("defaultRepl").partitions(3).build()
Starting with version 2.7, you can declare multiple NewTopic
s in a single KafkaAdmin.NewTopics
bean definition:
Java
Kotlin
public KafkaAdmin.NewTopics topics456() {
return new NewTopics(
.build(),
.replicas(1)
.build(),
.partitions(3)
.build());
fun topics456() = KafkaAdmin.NewTopics(
.build(),
.replicas(1)
.build(),
.partitions(3)
.build()
When using Spring Boot, a KafkaAdmin bean is automatically registered so you only need the NewTopic (and/or NewTopics ) @Bean s.
By default, if the broker is not available, a message is logged, but the context continues to load.
You can programmatically invoke the admin’s initialize()
method to try again later.
If you wish this condition to be considered fatal, set the admin’s fatalIfBrokerNotAvailable
property to true
The context then fails to initialize.
If the broker supports it (1.0.0 or higher), the admin increases the number of partitions if it is found that an existing topic has fewer partitions than the NewTopic.numPartitions .
Starting with version 2.7, the KafkaAdmin
provides methods to create and examine topics at runtime.
createOrModifyTopics
describeTopics
For more advanced features, you can use the AdminClient
directly.
@Autowired
private KafkaAdmin admin;
AdminClient client = AdminClient.create(admin.getConfigurationProperties());
client.close();
Starting with versions 2.9.10, 3.0.9, you can provide a Predicate<NewTopic>
which can be used to determine whether a particular NewTopic
bean should be considered for creation or modification.
This is useful, for example, if you have multiple KafkaAdmin
instances pointing to different clusters and you wish to select those topics that should be created or modified by each admin.
admin.setCreateOrModifyTopic(nt -> !nt.name().equals("dontCreateThisOne"));
