This version is still in development and is not considered stable yet. For the latest stable version, please use spring-cloud-contract 4.2.1! |
Stub Runner JUnit Rule and Stub Runner JUnit5 Extension
Stub Runner comes with a JUnit rule that lets you can download and run stubs for a given group and artifact ID, as the following example shows:
@ClassRule
public static StubRunnerRule rule = new StubRunnerRule().repoRoot(repoRoot())
.stubsMode(StubRunnerProperties.StubsMode.REMOTE)
.downloadStub("org.springframework.cloud.contract.verifier.stubs", "loanIssuance")
.downloadStub("org.springframework.cloud.contract.verifier.stubs:fraudDetectionServer");
@BeforeClass
@AfterClass
public static void setupProps() {
System.clearProperty("stubrunner.repository.root");
System.clearProperty("stubrunner.classifier");
A StubRunnerExtension
is also available for JUnit 5. StubRunnerRule
and
StubRunnerExtension
work in a very similar fashion. After the rule or extension is
called, Stub Runner connects to your Maven repository and, for the given list of
dependencies, tries to:
Download them
Cache them locally
Unzip them to a temporary folder
Start a WireMock server for each Maven dependency on a random port from the provided range of ports or the provided port
Feed the WireMock server with all JSON files that are valid WireMock definitions
Send messages (remember to pass an implementation of
MessageVerifierSender
interface)
Stub Runner uses the Eclipse Aether mechanism to download the Maven dependencies. Check their docs for more information.
Since the StubRunnerRule
and StubRunnerExtension
implement the StubFinder
, they let
you find the started stubs, as the following example shows:
import java.net.URL;
import java.util.Collection;
import java.util.Map;
import org.springframework.cloud.contract.spec.Contract;
* Contract for finding registered stubs.
* @author Marcin Grzejszczak
public interface StubFinder extends StubTrigger {
* For the given groupId and artifactId tries to find the matching URL of the running
* stub.
* @param groupId - might be null. In that case a search only via artifactId takes
* place
* @param artifactId - artifact id of the stub
* @return URL of a running stub or throws exception if not found
* @throws StubNotFoundException in case of not finding a stub
URL findStubUrl(String groupId, String artifactId) throws StubNotFoundException;
* For the given Ivy notation {@code [groupId]:artifactId:[version]:[classifier]}
* tries to find the matching URL of the running stub. You can also pass only
* {@code artifactId}.
* @param ivyNotation - Ivy representation of the Maven artifact
URL findStubUrl(String ivyNotation) throws StubNotFoundException;
* @return all running stubs
RunningStubs findAllRunningStubs();
* @return the list of Contracts
Map<StubConfiguration, Collection<Contract>> getContracts();
The following examples provide more detail about using Stub Runner:
@ClassRule
@Shared
.repoRoot(StubRunnerRuleSpec.getResource("/m2repo/repository").toURI().toString())
.withMappingsOutputFolder("target/outputmappingsforrule")
def 'should start WireMock servers'() {
expect: 'WireMocks are running'
rule.findStubUrl('org.springframework.cloud.contract.verifier.stubs', 'loanIssuance') != null
rule.findStubUrl('loanIssuance') != null
rule.findStubUrl('loanIssuance') == rule.findStubUrl('org.springframework.cloud.contract.verifier.stubs', 'loanIssuance')
rule.findStubUrl('org.springframework.cloud.contract.verifier.stubs:fraudDetectionServer') != null
and:
rule.findAllRunningStubs().isPresent('loanIssuance')
rule.findAllRunningStubs().isPresent('org.springframework.cloud.contract.verifier.stubs', 'fraudDetectionServer')
rule.findAllRunningStubs().isPresent('org.springframework.cloud.contract.verifier.stubs:fraudDetectionServer')
and: 'Stubs were registered'
"${rule.findStubUrl('loanIssuance').toString()}/name".toURL().text == 'loanIssuance'
"${rule.findStubUrl('fraudDetectionServer').toString()}/name".toURL().text == 'fraudDetectionServer'
def 'should output mappings to output folder'() {
when:
def url = rule.findStubUrl('fraudDetectionServer')
then:
new File("target/outputmappingsforrule", "fraudDetectionServer_${url.port}").exists()
@Test
public void should_start_wiremock_servers() throws Exception {
// expect: 'WireMocks are running'
then(rule.findStubUrl("org.springframework.cloud.contract.verifier.stubs", "loanIssuance")).isNotNull();
then(rule.findStubUrl("loanIssuance")).isNotNull();
.isEqualTo(rule.findStubUrl("org.springframework.cloud.contract.verifier.stubs", "loanIssuance"));
then(rule.findStubUrl("org.springframework.cloud.contract.verifier.stubs:fraudDetectionServer")).isNotNull();
// and:
then(rule.findAllRunningStubs().isPresent("loanIssuance")).isTrue();
.isPresent("org.springframework.cloud.contract.verifier.stubs", "fraudDetectionServer")).isTrue();
.isPresent("org.springframework.cloud.contract.verifier.stubs:fraudDetectionServer")).isTrue();
// and: 'Stubs were registered'
then(httpGet(rule.findStubUrl("loanIssuance").toString() + "/name")).isEqualTo("loanIssuance");
then(httpGet(rule.findStubUrl("fraudDetectionServer").toString() + "/name")).isEqualTo("fraudDetectionServer");
// Visible for Junit
@RegisterExtension
static StubRunnerExtension stubRunnerExtension = new StubRunnerExtension().repoRoot(repoRoot())
.withMappingsOutputFolder("target/outputmappingsforrule");
@BeforeAll
@AfterAll
private static String repoRoot() {
try {
return StubRunnerRuleJUnitTest.class.getResource("/m2repo/repository/").toURI().toString();
catch (Exception e) {
return "";
See the Common Properties for JUnit and Spring for more information on how to apply global configuration of Stub Runner.
To use the JUnit rule or JUnit 5 extension together with messaging, you have to provide an implementation of the
MessageVerifierSender and MessageVerifierReceiver interface to the rule builder (for example, rule.messageVerifierSender(new MyMessageVerifierSender()) ).
If you do not do this, then, whenever you try to send a message, an exception is thrown.
Maven Settings
The stub downloader honors Maven settings for a different local repository folder. Authentication details for repositories and profiles are currently not taken into account, so you need to specify it by using the properties mentioned above.
Providing Fixed Ports
You can also run your stubs on fixed ports. You can do it in two different ways. One is to pass it in the properties, and the other is to use the fluent API of JUnit rule.
Fluent API
When using the StubRunnerRule
or StubRunnerExtension
, you can add a stub to download
and then pass the port for the last downloaded stub. The following example shows how to do so:
@ClassRule
.withPort(35465)
.downloadStub("org.springframework.cloud.contract.verifier.stubs:fraudDetectionServer:35466");
@BeforeClass
@AfterClass
For the preceding example, the following test is valid:
then(rule.findStubUrl("loanIssuance")).isEqualTo(URI.create("http://localhost:35465").toURL());
then(rule.findStubUrl("fraudDetectionServer")).isEqualTo(URI.create("http://localhost:35466").toURL());
Stub Runner with Spring
Stub Runner with Spring sets up Spring configuration of the Stub Runner project.
By providing a list of stubs inside your configuration file, Stub Runner automatically downloads and registers in WireMock the selected stubs.
If you want to find the URL of your stubbed dependency, you can autowire the StubFinder
interface and use
its methods, as follows:
@SpringBootTest(classes = Config, properties = [" stubrunner.cloud.enabled=false",
'foo=${stubrunner.runningstubs.fraudDetectionServer.port}',
'fooWithGroup=${stubrunner.runningstubs.org.springframework.cloud.contract.verifier.stubs.fraudDetectionServer.port}'])
@AutoConfigureStubRunner(mappingsOutputFolder = "target/outputmappings/",
httpServerStubConfigurer = HttpsForFraudDetection)
@ActiveProfiles("test")
class StubRunnerConfigurationSpec {
@Autowired
StubFinder stubFinder
@Autowired
Environment environment
@StubRunnerPort("fraudDetectionServer")
int fraudDetectionServerPort
@StubRunnerPort("org.springframework.cloud.contract.verifier.stubs:fraudDetectionServer")
int fraudDetectionServerPortWithGroupId
@Value('${foo}')
Integer foo
@BeforeAll
static void setupSpec() {
WireMockHttpServerStubAccessor.clear()
@AfterAll
static void cleanupSpec() {
setupSpec()
@Test
void 'should mark all ports as random'() {
expect:
WireMockHttpServerStubAccessor.everyPortRandom()
@Test
void 'should start WireMock servers'() {
assert stubFinder.findStubUrl('org.springframework.cloud.contract.verifier.stubs', 'loanIssuance') != null
assert stubFinder.findStubUrl('loanIssuance') != null
assert stubFinder.findStubUrl('loanIssuance') == stubFinder.findStubUrl('org.springframework.cloud.contract.verifier.stubs', 'loanIssuance')
assert stubFinder.findStubUrl('loanIssuance') == stubFinder.findStubUrl('org.springframework.cloud.contract.verifier.stubs:loanIssuance')
assert stubFinder.findStubUrl('org.springframework.cloud.contract.verifier.stubs:loanIssuance:0.0.1-SNAPSHOT') == stubFinder.findStubUrl('org.springframework.cloud.contract.verifier.stubs:loanIssuance:0.0.1-SNAPSHOT:stubs')
assert stubFinder.findStubUrl('org.springframework.cloud.contract.verifier.stubs:fraudDetectionServer') != null
and:
assert stubFinder.findAllRunningStubs().isPresent('loanIssuance')
assert stubFinder.findAllRunningStubs().isPresent('org.springframework.cloud.contract.verifier.stubs', 'fraudDetectionServer')
assert stubFinder.findAllRunningStubs().isPresent('org.springframework.cloud.contract.verifier.stubs:fraudDetectionServer')
assert "${stubFinder.findStubUrl('loanIssuance').toString()}/name".toURL().text == 'loanIssuance'
assert "${stubFinder.findStubUrl('fraudDetectionServer').toString()}/name".toURL().text == 'fraudDetectionServer'
and: 'Fraud Detection is an HTTPS endpoint'
assert stubFinder.findStubUrl('fraudDetectionServer').toString().startsWith("https")
@Test
void 'should throw an exception when stub is not found'() {
when:
BDDAssertions.thenThrownBy(() -> stubFinder.findStubUrl('nonExistingService')).isInstanceOf(StubNotFoundException)
when:
BDDAssertions.thenThrownBy(() -> stubFinder.findStubUrl('nonExistingGroupId', 'nonExistingArtifactId'))
@Test
void 'should register started servers as environment variables'() {
expect:
assert environment.getProperty("stubrunner.runningstubs.loanIssuance.port") != null
assert stubFinder.findAllRunningStubs().getPort("loanIssuance") == (environment.getProperty("stubrunner.runningstubs.loanIssuance.port") as Integer)
and:
assert environment.getProperty("stubrunner.runningstubs.fraudDetectionServer.port") != null
assert stubFinder.findAllRunningStubs().getPort("fraudDetectionServer") == (environment.getProperty("stubrunner.runningstubs.fraudDetectionServer.port") as Integer)
and:
assert stubFinder.findAllRunningStubs().getPort("fraudDetectionServer") == (environment.getProperty("stubrunner.runningstubs.org.springframework.cloud.contract.verifier.stubs.fraudDetectionServer.port") as Integer)
@Test
void 'should be able to interpolate a running stub in the passed test property'() {
given:
int fraudPort = stubFinder.findAllRunningStubs().getPort("fraudDetectionServer")
expect:
assert fraudPort > 0
assert environment.getProperty("foo", Integer) == fraudPort
assert environment.getProperty("fooWithGroup", Integer) == fraudPort
assert foo == fraudPort
// @Issue("#573")
@Test
void 'should be able to retrieve the port of a running stub via an annotation'() {
given:
expect:
assert fraudDetectionServerPort == fraudPort
assert fraudDetectionServerPortWithGroupId == fraudPort
@Test
void 'should dump all mappings to a file'() {
when:
def url = stubFinder.findStubUrl("fraudDetectionServer")
then:
assert new File("target/outputmappings/", "fraudDetectionServer_${url.port}").exists()
@EnableAutoConfiguration
static class Config {}
@CompileStatic
static class HttpsForFraudDetection extends WireMockHttpServerStubConfigurer {
private static final Log log = LogFactory.getLog(HttpsForFraudDetection)
WireMockConfiguration configure(WireMockConfiguration httpStubConfiguration, HttpServerStubConfiguration httpServerStubConfiguration) {
if (httpServerStubConfiguration.stubConfiguration.artifactId == "fraudDetectionServer") {
int httpsPort = TestSocketUtils.findAvailableTcpPort()
log.info("Will set HTTPs port [" + httpsPort + "] for fraud detection server")
return httpStubConfiguration
.httpsPort(httpsPort)
Doing so depends on the following configuration file:
stubrunner:
repositoryRoot: classpath:m2repo/repository/
ids:
- org.springframework.cloud.contract.verifier.stubs:loanIssuance
- org.springframework.cloud.contract.verifier.stubs:fraudDetectionServer
- org.springframework.cloud.contract.verifier.stubs:bootService
stubs-mode: remote
Instead of using the properties, you can also use the properties inside the @AutoConfigureStubRunner
The following example achieves the same result by setting values on the annotation:
@AutoConfigureStubRunner(ids = ["org.springframework.cloud.contract.verifier.stubs:loanIssuance",
"org.springframework.cloud.contract.verifier.stubs:fraudDetectionServer",
"org.springframework.cloud.contract.verifier.stubs:bootService"] ,
stubsMode = StubRunnerProperties.StubsMode.REMOTE ,
repositoryRoot = "classpath:m2repo/repository/" )
Stub Runner Spring registers environment variables in the following manner
for every registered WireMock server. The following example shows Stub Runner IDs for
com.example:thing1
and com.example:thing2
stubrunner.runningstubs.thing1.port
stubrunner.runningstubs.com.example.thing1.port
stubrunner.runningstubs.thing2.port
stubrunner.runningstubs.com.example.thing2.port
You can reference these values in your code.
You can also use the @StubRunnerPort
annotation to inject the port of a running stub.
The value of the annotation can be the groupid:artifactid
or only the artifactid
The following example works shows Stub Runner IDs for
com.example:thing1
@StubRunnerPort("thing1")
int thing1Port;
@StubRunnerPort("com.example:thing2")
int thing2Port;
