This version is still in development and is not considered stable yet. For the latest stable version, please use spring-cloud-contract 4.2.1! |
How Can I Generate YAML, or X files from Spring Cloud Contract Contracts?
Spring Cloud Contract comes with a ToFileContractsTransformer
class that lets you dump
contracts as files for the given ContractConverter
. It contains a static void main
method that lets you run the transformer as an executable. It takes the following
arguments:
argument 1 :
FQN
: Fully qualified name of theContractConverter
(for example,PactContractConverter
). REQUIRED. -
argument 2 :
path
: Path where the dumped files should be stored. OPTIONAL — defaults totarget/converted-contracts
argument 3 :
path
: Path were the contracts should be searched for. OPTIONAL — defaults tosrc/test/resources/contracts
After calling the transformer, the Spring Cloud Contract files are processed and,
depending on the provided FQN of the ContractTransformer
, the contracts are transformed
to the required format and dumped to the provided folder.
