This version is still in development and is not considered stable yet. For the latest stable version, please use spring-cloud-contract 4.2.1! |
GraphQL
Since GraphQL is essentially HTTP you can write a contract for it by creating a standard HTTP contract with an additional metadata
entry with key verifier
and a mapping tool=graphql
import org.springframework.cloud.contract.spec.Contract
Contract.make {
request {
method(POST())
url("/graphql")
headers {
contentType("application/json")
body('''
"query":"query queryName($personName: String!) {\\n personToCheck(name: $personName) {\\n name\\n age\\n }\\n}\\n\\n\\n\\n",
"variables":{"personName":"Old Enough"},
"operationName":"queryName"
response {
status(200)
headers {
body('''\
"data": {
"personToCheck": {
"name": "Old Enough",
"age": "40"
metadata(verifier: [
tool: "graphql"
request:
method: "POST"
url: "/graphql"
headers:
Content-Type: "application/json"
body:
query: "query queryName($personName: String!) { personToCheck(name: $personName)
{ name age } }"
variables:
personName: "Old Enough"
operationName: "queryName"
matchers:
headers:
- key: "Content-Type"
regex: "application/json.*"
regexType: "as_string"
response:
status: 200
headers:
body:
data:
personToCheck:
age: "40"
matchers:
headers:
metadata:
verifier:
tool: "graphql"
Adding the metadata section will change the way the default, WireMock stub is built. It will now use the Spring Cloud Contract request matcher, so that e.g. the query
part of the GraphQL request gets compared against the real request by ignoring whitespaces.
Producer Side Setup
On the producer side your configuration can look as follows.
<plugin>
<artifactId>spring-cloud-contract-maven-plugin</artifactId>
<version>${spring-cloud-contract.version}</version>
<extensions>true</extensions>
<configuration>
<testMode>EXPLICIT</testMode>
<baseClassForTests>com.example.BaseClass</baseClassForTests>
</configuration>
</plugin>
contracts {
testMode = "EXPLICIT"
baseClassForTests = "com.example.BaseClass"
The base class would set up the application running on a random port.
@SpringBootTest(classes = ProducerApplication.class,
properties = "graphql.servlet.websocket.enabled=false",
webEnvironment = SpringBootTest.WebEnvironment.RANDOM_PORT)
public abstract class BaseClass {
@LocalServerPort int port;
@BeforeEach
public void setup() {
RestAssured.baseURI = "http://localhost:" + port;
Consumer Side Setup
Example of a consumer side test of the GraphQL API.
@SpringBootTest(webEnvironment = WebEnvironment.NONE)
public class BeerControllerGraphQLTest {
@RegisterExtension
static StubRunnerExtension rule = new StubRunnerExtension()
.downloadStub("com.example","beer-api-producer-graphql")
.stubsMode(StubRunnerProperties.StubsMode.LOCAL);
private static final String REQUEST_BODY = "{\n"
+ "\"query\":\"query queryName($personName: String!) {\\n personToCheck(name: $personName) {\\n name\\n age\\n }\\n}\","
+ "\"variables\":{\"personName\":\"Old Enough\"},\n"
+ "\"operationName\":\"queryName\"\n"
@Test
public void should_send_a_graphql_request() {
ResponseEntity<String> responseEntity = new RestTemplate()
.exchange(RequestEntity
.post(URI.create("http://localhost:" + rule.findStubUrl("beer-api-producer-graphql").getPort() + "/graphql"))
.contentType(MediaType.APPLICATION_JSON)
.body(REQUEST_BODY), String.class);
BDDAssertions.then(responseEntity.getStatusCodeValue()).isEqualTo(200);
