This version is still in development and is not considered stable yet. For the latest stable version, please use spring-cloud-contract 4.2.1! |
Common Top-Level Elements
The following sections describe the most common top-level elements:
Description
You can add a description
to your contract. The description is arbitrary text. The
following code shows an example:
org.springframework.cloud.contract.spec.Contract.make {
description('''
given:
An input
when:
Sth happens
then:
Output
description: Some description
priority: 8
ignored: true
request:
url: /foo
queryParameters:
a: b
b: c
method: PUT
headers:
foo: bar
fooReq: baz
body:
foo: bar
matchers:
body:
- path: $.foo
type: by_regex
value: bar
headers:
- key: foo
regex: bar
response:
status: 200
headers:
foo2: bar
foo3: foo33
fooRes: baz
body:
foo2: bar
foo3: baz
nullValue: null
matchers:
body:
- path: $.foo2
type: by_regex
value: bar
- path: $.foo3
type: by_command
value: executeMe($it)
- path: $.nullValue
type: by_null
value: null
headers:
- key: foo2
regex: bar
- key: foo3
command: andMeToo($it)
Contract.make(c -> {
c.description("Some description");
contract {
description = """
given:
An input
when:
Sth happens
then:
Output
Name
You can provide a name for your contract. Assume that you provide the following name:
should register a user
. If you do so, the name of the autogenerated test is
validate_should_register_a_user
. Also, the name of the stub in a WireMock stub is
should_register_a_user.json
You must ensure that the name does not contain any characters that make the generated test not compile. Also, remember that, if you provide the same name for multiple contracts, your autogenerated tests fail to compile and your generated stubs override each other. |
The following example shows how to add a name to a contract:
name("some_special_name")
c.name("some name");
contract {
name = "some_special_name"
Ignoring Contracts
If you want to ignore a contract, you can either set a value for ignored contracts in the
plugin configuration or set the ignored
property on the contract itself. The following
example shows how to do so:
ignored()
ignored: true
c.ignored();
contract {
ignored = true
Contracts in Progress
A contract in progress does not generate tests on the producer side but does allow generation of stubs.
Use this feature with caution as it may lead to false positives, because you generate stubs for your consumers to use without actually having the implementation in place. |
If you want to set a contract in progress, the following example shows how to do so:
inProgress()
inProgress: true
c.inProgress();
contract {
inProgress = true
You can set the value of the failOnInProgress
Spring Cloud Contract plugin property to ensure that your build breaks when at least one contract in progress remains in your sources.
Passing Values from Files
Starting with version 1.2.0
, you can pass values from files. Assume that you have the
following resources in your project:
└── src
└── test
└── resources
└── contracts
├── readFromFile.groovy
├── request.json
└── response.json
Further assume that your contract is as follows:
* Copyright 2013-2020 the original author or authors.
* Licensed under the Apache License, Version 2.0 (the "License");
* you may not use this file except in compliance with the License.
* You may obtain a copy of the License at
* https://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
import org.springframework.cloud.contract.spec.Contract
Contract.make {
request {
method('PUT')
headers {
contentType(applicationJson())
body(file("request.json"))
url("/1")
response {
status OK()
body(file("response.json"))
headers {
request:
method: GET
url: /foo
bodyFromFile: request.json
response:
status: 200
bodyFromFile: response.json
import java.util.Collection;
import java.util.Collections;
import java.util.function.Supplier;
import org.springframework.cloud.contract.spec.Contract;
class contract_rest_from_file implements Supplier<Collection<Contract>> {
public Collection<Contract> get() {
return Collections.singletonList(Contract.make(c -> {
c.request(r -> {
r.url("/foo");
r.method(r.GET());
r.body(r.file("request.json"));
c.response(r -> {
r.status(r.OK());
r.body(r.file("response.json"));
import org.springframework.cloud.contract.spec.ContractDsl.Companion.contract
contract {
request {
url = url("/1")
method = PUT
headers {
contentType = APPLICATION_JSON
body = bodyFromFile("request.json")
response {
status = OK
body = bodyFromFile("response.json")
headers {
Further assume that the JSON files are as follows:
"status": "REQUEST"
"status": "RESPONSE"
When test or stub generation takes place, the contents of the request.json
and response.json
files are passed to the body
of a request or a response. The name of the file needs to be a file in a location
relative to the folder in which the contract resides.
If you need to pass the contents of a file in binary form,
you can use the fileAsBytes
method in the coded DSL or a bodyFromFileAsBytes
field in YAML.
The following example shows how to pass the contents of binary files:
Contract.make {
request {
url("/1")
method(PUT())
headers {
contentType(applicationOctetStream())
body(fileAsBytes("request.pdf"))
response {
status 200
body(fileAsBytes("response.pdf"))
headers {
request:
url: /1
method: PUT
headers:
Content-Type: application/octet-stream
bodyFromFileAsBytes: request.pdf
response:
status: 200
bodyFromFileAsBytes: response.pdf
headers:
class contract_rest_from_pdf implements Supplier<Collection<Contract>> {
c.request(r -> {
r.url("/1");
r.method(r.PUT());
r.body(r.fileAsBytes("request.pdf"));
r.headers(h -> {
h.contentType(h.applicationOctetStream());
c.response(r -> {
r.status(r.OK());
r.body(r.fileAsBytes("response.pdf"));
r.headers(h -> {
contract {
request {
url = url("/1")
method = PUT
headers {
contentType = APPLICATION_OCTET_STREAM
body = bodyFromFileAsBytes("contracts/request.pdf")
response {
status = OK
body = bodyFromFileAsBytes("contracts/response.pdf")
headers {
You should use this approach whenever you want to work with binary payloads, both for HTTP and messaging. |
Metadata
You can add metadata
to your contract. Via the metadata you can pass in configuration to extensions. Below you can find
an example of using the wiremock
key. Its value is a map whose key is stubMapping
and value being WireMock’s StubMapping
object. Spring Cloud Contract is able to
patch parts of your generated stub mapping with your custom code. You may want to do that in order to add webhooks, custom
delays or integrate with third party WireMock extensions.
c.metadata(MetadataUtil.map()
.entry("wiremock", ContractVerifierUtil.map()
.entry("stubMapping", "{ \"response\" : { \"fixedDelayMilliseconds\" : 2000 } }")));
contract {
metadata("wiremock" to ("stubmapping" to """
"response" : {
"fixedDelayMilliseconds": 2000
In the following sections you can find examples of the supported metadata entries.
Contracts for HTTP
Spring Cloud Contract lets you verify applications that use REST or HTTP as a
means of communication. Spring Cloud Contract verifies that, for a request that matches the
criteria from the request
part of the contract, the server provides a response that is in
keeping with the response
part of the contract. Subsequently, the contracts are used to
generate WireMock stubs that, for any request matching the provided criteria, provide a
suitable response.
