This version is still in development and is not considered stable yet. For the latest stable version, please use spring-cloud-contract 4.2.1! |
How Can I Mark that a Contract Is in Progress
If a contract is in progress, it means that the, on the producer side, tests are not generated, but the stub is generated. You can read more about this in this section of the documentation.
In a CI build, before going to production, you would like to ensure that no in-progress contracts are on the classpath, because they may lead to false positives. For this reason, by default, in the Spring Cloud Contract plugin, we set the value of failOnInProgress
to true
. If you want to allow such contracts when tests are to be generated, set the flag to false
