This version is still in development and is not considered stable yet. For the latest stable version, please use spring-cloud-contract 4.2.1!spring-doc.cn
Provider Contract Testing with Stubs in Artifactory for a non-Spring Application
In this page you will learn how to do provider contract testing with a non-Spring application and stubs uploaded to Artifactory.spring-doc.cn
The Flow
You can read Developing Your First Spring Cloud Contract-based Application to see the flow for provider contract testing with stubs in Nexus or Artifactory.spring-doc.cn
Setting up the Consumer
For the consumer side, you can use a JUnit rule. That way, you need not start a Spring context. The following listing shows such a rule (in JUnit4 and JUnit 5);spring-doc.cn
JUnit 4 Rule
@Rule
	public StubRunnerRule rule = new StubRunnerRule()
			.downloadStub("com.example","artifact-id", "0.0.1")
			.repoRoot("git://[email protected]:spring-cloud-samples/spring-cloud-contract-nodejs-contracts-git.git")
			.stubsMode(StubRunnerProperties.StubsMode.REMOTE);
JUnit 5 Extension
@RegisterExtension
	public StubRunnerExtension stubRunnerExtension = new StubRunnerExtension()
Setting up the Producer
By default, the Spring Cloud Contract Plugin uses Rest Assured’s MockMvc setup for the generated tests. Since non-Spring applications do not use MockMvc, you can change the testMode to EXPLICIT to send a real request to an application bound at a specific port.spring-doc.cn
In this example, we use a framework called Javalin to start a non-Spring HTTP server.spring-doc.cn
Assume that we have the following application:spring-doc.cn
import io.javalin.Javalin;
public class DemoApplication {
		new DemoApplication().run(7000);
	public Javalin start(int port) {
		return Javalin.create().start(port);
	public Javalin registerGet(Javalin app) {
		return app.get("/", ctx -> ctx.result("Hello World"));
	public Javalin run(int port) {
		return registerGet(start(port));
Given that application, we can set up the plugin to use the EXPLICIT mode (that is, to send out requests to a real port), as follows:spring-doc.cn
Maven
<plugin>
	<artifactId>spring-cloud-contract-maven-plugin</artifactId>
	<version>${spring-cloud-contract.version}</version>
	<extensions>true</extensions>
	<configuration>
		<baseClassForTests>com.example.demo.BaseClass</baseClassForTests>
		<!-- This will setup the EXPLICIT mode for the tests -->
		<testMode>EXPLICIT</testMode>
	</configuration>
</plugin>
Gradle
contracts {
	// This will setup the EXPLICIT mode for the tests
	testMode = "EXPLICIT"
	baseClassForTests = "com.example.demo.BaseClass"
The base class might resemble the following:spring-doc.cn
import io.restassured.RestAssured;
import org.junit.After;
import org.junit.Before;
import org.springframework.cloud.test.TestSocketUtils;
public class BaseClass {
	Javalin app;
	@Before
	public void setup() {
		// pick a random port
		int port = TestSocketUtils.findAvailableTcpPort();
		// start the application at a random port
		this.app = start(port);
		// tell Rest Assured where the started application is
		RestAssured.baseURI = "http://localhost:" + port;
	@After
	public void close() {
		// stop the server after each test
		this.app.stop();
	private Javalin start(int port) {
		// reuse the production logic to start a server
		return new DemoApplication().run(port);
With such a setup:spring-doc.cn
  • We have set up the Spring Cloud Contract plugin to use the EXPLICIT mode to send real requests instead of mocked ones.spring-doc.cn
  • We have defined a base class that:spring-doc.cn
