This version is still in development and is not considered stable yet. For the latest stable version, please use spring-cloud-contract 4.2.1!spring-doc.cn
Messaging
Spring Cloud Contract lets you verify applications that use messaging as a means of communication. All of the integrations shown in this document work with Spring, but you can also create one of your own and use that.spring-doc.cn
Messaging DSL Top-level Elements
The DSL for messaging looks a little bit different than the one that focuses on HTTP. The following sections explain the differences:spring-doc.cn
Output Triggered by a Method
The output message can be triggered by calling a method (such as a Scheduler when a contract was started and when a message was sent), as shown in the following example:spring-doc.cn
Groovy
def dsl = Contract.make {
	// Human readable description
	description 'Some description'
	// Label by means of which the output message can be triggered
	label 'some_label'
	// input to the contract
	input {
		// the contract will be triggered by a method
		triggeredBy('bookReturnedTriggered()')
	// output message of the contract
	outputMessage {
		// destination to which the output message will be sent
		sentTo('output')
		// the body of the output message
		body('''{ "bookName" : "foo" }''')
		// the headers of the output message
		headers {
			header('BOOK-NAME', 'foo')
YAML
# Human readable description
description: Some description
# Label by means of which the output message can be triggered
label: some_label
input:
  # the contract will be triggered by a method
  triggeredBy: bookReturnedTriggered()
# output message of the contract
outputMessage:
  # destination to which the output message will be sent
  sentTo: output
  # the body of the output message
  body:
    bookName: foo
  # the headers of the output message
  headers:
    BOOK-NAME: foo
In the previous example case, the output message is sent to output if a method called bookReturnedTriggered is invoked. On the message publisher’s side, we generate a test that calls that method to trigger the message. On the consumer side, you can use some_label to trigger the message.spring-doc.cn
Consumer/Producer
This section is valid only for the Groovy DSL.
In HTTP, you have a notion of client/stub and `server/test notation. You can also use those paradigms in messaging. In addition, Spring Cloud Contract Verifier also provides the consumer and producer methods (note that you can use either $ or value methods to provide consumer and producer parts).spring-doc.cn
Common
In the input or outputMessage section, you can call assertThat with the name of a method (for example, assertThatMessageIsOnTheQueue()) that you have defined in the base class or in a static import. Spring Cloud Contract runs that method in the generated test.spring-doc.cn
Integrations
You can use one of the following integration configurations:spring-doc.cn
Since we use Spring Boot, if you have added one of these libraries to the classpath, all the messaging configuration is automatically set up.spring-doc.cn
Remember to put @AutoConfigureMessageVerifier on the base class of your generated tests. Otherwise, the messaging part of Spring Cloud Contract does not work.
If you want to use Spring Cloud Stream, remember to add a test dependency on org.springframework.cloud:spring-cloud-stream, as follows:spring-doc.cn
Maven
<dependency>
    <artifactId>spring-cloud-stream</artifactId>
    <type>test-jar</type>
    <scope>test</scope>
    <classifier>test-binder</classifier>
</dependency>
Gradle
testImplementation(group: 'org.springframework.cloud', name: 'spring-cloud-stream', classifier: 'test-binder')
Manual Integration Testing
The main interface used by the tests is org.springframework.cloud.contract.verifier.messaging.MessageVerifierSender and org.springframework.cloud.contract.verifier.messaging.MessageVerifierReceiver. It defines how to send and receive messages.spring-doc.cn
In a test, you can inject a ContractVerifierMessageExchange to send and receive messages that follow the contract. Then add @AutoConfigureMessageVerifier to your test. The following example shows how to do so:spring-doc.cn
@RunWith(SpringTestRunner.class)
@SpringBootTest
public static class MessagingContractTests {
  @Autowired
  private MessageVerifier verifier;
If your tests require stubs as well, then @AutoConfigureStubRunner includes the messaging configuration, so you only need the one annotation.
Producer Side Messaging Test Generation
Having the input or outputMessage sections in your DSL results in creation of tests on the publisher’s side. By default, JUnit 4 tests are created. However, there is also a possibility to create JUnit 5, TestNG, or Spock tests.spring-doc.cn
The destination passed to messageFrom or sentTo can have different meanings for different messaging implementations. For Stream and Integration, it is first resolved as a destination of a channel. Then, if there is no such destination, it is resolved as a channel name. For Camel, that’s a certain component (for example, jms).
Consider the following contract:spring-doc.cn
Groovy
def contractDsl = Contract.make {
	name "foo"
	label 'some_label'
	input {
	outputMessage {
		sentTo('activemq:output')
		headers {
			messagingContentType(applicationJson())
YAML
label: some_label
input:
outputMessage:
  sentTo: activemq:output
  body:
    bookName: foo
  headers:
    BOOK-NAME: foo
    contentType: application/json
For the preceding example, the following test would be created:spring-doc.cn
JUnit
import com.jayway.jsonpath.DocumentContext;
import com.jayway.jsonpath.JsonPath;
import org.junit.Test;
import org.junit.Rule;
import javax.inject.Inject;
import org.springframework.cloud.contract.verifier.messaging.internal.ContractVerifierObjectMapper;
import org.springframework.cloud.contract.verifier.messaging.internal.ContractVerifierMessage;
import org.springframework.cloud.contract.verifier.messaging.internal.ContractVerifierMessaging;
import static org.springframework.cloud.contract.verifier.assertion.SpringCloudContractAssertions.assertThat;
import static org.springframework.cloud.contract.verifier.util.ContractVerifierUtil.*;
import static com.toomuchcoding.jsonassert.JsonAssertion.assertThatJson;
import static org.springframework.cloud.contract.verifier.messaging.util.ContractVerifierMessagingUtil.headers;
import static org.springframework.cloud.contract.verifier.util.ContractVerifierUtil.fileToBytes;
public class FooTest {
	@Inject ContractVerifierMessaging contractVerifierMessaging;
	@Inject ContractVerifierObjectMapper contractVerifierObjectMapper;
	@Test
	public void validate_foo() throws Exception {
		// when:
			bookReturnedTriggered();
		// then:
			ContractVerifierMessage response = contractVerifierMessaging.receive("activemq:output",
					contract(this, "foo.yml"));
			assertThat(response).isNotNull();
		// and:
			assertThat(response.getHeader("BOOK-NAME")).isNotNull();
			assertThat(response.getHeader("BOOK-NAME").toString()).isEqualTo("foo");
			assertThat(response.getHeader("contentType")).isNotNull();
			assertThat(response.getHeader("contentType").toString()).isEqualTo("application/json");
		// and:
			DocumentContext parsedJson = JsonPath.parse(contractVerifierObjectMapper.writeValueAsString(response.getPayload()));
			assertThatJson(parsedJson).field("['bookName']").isEqualTo("foo");
Spock
import spock.lang.Specification
class FooSpec extends Specification {
	def validate_foo() throws Exception {
		when:
		then:
			response != null
		and:
			response.getHeader("BOOK-NAME") != null
			response.getHeader("BOOK-NAME").toString() == 'foo'
			response.getHeader("contentType") != null
			response.getHeader("contentType").toString() == 'application/json'
		and:
Consumer Stub Generation
Unlike in the HTTP part, in messaging, we need to publish the contract definition inside the JAR with a stub. Then it is parsed on the consumer side, and proper stubbed routes are created.spring-doc.cn
If you have multiple frameworks on the classpath, Stub Runner needs to define which one should be used. Assume that you have AMQP, Spring Cloud Stream, and Spring Integration on the classpath and that you want to use Spring AMQP. Then you need to set stubrunner.stream.enabled=false and stubrunner.integration.enabled=false. That way, the only remaining framework is Spring AMQP.
Stub triggering
To trigger a message, use the StubTrigger interface, as the following example shows:spring-doc.cn
import java.util.Collection;
import java.util.Map;
 * Contract for triggering stub messages.
 * @author Marcin Grzejszczak
public interface StubTrigger {
	 * Triggers an event by a given label for a given {@code groupid:artifactid} notation.
	 * You can use only {@code artifactId} too.
	 * Feature related to messaging.
	 * @param ivyNotation ivy notation of a stub
	 * @param labelName name of the label to trigger
	 * @return true - if managed to run a trigger
	boolean trigger(String ivyNotation, String labelName);
	 * Triggers an event by a given label.
	boolean trigger(String labelName);
	 * Triggers all possible events.
	boolean trigger();
	 * @return a mapping of ivy notation of a dependency to all the labels it has.
	Map<String, Collection<String>> labels();
For convenience, the StubFinder interface extends StubTrigger, so you need only one or the other in your tests.spring-doc.cn
StubTrigger gives you the following options to trigger a message:spring-doc.cn
Trigger by Label
The following example shows how to trigger a message with a label:spring-doc.cn
stubFinder.trigger('return_book_1')
Trigger by Group and Artifact IDs
The following example shows how to trigger a message by group and artifact IDs:spring-doc.cn
stubFinder.trigger('org.springframework.cloud.contract.verifier.stubs:streamService', 'return_book_1')
Trigger by Artifact IDs
The following example shows how to trigger a message from artifact IDs:spring-doc.cn
stubFinder.trigger('streamService', 'return_book_1')
Trigger All Messages
The following example shows how to trigger all messages:spring-doc.cn
stubFinder.trigger()
Consumer Side Messaging With Apache Camel
Spring Cloud Contract Stub Runner’s messaging module gives you an easy way to integrate with Apache Camel. For the provided artifacts, it automatically downloads the stubs and registers the required routes.spring-doc.cn
Adding Apache Camel to the Project
You can have both Apache Camel and Spring Cloud Contract Stub Runner on the classpath. Remember to annotate your test class with @AutoConfigureStubRunner.spring-doc.cn
Disabling the Functionality
If you need to disable this functionality, set the stubrunner.camel.enabled=false property.spring-doc.cn
Examples
Assume that we have the following Maven repository with deployed stubs for the camelService application:spring-doc.cn
└── .m2
    └── repository
        └── io
            └── codearte
                └── accurest
                    └── stubs
                        └── camelService
                            ├── 0.0.1-SNAPSHOT
                            │   ├── camelService-0.0.1-SNAPSHOT.pom
                            │   ├── camelService-0.0.1-SNAPSHOT-stubs.jar
                            │   └── maven-metadata-local.xml
Further, assume that the stubs contain the following structure:spring-doc.cn
├── META-INF
│   └── MANIFEST.MF
└── repository
    ├── accurest
    │   └── bookReturned1.groovy
    └── mappings
Now consider the following contract:spring-doc.cn
Contract.make {
	label 'return_book_1'
	input {
	outputMessage {
		sentTo('rabbitmq:output?queue=output')
		headers {
To trigger a message from the return_book_1 label, we use the StubTrigger interface, as follows:spring-doc.cn
stubFinder.trigger("return_book_1")
That will send out a message to the destination described in the output message of the contract.spring-doc.cn
Consumer Side Messaging with Spring Integration
Spring Cloud Contract Stub Runner’s messaging module gives you an easy way to integrate with Spring Integration. For the provided artifacts, it automatically downloads the stubs and registers the required routes.spring-doc.cn
Adding the Runner to the Project
You can have both Spring Integration and Spring Cloud Contract Stub Runner on the classpath. Remember to annotate your test class with @AutoConfigureStubRunner.spring-doc.cn
If you need to disable this functionality, set the stubrunner.integration.enabled=false property.spring-doc.cn
Examples
Assume that you have the following Maven repository with deployed stubs for the integrationService application:spring-doc.cn
└── .m2
    └── repository
        └── io
            └── codearte
                └── accurest
                    └── stubs
                        └── integrationService
                            ├── 0.0.1-SNAPSHOT
                            │   ├── integrationService-0.0.1-SNAPSHOT.pom
                            │   ├── integrationService-0.0.1-SNAPSHOT-stubs.jar
Further assume the stubs contain the following structure:spring-doc.cn
├── META-INF
│   └── MANIFEST.MF
└── repository
    ├── accurest
    └── mappings
Contract.make {
	input {
	outputMessage {
		sentTo('output')
		headers {
Now consider the following Spring Integration Route:spring-doc.cn
<beans:beans xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
			 xmlns:beans="http://www.springframework.org/schema/beans"
			 xmlns="http://www.springframework.org/schema/integration"
			http://www.springframework.org/schema/integration/spring-integration.xsd">
	<!-- REQUIRED FOR TESTING -->
	<bridge input-channel="output"
			output-channel="outputTest"/>
	<channel id="outputTest">
		<queue/>
	</channel>
</beans:beans>
To trigger a message from the return_book_1 label, use the StubTrigger interface, as follows:spring-doc.cn
Consumer Side Messaging With Spring Cloud Stream
Spring Cloud Contract Stub Runner’s messaging module gives you an easy way to integrate with Spring Stream. For the provided artifacts, it automatically downloads the stubs and registers the required routes.spring-doc.cn
If Stub Runner’s integration with the Stream messageFrom or sentTo strings are resolved first as the destination of a channel and no such destination exists, the destination is resolved as a channel name.
If you want to use Spring Cloud Stream, remember to add a dependency on org.springframework.cloud:spring-cloud-stream test support, as follows:spring-doc.cn
Maven
<dependency>
    <artifactId>spring-cloud-stream-test-binder</artifactId>
    <scope>test</scope>
</dependency>
Gradle
testImplementation('org.springframework.cloud:spring-cloud-stream-test-binder')
You can have both Spring Cloud Stream and Spring Cloud Contract Stub Runner on the classpath. Remember to annotate your test class with @AutoConfigureStubRunner.spring-doc.cn
If you need to disable this functionality, set the stubrunner.stream.enabled=false property.spring-doc.cn
Examples
Assume that you have the following Maven repository with deployed stubs for the streamService application:spring-doc.cn
└── .m2
    └── repository
        └── io
            └── codearte
                └── accurest
                    └── stubs
                        └── streamService
                            ├── 0.0.1-SNAPSHOT
                            │   ├── streamService-0.0.1-SNAPSHOT.pom
                            │   ├── streamService-0.0.1-SNAPSHOT-stubs.jar
├── META-INF
│   └── MANIFEST.MF
└── repository
    ├── accurest
    └── mappings
Contract.make {
	input { triggeredBy('bookReturnedTriggered()') }
	outputMessage {
		sentTo('returnBook')
		headers { header('BOOK-NAME', 'foo') }
Now consider the following Spring Cloud Stream function configuration:spring-doc.cn
@ImportAutoConfiguration(TestChannelBinderConfiguration.class)
@Configuration(proxyBeanMethods = true)
@EnableAutoConfiguration
protected static class Config {
	Function<String, String> test1() {
		return (input) -> {
			println "Test 1 [${input}]"
			return input
Now consider the following Spring configuration:spring-doc.cn
stubrunner.repositoryRoot: classpath:m2repo/repository/
stubrunner.ids: org.springframework.cloud.contract.verifier.stubs:streamService:0.0.1-SNAPSHOT:stubs
stubrunner.stubs-mode: remote
spring:
  cloud:
    stream:
      bindings:
        test1-in-0:
          destination: returnBook
        test1-out-0:
          destination: outputToAssertBook
    function:
      definition: test1
server:
  port: 0
debug: true
To trigger a message from the return_book_1 label, use the StubTrigger interface as follows:spring-doc.cn
Consumer Side Messaging With Spring JMS
Spring Cloud Contract Stub Runner’s messaging module provides an easy way to integrate with Spring JMS.spring-doc.cn
The integration assumes that you have a running instance of a JMS broker.spring-doc.cn
You need to have both Spring JMS and Spring Cloud Contract Stub Runner on the classpath. Remember to annotate your test class with @AutoConfigureStubRunner.spring-doc.cn
Examples
Assume that the stub structure looks as follows:spring-doc.cn
├── stubs
Further assume the following test configuration:spring-doc.cn
stubrunner:
  repository-root: stubs:classpath:/stubs/
  ids: my:stubs
  stubs-mode: remote
spring:
  activemq:
    send-timeout: 1000
  jms:
    template:
      receive-timeout: 1000
Contract.make {
	input {
	outputMessage {
		sentTo('output')
		headers {
			header('BOOKNAME', 'foo')
