This version is still in development and is not considered stable yet. For the latest stable version, please use spring-cloud-contract 4.2.1! |
How Can I Make The Build Pass if There Are No Contracts or Stubs
If you want Stub Runner not to fail if no stubs were found, switch the generateStubs
property in the @AutoConfigureStubRunner
annotation or call the withFailOnNoStubs(false)
method on the JUnit Rule or Extension. You can read more about this in this section of the documentation.
If you want the plugins not to fail the build when no contracts were found, you can set the failOnNoStubs
flag in Maven or call the contractRepository { failOnNoStubs(false) }
closure in Gradle.
