This version is still in development and is not considered stable yet. For the latest stable version, please use spring-cloud-contract 4.2.1!spring-doc.cn
WebFlux with WebTestClient
You can work with WebFlux by using WebTestClient. The following listing shows how to configure WebTestClient as the test mode:spring-doc.cn
Maven
<plugin>
    <artifactId>spring-cloud-contract-maven-plugin</artifactId>
    <version>${spring-cloud-contract.version}</version>
    <extensions>true</extensions>
    <configuration>
        <testMode>WEBTESTCLIENT</testMode>
    </configuration>
</plugin>
Gradle
contracts {
		testMode = 'WEBTESTCLIENT'
The following example shows how to set up a WebTestClient base class and RestAssured for WebFlux:spring-doc.cn
import io.restassured.module.webtestclient.RestAssuredWebTestClient;
import org.junit.Before;
public abstract class BeerRestBase {
	@Before
	public void setup() {
		RestAssuredWebTestClient.standaloneSetup(
		new ProducerController(personToCheck -> personToCheck.age >= 20));
The WebTestClient mode is faster than the EXPLICIT mode.
