此版本仍在开发中,尚未被视为稳定版本。最新的稳定版本请使用 Spring Cloud Config 4.2.0spring-doc.cadn.net.cn
自定义环境存储库
Spring Cloud Config 通过允许您创建和集成自定义 EnvironmentRepository 实现来支持增强其配置管理。这样就可以向应用程序添加唯一的配置源。通过实现 Ordered 接口并指定 getOrder 方法,您还可以在复合配置设置中设置自定义存储库的优先级。否则,默认情况下,自定义存储库的优先级最低。spring-doc.cadn.net.cn
以下是如何创建和配置自定义EnvironmentRepository:spring-doc.cadn.net.cn
public class CustomConfigurationRepository implements EnvironmentRepository, Ordered {
    public Environment findOne(String application, String profile, String label) {
        // Simulate fetching configuration from a custom source
        final Map<String, String> properties = Map.of(
            "key1", "value1",
            "key2", "value2",
            "key3", "value3"
        Environment environment = new Environment(application, profile);
        environment.add(new PropertySource("customPropertySource", properties));
        return environment;
    public int getOrder() {
        return 0;
@Profile("custom")
public class AppConfig {
    public CustomConfigurationRepository customConfigurationRepository() {
        return new CustomConfigurationRepository();
通过此设置,如果您激活custom配置文件,则您的自定义环境存储库将集成到配置服务器中。例如,指定custom个人资料中的application.propertiesapplication.yml如下:spring-doc.cadn.net.cn
spring:
  application:
  profiles:
    active: custom
现在,访问配置服务器:spring-doc.cadn.net.cn
http://localhost:8080/any-client/dev/latest
将返回自定义仓库的默认值,如下所示:spring-doc.cadn.net.cn
  "name": "any-client",
  "profiles": ["dev"],
  "label": "latest",
  "propertySources": [
      "name": "customPropertySource",
      "source": {
        "key1": "value1",
        "key2": "value2",
        "key3": "value3"
