This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Boot 3.4.0!
Web
Spring Boot is well suited for web application development. You can create a self-contained HTTP server by using embedded Tomcat, Jetty, Undertow, or Netty. Most web applications use the spring-boot-starter-web module to get up and running quickly. You can also choose to build reactive web applications by using the spring-boot-starter-webflux module.
If you have not yet developed a Spring Boot web application, you can follow the “Hello World!” example in the Getting started section.
APP信息
