This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Boot 3.4.0! |
Spring HATEOAS
If you develop a RESTful API that makes use of hypermedia, Spring Boot provides auto-configuration for Spring HATEOAS that works well with most applications.
The auto-configuration replaces the need to use @EnableHypermediaSupport
and registers a number of beans to ease building hypermedia-based applications, including a LinkDiscoverers
(for client side support) and an ObjectMapper
configured to correctly marshal responses into the desired representation.
The ObjectMapper
is customized by setting the various spring.jackson.*
properties or, if one exists, by a Jackson2ObjectMapperBuilder
bean.
You can take control of Spring HATEOAS’s configuration by using @EnableHypermediaSupport
Note that doing so disables the ObjectMapper
customization described earlier.
spring-boot-starter-hateoas is specific to Spring MVC and should not be combined with Spring WebFlux.
In order to use Spring HATEOAS with Spring WebFlux, you can add a direct dependency on org.springframework.hateoas:spring-hateoas along with spring-boot-starter-webflux .
By default, requests that accept application/json
will receive an application/hal+json
response.
To disable this behavior set spring.hateoas.use-hal-as-default-json-media-type
to false
and define a HypermediaMappingInformation
or HalConfiguration
to configure Spring HATEOAS to meet the needs of your application and its clients.
