This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Boot 3.4.0! |
Monitoring and Management over JMX
Java Management Extensions (JMX) provide a standard mechanism to monitor and manage applications.
By default, this feature is not enabled.
You can turn it on by setting the spring.jmx.enabled
configuration property to true
Spring Boot exposes the most suitable MBeanServer
as a bean with an ID of mbeanServer
Any of your beans that are annotated with Spring JMX annotations (@org.springframework.jmx.export.annotation.ManagedResource
, @ManagedAttribute
, or @ManagedOperation
) are exposed to it.
If your platform provides a standard MBeanServer
, Spring Boot uses that and defaults to the VM MBeanServer
, if necessary.
If all that fails, a new MBeanServer
is created.
spring.jmx.enabled affects only the management beans provided by Spring.
Enabling management beans provided by other libraries (for example Log4j2 or Quartz) is independent.
See the JmxAutoConfiguration
class for more details.
By default, Spring Boot also exposes management endpoints as JMX MBeans under the org.springframework.boot
domain.
To take full control over endpoint registration in the JMX domain, consider registering your own EndpointObjectNameFactory
implementation.
Customizing MBean Names
The name of the MBean is usually generated from the id
of the endpoint.
For example, the health
endpoint is exposed as org.springframework.boot:type=Endpoint,name=Health
If your application contains more than one Spring ApplicationContext
, you may find that names clash.
To solve this problem, you can set the spring.jmx.unique-names
property to true
so that MBean names are always unique.
You can also customize the JMX domain under which endpoints are exposed.
The following settings show an example of doing so in application.properties
Properties
YAML
spring.jmx.unique-names=true
management.endpoints.jmx.domain=com.example.myapp
spring:
jmx:
unique-names: true
management:
endpoints:
jmx:
domain: "com.example.myapp"
Disabling JMX Endpoints
If you do not want to expose endpoints over JMX, you can set the management.endpoints.jmx.exposure.exclude
property to *
, as the following example shows:
Properties
YAML
management.endpoints.jmx.exposure.exclude=*
management:
endpoints:
jmx:
exposure:
exclude: "*"
