This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Boot 3.4.0!spring-doc.cn
Audit Events (auditevents)
The auditevents endpoint provides information about the application’s audit events.spring-doc.cn
Retrieving Audit Events
To retrieve the audit events, make a GET request to /actuator/auditevents, as shown in the following curl-based example:spring-doc.cn
$ curl 'http://localhost:8080/actuator/auditevents?principal=alice&after=2024-11-27T20%3A20%3A37.56526381Z&type=logout' -i -X GET
The preceding example retrieves logout events for the principal, alice, that occurred after 09:37 on 7 November 2017 in the UTC timezone. The resulting response is similar to the following:spring-doc.cn
HTTP/1.1 200 OK
Content-Type: application/vnd.spring-boot.actuator.v3+json
Content-Length: 127
  "events" : [ {
    "timestamp" : "2024-11-27T20:20:37.575882458Z",
    "principal" : "alice",
    "type" : "logout"
Query Parameters
The endpoint uses query parameters to limit the events that it returns. The following table shows the supported query parameters:spring-doc.cn
Parameter Description
afterspring-doc.cn
Restricts the events to those that occurred after the given time. Optional.spring-doc.cn
principalspring-doc.cn
Restricts the events to those with the given principal. Optional.spring-doc.cn
typespring-doc.cn
Restricts the events to those with the given type. Optional.spring-doc.cn
Response Structure
The response contains details of all of the audit events that matched the query. The following table describes the structure of the response:spring-doc.cn
Path Type Description
eventsspring-doc.cn
Arrayspring-doc.cn
An array of audit events.spring-doc.cn
events.[].timestampspring-doc.cn
Stringspring-doc.cn
The timestamp of when the event occurred.spring-doc.cn
events.[].principalspring-doc.cn
Stringspring-doc.cn
The principal that triggered the event.spring-doc.cn
events.[].typespring-doc.cn
Stringspring-doc.cn
The type of the event.spring-doc.cn
